A/C Damper problem - help needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by JAJI4, Oct 9, 2011.
  1. Oct 9, 2011 at 7:37 PM
    JAJI4
    JAJI4 [OP] Well-Known Member
    Sunshine State
    2001 Tacoma; Double Cab; TRD Offroad; 2WD
    I've got a 2001 double cab prerunner. For the past month, I've noticed the following issue with my AC:
    1. The AC damper (back behind the dash) seems to constantly move. I can hear it constantly self adjusting.
    2. The damper continuously self adjusts whether the AC/heater is turned off or on.
    3. The sound seems to be coming from the passenger foot-well area.
    4. The AC temp seems to go from cold to cool, to luke warm, to cold and back again (unrelated issue with the refrigerant perhaps? I don't know....).
    Any thoughts on this - especially points 1-3? It sounds like an electrical/solenoid issue. I haven't had any "check engine" codes appear. If there is something that needs maintenance, I don't know what it would be or where to start. Any advise is appreciated.
  2. Jan 14, 2013 at 5:48 PM
    kpmurphy
    kpmurphy New Member
    Did you figure out what the problem was i have the same issue
    thanks
    Kevin
  3. Jan 15, 2013 at 10:33 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Sounds like a spring has broken or a link has disconnected.
    You'll have to get in there and see what broke.
    If this is true, then one of your controls should not be working .
