A/C controls & steering wheel controls are not lighting up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moransa, Jan 19, 2016.
  1. Jan 19, 2016 at 2:54 PM
    moransa
    moransa [OP] Member
    Scott
    Cypress
    07 Tacoma 4x4
    I've been running searches on this for days, and turned up nothing. I'm pretty sure it is a fuse because this happened before and I found the quick answer here. I just don't remember which one, I checked all the ones that made sense, but nothing was bad.
  2. Jan 19, 2016 at 5:32 PM
    Standard Issue X06
    Standard Issue X06 Well-Known Member
    2006 Xrunner
    Interior LEDs in foot well, sub rings, map lights, dome light, self done window tint, "always on fogs" custom head unit, custom built sub box for access cabs.
    if you have an aftermarket stereo with the hand control adapter check it. My steering control lights went off because the hand control adapter had gone out.
  3. Jan 19, 2016 at 5:34 PM
    moransa
    moransa [OP] Member
    Scott
    Cypress
    07 Tacoma 4x4
    Thanks, but that wouldn't account for the a/c controls not lighting up.
  4. Jan 19, 2016 at 5:38 PM
    Standard Issue X06
    2006 Xrunner
    I don't believe they are on the same relay. But if they had blown a fuse wouldn't the gauge cluster as well as the door lock/unlock window up/down illumination gone out? Being all that's on the same dimmer switch.
  5. Jan 19, 2016 at 5:43 PM
    moransa
    moransa [OP] Member
    Scott
    Cypress
    07 Tacoma 4x4
    It didn't make sense to me either the first time.
  6. Jan 19, 2016 at 5:50 PM
    Standard Issue X06
    2006 Xrunner
    Did you check all the fuses behind the coin drawer? I think that's what it is. The little drop down "hidey hole" right by the drivers door.
  7. Jan 19, 2016 at 5:50 PM
    Standard Issue X06
    2006 Xrunner
  8. Jan 19, 2016 at 5:51 PM
    moransa
    moransa [OP] Member
    Scott
    Cypress
    07 Tacoma 4x4
    Not all of them. Taking it to the dealer tomorrow. Last time this happened, I found the answer in 5 minutes.
  9. Jan 10, 2023 at 4:15 PM
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    So did you find out what fixed it
