A/C button light blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by c hoov, Aug 2, 2011.
  1. Aug 2, 2011 at 7:44 PM
    c hoov
    c hoov [OP] Member
    Fla
    07 PreRunner TRD Sport 2WD
    OK, so I'm pretty sure it's water related since it only happened during a couple downpours. A/C was on and I noticed it wasn't cooling. Looked at the A/C switch button and the light was blinking. Turned it off and back on and it seemed to work fine. Anyone have a clue why/how this happened?
    Azurapriest likes this.
  2. Aug 2, 2011 at 7:54 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yea has to do with the compressor not turning. My car did it once i fixed the a/c because the clutch was full of crap and wouldnt always let the compressor move
  3. Jun 27, 2012 at 12:15 PM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    I had the same thing happen yesterday when I was driving through about 8 inches of water on the road. I turned it off and back on have had no issues sense. I'm wondering if water got under the hood and possibly made the belt slip on the A/C unit. That would explain it. Hopefully that was all it was.
  4. Jun 27, 2012 at 12:18 PM
    BamaToy1997
    Bill
    Navarre, FL
    If the AC computer detects conditions that are not acceptable for compressor operation, which could be several things, then it will not allow the compressor to engage, and will flash the AC light to let the driver know there is a problem. Similar to a check engine light.
  5. Jun 27, 2012 at 8:42 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    funny my mom just asked me about this for her 03 'runner. i hear of the clutch relay going bad on those.
  6. Jul 8, 2014 at 5:06 PM
    mhuegerich
    mhuegerich Member
    St. Louis, MO
    09 Tacoma D-Cab TRD 4x4
    This happened to me last night. I was driving home after a heavy rain, and after a few passes through some deep puddles and standing water the A/C switch light started flashing and the cool air turned warm. Turning the A/C off and back on corrected what ever problem was occurring.
    It didn't happen at all today. Sounds like water got somewhere it wasn't meant to be.
    mhuegerich
  7. Jul 23, 2014 at 3:48 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    I've noticed the flashing A/C light/button on my '06 Tacoma on a couple of occasions. Both times I have been in a drive-thru line for several minutes. Is this an indication something is wrong? If so, what?
  8. Jul 23, 2014 at 4:03 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    The first several posts will have the answer for you.
