A/C light blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by buddywh1, Aug 13, 2010.
  1. Apr 10, 2023 at 9:27 PM
    #101
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Curious on the UAC compressor you purchased to fix your ac problem. I am having the same issue with mine and need a new compressor discharge line and condenser. Curious as to how your install went and how the compressor is running.
  2. Dec 4, 2024 at 11:00 AM
    #102
    SloppySteve
    SloppySteve New Member
    2008 TRD Off Road
    Hey all. Just got the blinking AC light after mechanic changed belt 2 idlers and tensioner. Frosty mornings using defrost it's blinking. Any help would help or info would be appreciated!
  3. Dec 4, 2024 at 11:02 AM
    #103
    MACKT28
    2006DCLB
    I would swing it by your local dealership and have them make sure you don't have a leak anywhere. Could be a possibility but maybe not.
  4. Dec 4, 2024 at 12:49 PM
    #104
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Need to check and make sure the compressor and lock sensor are plugged in and no wires are damaged.
    Low refrigerant will not cause the A/C light to flash.
    SloppySteve[QUOTED] likes this.
