A/C Control Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lone_commander_, Feb 1, 2016.
  1. Feb 1, 2016 at 9:24 PM
    lone_commander_
    lone_commander_ [OP] They Call Me the Fireman!
    Brandon
    South Carolina
    2007 Silver Tacoma Sport (Prerunner)
    6in Pro Comp lift, 17in Pro Comp 05 series wheels, UWS black toolbox, Westin bulbar, Halo projector headlights, red lights and a siren for fire calls, etc.
    My a/c control lights went out on the fan speed dial, temp gauge, and the a/c button between the two underneath. I ran into a problem however. One, I don't know the bulb size and two to change the a/c button light a white cover has to come off (see photos). There is a screw underneath a socket for a plug, but it seems almost inaccessible. One last thing is I would like to change the amber over to white or blue. But the dials have an amber film on them it seems. Any ideas?
  2. Feb 2, 2016 at 2:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are only the two lights that are in the assembly. There is no third bulb. I see in picture # 3 above you already have the two bulbs removed. Take those bulbs to the auto parts store of your choice and get new bulbs.
  3. Feb 2, 2016 at 6:19 AM
    lone_commander_
    Brandon
    South Carolina
    I could've sworn there was 1 mini light for each button below the dials after I pulled the switches out @Jimmyh
  4. Feb 2, 2016 at 9:13 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    I replaced mine back in December of '15. I had a hard time finding them at a local parts store and had to goto the dealership. They were $23.00 plus tax for two of them. :annoyed:
  5. Feb 2, 2016 at 9:46 AM
    lone_commander_
    Brandon
    South Carolina
    @TexS4 Dang dude that sucks. I called my local dealer. They want $13 plus tax. However, I called and got a part number! The part number for anyone wondering is 8499910090. It is a 74 neo wedge bulb. I should be able to find something online. You don't know of any ideas to get the film off of the dials do you? :notsure:
  6. Feb 2, 2016 at 10:23 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
  7. Feb 2, 2016 at 10:38 AM
    cvisinho
    Rhode Island
  8. Feb 2, 2016 at 10:47 AM
    lone_commander_
    Brandon
    South Carolina
    @cvisinho You have the LEDS from super bright? Did you get another color other than amber? If so, can you see it clearly?
  9. Feb 2, 2016 at 10:59 AM
    cvisinho
    Rhode Island
    I have the white. The amber you see is actually a film on the control ring itself. There is no changing that unless you want to take on a pretty lengthy process of cutting, sanding, re-painting.
    They are single led's though. Not as much light coverage as I would like.
    The ones I just ordered today are 3 smd led's.
    I am hoping these spread more light.
  10. Feb 2, 2016 at 11:05 AM
    lone_commander_
    Brandon
    South Carolina
    @cvisinho There's no way remove that white cover on the backside of the unit and remove the film that way? The single LEDs pretty close to factory brightness?
  11. Feb 2, 2016 at 11:16 AM
    cvisinho
    Rhode Island
  12. Feb 2, 2016 at 11:47 AM
    lone_commander_
    Brandon
    South Carolina
    See the light for the a/c button?
  13. Feb 2, 2016 at 11:49 AM
    lone_commander_
    Brandon
    South Carolina
  14. Feb 2, 2016 at 11:56 AM
    cvisinho
    Rhode Island
    I got nothing on those. I just assumed they were part of the clear light system in the back.
    There are more details in that other thread.
  15. Feb 2, 2016 at 12:26 PM
    lone_commander_
    Brandon
    South Carolina
    Negative on that one. That's why I was trying to figure out how to remove that screw so I could get to it and see what was up lol
  16. Feb 2, 2016 at 2:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I thought that was just part of the switch itself and not replaceable.
  17. Feb 3, 2016 at 8:38 AM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Where did you get the replacement led with 3 smd?
  18. Feb 3, 2016 at 8:53 AM
    lone_commander_
    Brandon
    South Carolina
    The dials themselves take a 74 neo wedge. I will post a link later to some I ordered. (You need two total for all 3 dials). The a/c and recirculate buttons take a 3V 3mm LED. (Again I will post a link, 2 lights total).
  19. Feb 3, 2016 at 8:54 AM
    cvisinho
    Rhode Island
  20. Feb 3, 2016 at 8:56 AM
    lone_commander_
    Brandon
    South Carolina
    Also, for you all wishing to do a light color change mod. I will post a disassembly write up!
