A/C Compressor O-Ring question
Discussion in '1st Gen. Tacomas (1995-2004)' started by aaqr18, Aug 5, 2024.
  1. Aug 5, 2024 at 11:13 PM
    aaqr18
    aaqr18 [OP] Member
    2000 Tacoma 2WD 2.4L Manual Reg Cab
  2. Aug 5, 2024 at 11:18 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I do a decent amount of AC repairs at work. I always recommend a new O ring. You don't know how long that O ring sat on a shelf, then lived crushed on the new AC compressor.
    In a pinch, and with a gamble, yes pag oil up that o ring and send it. If it doesn't leak right away, chances are you will be OK.
    BTW, how do you plan to recharge your AC system??
    turbodb likes this.
  3. Aug 5, 2024 at 11:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Aug 6, 2024 at 12:02 AM
    Superdave1.0
    SoCal
    Dalandser[QUOTED] likes this.
  5. Aug 6, 2024 at 7:09 AM
    aaqr18
    aaqr18 [OP] Member
    Basically by following the write-up I had linked ^. Buying gauges, a vacuum pump, a fitting for canned R134a, and the R134a. Then pulling vacuum and letting it sit for a day before I charge it. I don't foresee myself doing this again and I am tempted to just take the easy way out and take it to a shop to vacuum/charge. After all, I may not need the tools again.
  6. Aug 6, 2024 at 8:12 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check the link I posted. I rented everything from autozone for free. There’s a video in the link too.
  7. Aug 6, 2024 at 11:50 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I'm biased, obviously ;) - I like to use new o-rings, just so you know what you're getting. Such a small (and relatively cheap) part, why risk it? (Maybe a time thing for delivery?)
    One thing I found when working on the A/C was that my first stab at fixing it didn't work. The system seemed to hold vacuum after I replaced the condenser, but it turned out there was also a leak in the compressor *sometimes* or at some point in the compression stroke, which didn't reveal itself unless the compressor was running. That meant that I had to recharge the system a couple of times (and, another couple of times while the slow leak in the compressor was diagnosed). Anyway, I say all that just to say that getting the tools might be worthwhile vs. taking it to a shop, if you end up having to do it a few times.
    "Renting" (borrowing) the tools - as @Dalandser mentioned - could be a good option as well, though I've found the A/C kits to be in rough shape, generally.
    aaqr18[QUOTED][OP] likes this.
  8. Aug 6, 2024 at 12:03 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The OEM brand Autozone rent were more expensive than I would have paid if I was buying my own tools for this job and the vacuum pump was never even used before with a brand new unopened bottle of hydraulic oil. The manifold was in new condition as well, so just look around at a few parts stores if they don’t have a nice one at the first one you go to. My city has 5 within 10 min of me so I’ll never buy anything I don’t use more than once every few years. Having one’s own tools is nice, but storing them all can be a pain sometimes too.
    aaqr18[OP] and turbodb[QUOTED] like this.
  9. Aug 6, 2024 at 1:05 PM
    aaqr18
    aaqr18 [OP] Member
    I already installed the compressor using the stock o-ring on Saturday. I had forgotten to order the Santec kit, and just wanted to get on with it. Later, I thought maybe the Santec is a thicker o-ring or something, so I posted here, hoping for some reassurance. I guess I'll see what happens!
  10. Aug 6, 2024 at 1:59 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Pull a vacuum on it before you put everything back together - at least you’ll know.
    Edit: just saw you put everything back together already haha
    aaqr18[OP] likes this.
