A/C compressor noisey
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BLACKFIREPDX, Oct 3, 2018.
  1. Oct 3, 2018 at 1:38 PM
    BLACKFIREPDX
    BLACKFIREPDX [OP] BlackFire PDX
    2015 TACOMA DBL CAB
    Front BP-51 and rear Firestone airbags
    Anyone just replaced the AC clutch, pulley and bearing instead of the whole compressor? Found the parts on ebay and not sure how much I should trust them? Don't want to pay for a new compressor and all the other stuff that goes with it.
  2. Oct 3, 2018 at 6:02 PM
    wootrain1
    wootrain1 Member
    2011 tacoma prerunner sr5 6cyl
    tranny cooler, tow wiring, running boards
    Be sure it's your compressor. I had a whining noise in that general area, 2011 prerunner. Had his sewing machine noise for 2 months. Got worse after a tranny flush. Thought it was tranny. After consulting several mechanics, my son included, they all said.... I don't know.... it's either your alternator or compressor. Well... crap!!!, changed the alternator( under warranty auto zone) no difference. Then I found on u tube a dude had the same problem... idler pully. Changed all out except tensioner pully, noise is gone, so in closing, if your ac is still cooling, mine was, then you might want to look elsewhere for your prob.
  3. Oct 3, 2018 at 6:49 PM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
    I took the belt off and spun the pulleys and they all feel good. The only thing is the noise comes and goes with the compressor turning on. My AC is still working fine. But it is noticeably loud and people have commented on that as it cycles on. Without the AC on you can't really hear it. So my thought it is the bearing in the pulley. You can buy the bearing and clutch instead of replacing the whole compressor. So I thought I would try it. Thanks for the input.
  4. Oct 4, 2018 at 6:35 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    When the AC is on, the bearing is locked in with the clutch assembly. No noise when the AC is off, it's not the bearing. Unfortunately, it's the compressor.
  5. Oct 4, 2018 at 11:54 AM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
    To be safe I assume it is not an idler pulley?:) Cheaper:) Have you installed one yourself?
  6. Oct 4, 2018 at 3:21 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not on your truck. ;)
    You said you checked the idlers. Right?
    Only makes noise when AC is on right?
    Think about it.
    Backround: I've been in the HVACR biz since 1979. Also, my forgetterer works much better than my rememberer. :)
  7. Oct 4, 2018 at 3:23 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I had the same exact issue and replaced the compressor
    Ended up being the tensioner assembly
  8. Oct 4, 2018 at 4:22 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    OP said he pulled the belt and checked the pulleys.
  9. Oct 4, 2018 at 7:26 PM
    anthony250f
    Anthony
    San Diego, CA
    I said the tensioner, not the pulley.
  10. Oct 4, 2018 at 7:32 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not the pulley on the tensioner? I don't understand how the tensioner can make a noise, but anything is possible.
  11. Oct 4, 2018 at 7:35 PM
    anthony250f
    Anthony
    San Diego, CA
    Thought so too, but I replaced every pulley and still had the sound. Once I used a mechanics stethescope it was obvious. Also someone else had the exact same noise and exact same defective tensioner.
  12. Oct 4, 2018 at 7:36 PM
    anthony250f
    Anthony
    San Diego, CA
  13. Oct 5, 2018 at 11:08 AM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
    I tried to listen with the stethoscope and couldn't pin point it. All the pulleys spun just fine under hand crank. But the noise is far worse with the AC on and when the clutch is activated. Without the AC on the noise is very minimal. But the noise sounds like a dry bearing with some grit. I'll record it. I did replace the belt and the tension made it a little better. I just don't want to spend the $$ on a compressor if it is a tensioner pulley. Thanks for the feedback.
  14. Oct 9, 2018 at 4:39 PM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
  15. Oct 9, 2018 at 7:22 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Tip, remove belt and start the engine let it run for 30 seconds and see if the noise persists. That can eliminate if it is even a pulley or something belt driven. That doesn't sound like any pulley going bad to me
  16. Oct 9, 2018 at 7:46 PM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
    Won't be any issue on the motor or battery? I assume not but wanted to ask
  17. Oct 9, 2018 at 7:59 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    No, not for a short period. You will be running the engine off the battery for those few seconds and will have no fan so make sure don't do it for more than a minute or so
  18. Oct 11, 2018 at 8:19 PM
    BLACKFIREPDX
    2015 TACOMA DBL CAB
    Well I will have to try it. Now I hear the noise with the entire heater/AC off.... Hoping for a tensioner:)
  19. Oct 11, 2018 at 9:40 PM
    anthony250f
    Anthony
    San Diego, CA
    Hopefully just the pulley
    Doing the entire assembly is the biggest pain
  20. Oct 11, 2018 at 9:42 PM
    anthony250f
    Anthony
    San Diego, CA
    Leave the truck running and put the stethescope on the pulley bolt head of the idler and tensioner
