A/C Filter Screen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boulder Taco, Mar 26, 2017.
  1. May 12, 2021 at 2:26 PM
    Taco'09
    Taco'09 Well-Known Member
    With a filter that looks like that and you got the dash out I would definitely replace the evaporator and include a new thermistor.
    I would probably also replace the heater core but that is just me because removing the dash is such a pain and one of the most unpleasant jobs I have done on a Taco, and I have done it twice. Moreover, both the high-side line and suction line need flushed. And don't be surprised if the inside of the condenser is also full of junk and needs flushed.
    Lucky you. Sorry
  2. May 12, 2021 at 3:20 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
    Yes I had already purchased the evaporator and because the filter was so clogged I have ordered the condenser/drier thanks for the advice
  3. Apr 8, 2022 at 11:00 PM
    TacoTuesday1
    FL
    thinking of replacing the filter and drier as maintenance during a recharge
    good idea?
    cheap enough, filter is $2.74
    drier $13.51
  4. Apr 9, 2022 at 2:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The filter drier is built into the condenser at least on the second generation Tacoma. I don't think it is serviceble as a separate unit.
    TnShooter likes this.
  5. Apr 9, 2022 at 5:06 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    that filter shouldn't even get clogged enough to need replacement unless the compressor is shredding metal off. (a little bit of metal comes off when brand new but not enough to clog that filter)
    that screen should only need replacement if the compressor fails, then you would discharge the lines, replace compressor, flush lunes, chang filter and orings, then re fill.
  6. Aug 14, 2022 at 2:18 PM
    MarkNap128
    MarkNap128 Well-Known Member
    Mark
    West Warwick RI
    2013 Black Tacoma TRD Sport 4x4 dbl cab
    None
    Hey guys.
    if I have the replacement expansion valve do I need to purchase the tube/filter as well?
  7. Aug 14, 2022 at 2:46 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    Ok so that filter is in the line not the evaporator
  8. Aug 14, 2022 at 4:31 PM
    TacoTuesday1
    FL
    these are typically two separate components, with an expansion valve being where lines meet the firewall
    and tube/filter being inline with one of the lines at a hex fitting, located somewhere else usually in the engine bay
  9. Aug 15, 2022 at 3:07 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    Thanks man I found one! I couldn’t find it
    because Toyota calls it a refrigerant filter and not an orifice tube. Yay for consistency
