A/C Evaporator Drain
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gtech2, Jan 16, 2012.
  1. Jan 16, 2012 at 11:45 AM
    Gtech2
    Gtech2 [OP] Member
    Jimmy
    Southern California
    98 Limited 4x4
    Deckplate
    Anyone know where the A/C evaporator drain is located? Trying to clean out the odor coming from the cabin vents when I run the A/C and want to start by making sure the evaporator drain isn't clogged.
  2. Jan 16, 2012 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Passenger side firewall
  3. Feb 22, 2012 at 6:02 PM
    Gtech2
    Gtech2 [OP] Member
    Jimmy
    Southern California
    98 Limited 4x4
    Deckplate
    Thanks Chris!
  4. Feb 22, 2012 at 6:16 PM
    Madjik_Man
    Colorado Front Range
    When the A/C evap drain was clogged on my other vehicle (located on the passenger side firewall) the floor of the footwell got drenched.
    If your drain isn't clogged, think about mixing a few drops of essential lavender oil in a water bottle mister and spraying the vents (don't know if you can do it from the outside - eg at the base of the windshield - like you could on my Legacy). Not only will the lavender make it smell better, but it is also anti-fungal and anti-bacterial
  5. Feb 22, 2012 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats a dam good idea!
  6. Feb 22, 2012 at 6:20 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Judging by how snow used to blow in the vents on my old 96, you should be able to spray from the outside in.
  7. Feb 22, 2012 at 6:22 PM
    Madjik_Man
    lol
  8. Feb 22, 2012 at 6:23 PM
    Madjik_Man
    MADJIK_MAN MOD!!! STICKY IT!!! :D
    Also, lavender is calming, so it cuts down on road rage too.
  9. Feb 22, 2012 at 6:28 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    You work at bath and body works?
  10. Feb 22, 2012 at 6:34 PM
    Madjik_Man
    Nope.
    Just a typical Boulderite.
    All natural baby :p
  11. Feb 22, 2012 at 7:46 PM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    Does someone have a picture of the drain?
  12. Feb 27, 2012 at 12:29 PM
    Gtech2
    Gtech2 [OP] Member
    Jimmy
    Southern California
    98 Limited 4x4
    Deckplate
    Haha, I would definitely spray the lavender if I had to commute in heavy traffic. Less likely to flip the bird if someone cuts you off! I just spray Ozium which has a nice smell and also reduces airborne bacteria.
  13. Feb 27, 2012 at 12:29 PM
    Gtech2
    Gtech2 [OP] Member
    Jimmy
    Southern California
    98 Limited 4x4
    Deckplate
  14. Feb 27, 2012 at 3:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If its a mildew smell I'd say your drain may be plugged, if its misc. odor/odors, your interior coil is probably dirty & the culprit
  15. Feb 27, 2012 at 5:37 PM
    Adam Baum
    PCS
    How do you unclog it? I don't own an air compressor.
