A/C kick ON, once Defrost is ON!
Discussion in '1st Gen. Tacomas (1995-2004)' started by akrinar, Sep 10, 2018.
  1. Sep 10, 2018 at 5:22 PM
    akrinar
    akrinar [OP] Well-Known Member
    2002 Tacoma 2.7 - 4 cylinder - PreRunner
    Tacoma 2002 - Pre-Runner
    2WD - 4 Cylinder
    Hi, I would like to know how to disable the A/C from coming ON when selected the mixed(floor/windshield) and windshield only modes on the environmental selector. Basically the A/C get on even the A/C button is OFF. I do not need to A/C on once i use the Defrost. It save a lot of the MPG.
    I found the great instruction to change the wires from D3 connector triggered the A/C amplifier to engage the compressor for second generation of Tacoma.
    https://www.tacomaworld.com/threads/a-c-on-with-defrost.7160/
    This is another way:
    https://www.tacomaworld.com/threads/defrost-without-a-c-mod.126495/
    I would like to know if it's going to work for first generation too!
    TNX
  2. Sep 10, 2018 at 5:32 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yes it’s correct that the defroster uses air from the ac as the air has a dried affect and help to defog or defrost the windshied. This means that if the defrost is on the the ac compressor is on.
  3. Sep 10, 2018 at 5:35 PM
    akrinar
  4. Sep 10, 2018 at 6:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Ac works by dehumidifying Before cooling.
    So when you want to defrost the ac kicks on to help dehumidify
  5. Sep 10, 2018 at 6:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Why would you want to blow warm moist air on the inside of the windshield. If you don't want cold air set the temperature dial somewhere in the middle then you can blow dry air that is anywhere between hot and cold. The key is dry air. Not using the AC with the defrost on would make things worse.
  6. Sep 10, 2018 at 7:26 PM
    Indy
    Indy Master of all I survey.
    Help. My wheels keep going around in circles when i drive....
    In other words, is working as designed.
  7. Sep 10, 2018 at 8:15 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    While most modern vehicles kick the ac on during defrost, Defrost does, and has worked for a billion years without ac.
    devinzz1 likes this.
  8. Sep 10, 2018 at 8:53 PM
    cleonard
    cleonard Active Member
    Santa Clarita, CA
    2003 extra cab 3.4L 4x4
    There is a thread in this forum on the mod. If I remember correctly, you modify the stop on the mode selector so it can go one position past defrost. The result is defrost with no A/C. I want to do this mod because it would have a positive effect in my climate. In the winter it is usually low 40's or high 30's and somewhat dry. Engaging the defrost with the A/C on actually makes the fogging worse before the engine produces some heat.
    Ridgerunner and devinzz1 like this.
  9. Sep 10, 2018 at 9:31 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It's okay if it's winter and you just want to heat up the windshield tho
  10. Sep 11, 2018 at 6:44 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    This is the fastest way. I did it though I never use it due to the bad effect in rain. I need the AC-linked defrost here. All you do is take the selector knob off, shave off the square stop-tab on the underside of it, then replace it back on. You can now move the selector that one notch past defrost where it'll blow non-AC-linked defrost air.
  11. Sep 11, 2018 at 6:58 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    On my 1999, there is a 2 pin connector near the defrost knob. If you disconnect it, you will get the exact functionality you are looking for. And it’s easily reversible!
  12. Sep 11, 2018 at 10:36 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    @akrinar, I highly doubt you'd notice a difference in MPGs with the A/C on...
    That's not really true.
    If you have the temp dial set on med/high, it's not cooling the air (thereby making the fogging worse) or doing anything different than if the a/c was off, aside from dehumidifying the air. It's just pulling ambient temp air, which, if your windows are fogged, is cold air.
  13. Sep 11, 2018 at 12:23 PM
    cleonard
    Santa Clarita, CA
    Perhaps I was imprecise. This issue only occurs immediately after startup before the engine is pumping hot coolant through the heater core. When I drove my 93 F150 that does not engage A/C on defrost I had basically no issue. When I drove my 98 Camry in the exact same condition, the window fogging would get so bad that I couldn't see. On occasion I had to pull over to the side for a couple of minutes so the engine could supply hot coolant and the defrost would function.
    The issue is the cold air coming out of the defrost vents cooling the glass and causing condensation. Sure operating the wipers can clear it, but not cooling the glass fixes it too.
    It is a narrow use case which only lasts about two minutes, but I does exist and I'm able to repeat it. I've not driven my Tacoma in this condition yet, but I will in the next few months.
  14. Sep 11, 2018 at 12:31 PM
    jbrandt
    Justin
    Like I said, even with the A/C on, you're not pumping cold air unless you have the temp set to low. Turn the heat up and it will blow hot air (once the engine has warmed up a bit).
    When it's cold (in CA I use that term loosely, lol), I usually let my truck warm up for those 2 minutes anyway.
  15. Sep 11, 2018 at 4:55 PM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    Unplug the wire off the front of the compressor. No more ac with the defrost or without.
  16. Sep 11, 2018 at 5:37 PM
    akrinar
    It's not about warm/cold air at all!
    If you switch to the defrost, the Compressor will kick ON and starting to engage in earlier Tacoma models. The whole point is I do not want to engage and run with A/C compressor once I'm using the Defrost. It's made a lot of difference in RPM and MPG's once the car run with A/C compressor. As I said it's nothing to do with Cold/medium/HOT air..
    Thanks
  17. Sep 11, 2018 at 5:38 PM
    akrinar
    That's the last option... ;)
    Tnx
  18. Sep 11, 2018 at 5:39 PM
    akrinar
    True...
  19. Sep 11, 2018 at 5:41 PM
    akrinar
    Yes, It's in earlier Tacoma models. Nowadays you have the option to keep A/C On or Off once the Defrost is ON.
  20. Sep 11, 2018 at 5:44 PM
    akrinar
    You do not get it Bro!!!
    Yes, it designed that way. But we are going to change it...
