A/C compressor replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, Apr 15, 2021.
  1. Apr 15, 2021 at 6:37 AM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I'm thinking of having my A/C compressor replaced as a preventive measure after having my system refilled 3 times from o-rings leaks. I got about 110K miles on my 2012, lots of it speeding on dirt roads. Also, since I'm in Quebec, there's some corrosion from road salt as well.
    Any suggestions on a reliable replacement compressor? Anything else I should be replacing while I'm at it?
  2. Apr 15, 2021 at 6:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Other than leaks and refills, is the A/C cooling well?
    Unusual noise from the A/C clutch?
    Do you know the O-ring material?
  3. Apr 15, 2021 at 6:42 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Seems like a waste of money. The compressor is not usually the failure point.
    Have you dye tested the system. If nothing is coming from the seals of the pump, the pump is fine.
  4. Apr 15, 2021 at 7:03 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    In my experience I wouldn't replace it with anything other than OEM. Reman compressors are really a crap shoot. The one you have now might be better and last longer than a "new" reman.
    SR-71A likes this.
  5. Apr 15, 2021 at 7:05 AM
    Imageoguy
    2012 DCLB SR5
    The A/C is not cooling yet again. Seems like the compressor works but when I give it some gas, it sounds like I have a turbo under the hood. I replaced the clutch 3 yrs ago and it engages properly. I haven't test dyed the system. I'm thinking of replacing the pump for a few hundred $ instead of dealing with the costs of mine exploding down the road. I'm planning on keeping my taco for at least another 5 yrs.
  6. Apr 15, 2021 at 7:07 AM
    Knute
    Sounds like you have set your path.
    Suggest to get the A/C compressor from Toyota. Go OEM.
    Bleep100 and Raylo like this.
  7. Apr 15, 2021 at 7:11 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    My A/C compressor failed at 72,000 miles. I replaced it and the condenser.
  8. Apr 15, 2021 at 7:15 AM
    Raylo
    MD, USA
    If the system is really low on refrigerant, the compressor wouldn't even come on because the low pressure cutoff would activate. That noise could be any number of things... alternator, idler pulley, whatever. First thing is to put some AC gauges on it and actually measure vent temps.
  9. Apr 15, 2021 at 7:18 AM
    Raylo
    MD, USA
    How did it fail? Did the main seal just start leaking or did you have a "black death" explosion? I had that once on a Chevy S10 and had to change the condenser and flush everything else out to get all the debris out of the system. What a PITA.
    TomTwo[QUOTED] likes this.
  10. Apr 15, 2021 at 8:12 AM
    TomTwo
    Bill
    I-85 Southbound
    The main seal
    Slowly failed. I had $700 in parts and did all the labor myself
  11. Apr 15, 2021 at 8:37 AM
    Raylo
    MD, USA
    Why did you replace the condenser, then? Just a precaution?
  12. Apr 15, 2021 at 9:30 AM
    TomTwo
    Bill
    I-85 Southbound
    Because the accumulator is built in to the condenser. And should be changed when you have a A/C failure. No since in changing the $$ compressor and possibly leaving trash in the system only to work it’s way to the new compressor and having to redo everything
    deanosaurus likes this.
  13. Apr 15, 2021 at 9:48 AM
    Raylo
    MD, USA
    Wow, learned something new, I have never seen that before. Filter/driers and accumulators are usually a cheap separate piece. I guess I don't know my truck as well as I thought... and in this case it's a good thing because I have never had to touch the air conditioning system. Probably just jinxed myself.
  14. Apr 17, 2021 at 6:25 PM
    Imageoguy
    2012 DCLB SR5
    Looks like I'll go for OEM or the Denso 471-9196. Seems like they might actually be the same? Anyhow, both are expensive :spending:
    TomTwo likes this.
  15. Apr 17, 2021 at 6:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try putting some service valve schraders in it, those can leak. Put some dye in it
    How do you know the compressor is making the noise you're concerned about? Have you listened around with a stethoscope?
    It would be a bummer if you put a new compressor in it and still had a slow leak and a weird noise
  16. Apr 18, 2021 at 5:27 AM
    Imageoguy
    2012 DCLB SR5
    The noise only comes up when I put the A/C on. It's hard to describe other then a winding noise as the engine revs. It stops as soon as I cut out the A/C so don't know what else it could be:notsure: Would a lack of refrigerant also cause this type of noise?
  17. Apr 18, 2021 at 5:45 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I misunderstood. If the noise is only there when the a/c compressor engages then it sounds like you're on the right track
  18. Apr 18, 2021 at 6:00 AM
    gearcruncher
    Canadain bumper technician
    I am currently ordering parts for mine . My compressor grenaded on the highway causing my serpentine belt to blow as well . Thankfully I had a spare serpentine belt under my seat . I disabled the clutch and AC relay and fuses to get home . Needless to say I have been driving with no A/C for a few years . You can still drive the truck as long as the A/C system is disabled . The A/C clutch will never apply .
    Living way up North in Canada , I seldom need to use the A/C . I am also doing the AC mod to disable the compressor from operation during defrost
    https://www.tacomaworld.com/threads/a-c-on-with-defrost.7160/
    There is an informative thread with diagnostics and schematics where I have been doing my research here .
    https://www.tacomaworld.com/threads/a-c-light-blinking.107982/
    According to some of the members posting throughout the link , there is talk that the factory compressor ( Delphi ) is junk ??? Its an old thread from back in 2010 mind you .Maybe things have changed
