A/C Blower motor replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scrapla, Nov 3, 2016.
  1. Aug 23, 2023 at 7:57 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    So my motor doesn't go out, but it turns off when the wires get hit by people with big shoes.
    Everything is tight. I've checked em countless times. Not sure how to fix it without rewriting all the plugs
  2. Jul 11, 2025 at 1:25 PM
    ericinga
    ericinga Active Member
    Eric
    2003 Toyota Tacoma
    I replaced my Blower Motor and resistor. It works and air is cold but my problem is not much of it is making it to or through the vents. I can hear that blower going strong and all but something is blocking the air from the blow to the vents. Any ideas?
  3. Jul 11, 2025 at 2:24 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Your Blower motor is possibly running in reverse? or you left the plastic on your cabin air filter? or your cabin air filter is stopped up.
    Dm93 likes this.
  4. Jul 11, 2025 at 3:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    ^this, the blower wheel should have an arrow on it indicating the correct direction of rotation.
  5. Jul 11, 2025 at 3:52 PM
    ericinga
    Eric
    2003 Toyota Tacoma
    It is a 2003 Tacoma Prerunner. It does not have a cabin air filter. Some air does come out just not a lot. It is like something is blocking it. What would make the wheel run in reverse? Is there a door of some kind inside there that could be closed? I noticed looking in there after taking the blower motor out (see pic) there is what looks to be a door. It has an arm and possible hinges. Thought maybe I closed it somehow in the process. Not sure what controls it if it is a door.
  6. Jul 11, 2025 at 5:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Sometimes happens with aftermarket blowers or if the connector was replaced and not wired correctly, it's easy enough to check if it's turning the correct rotation..
    That's the air inlet (recirculation) door, it changes the air from outside air to inside air (recirculate).
    ericinga[QUOTED] likes this.
  7. Jul 11, 2025 at 5:30 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Yes! One of the simplest things one can do on a Gen 1. In fact, just about that simple on any Toyota or Lexus I’ve done it on.
    No Gen 1 truck has ever come with a factory cabin air filter. Pity.
  8. Jul 11, 2025 at 5:38 PM
    ericinga
    Eric
    2003 Toyota Tacoma
    I did have to replace the plug connector and both wires were red so I went by the way the old plug was wired to know which wire was solid and which was striped. Could have doing it wrong made the fan reverse?
    Thanks for letting me know about the recirculation door. Nobody I asked knew that.
  9. Jul 11, 2025 at 5:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's a very good possibility, happens to people on 2nd gens all the time when they replace the pigtail for some reason. Swap the wires and see what happens, I bet it fixes it.
  10. Jul 11, 2025 at 5:53 PM
    ericinga
    Eric
    2003 Toyota Tacoma
    I hope you are right. That would be GREAT!! My 2002 never had any issues. This 2003 has been a headache, get one thing fixed and something else goes out. Think it's about time to get rid of it. Will let you know if it worked!
  11. Jul 11, 2025 at 7:52 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    This happens to my second gen a lot. Doing it right now and I only have AC on full blast. The other 3 speeds don't work unless I wiggle the plug. I think it might be time to unplug it and kind of clean it up to make sure there's not some dirt and gunk in there
  12. Jul 12, 2025 at 6:24 AM
    ericinga
    Eric
    2003 Toyota Tacoma
    It fixed it! I am amazed!! Also odd that I went by the old pigtail thinking the way it was wired should be the same in the new one. Chances are some have replaced using that one and blamed the motor for not working. Still not sure why they are making the new pigtails with the same colored wire on both sides. Thanks so much! I thought it was something so much more than just changing wires around.
    Dm93[QUOTED] likes this.
  13. Jul 12, 2025 at 7:04 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Most pigtails will have all the same wires because they often have multiple applications.
    It's not feasable to make the many multiple ones with wire colors specific to every vehicle model and application that would be required so they often make them with all the same wire and it's the installer's responsibility to pin them correctly.
  14. Jul 12, 2025 at 7:13 AM
    ericinga
    Eric
    2003 Toyota Tacoma
    My far left vent has never really worked well. While trying to fix something last year I noticed the duct to that side had come loose behind the radio area but wasn't long enough to reconnect. Now I think after doing some research on other stuff there is a piece missing that connects them. Been trying to find a diagram showing what all ductwork is on the 2003.
  15. Jul 12, 2025 at 7:24 AM
    #35
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you looked here?
    https://partsouq.com/
  16. Jul 12, 2025 at 8:24 AM
    #36
    ericinga
    Eric
    2003 Toyota Tacoma
    I tried it but sadly no luck. Is a good site for other stuff though.
  17. Jul 12, 2025 at 12:13 PM
    #37
    ericinga
    Eric
    2003 Toyota Tacoma
    Anyone on this thread know what causes AC to only get cold when the truck is moving? Had freon and all that. You get stuck in traffic and it is like not having AC because unless the truck keeps moving that AC is not cold.
  18. Jul 13, 2025 at 9:35 AM
    #38
    Scrapla
    Scrapla [OP] Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    Maybe a clogged or dirty condenser? Sounds like it needs that air flow from driving. I never had that issue.
  19. Jul 13, 2025 at 5:26 PM
    #39
    ericinga
    Eric
    2003 Toyota Tacoma
    Already checked that. It is good. I think it may be the compressor. When you are sitting still and you hear the AC kick on to get colder, it has no kick. Someone mentioned the compressor clutch but I don't know what that does. New to AC systems.
  20. Jul 13, 2025 at 6:37 PM
    #40
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Is your fan clutch working?
    Beyond that need to see what the pressures are doing.
