A/C Light Blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evil Bubba JoJo, Oct 3, 2016.
  1. Oct 3, 2016 at 7:30 AM
    Evil Bubba JoJo
    Evil Bubba JoJo [OP] Member
    2010 Tacoma Prerunner
    So my A/C stopped blowing cold and the A/C light started Blinking.
    I checked the relay it's good. I checked the freon level it's good. I pulled the filter and checked it its also good. I ran a jumper cable on the pressure switch and it's good.
    The clutch free turns by hand. I made sure all the wires were tight on the compressor as well. Any advice would be appreciated. I really don't want it to be the compressor.:notsure:
  2. Oct 7, 2016 at 12:31 PM
    turbomkt
    turbomkt Well-Known Member
    Santee
    '13 Sport
    CBI Offroad bumper
  3. Oct 7, 2016 at 12:51 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  4. Oct 24, 2016 at 11:53 AM
    Evil Bubba JoJo
  5. Oct 24, 2016 at 11:56 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    How much more is the OE compressor? Or find one out of a junkyard
  6. Oct 24, 2016 at 12:01 PM
    Evil Bubba JoJo
    Also the OE is $337
  7. Oct 24, 2016 at 12:01 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I'm no expert but I'd imagine you'd have to perform a complete flush and then recharge once the new compressor is on. Other than that I think it's pretty much bolt off old, bolt on new
  8. Oct 24, 2016 at 12:02 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    If the price is that similar I'd get OEM over aftermarket any day. Especially on components like this.
  9. Oct 24, 2016 at 12:03 PM
    Evil Bubba JoJo
    See someone told me (the start of many horrible stories) I had to change the dryer , serpentine belt, and, one guy even said the condenser as well.
  10. Oct 24, 2016 at 12:07 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Well I'm no mechanic but I'm going into Toyota later this week for my 10,000 mile service, I have a good relationship with the mechanics there. I can ask if you'd like.
  11. Oct 24, 2016 at 12:26 PM
    Evil Bubba JoJo
    Yes please if you don't mind
  12. Oct 24, 2016 at 12:27 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I'm going in on Wednesday. I'll try to remember and ask
  13. Oct 24, 2016 at 12:28 PM
    Evil Bubba JoJo
    Thank you very much
  14. Oct 24, 2016 at 12:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    A new accumulator will be required, likely purchased at the same time and place, if you want the warranty on a new compressor.
    Its also correct practice anytime the system is open to atmosphere for any component change.
  15. Oct 24, 2016 at 12:38 PM
    bueller
    bueller Well-Known Member
    AZ
    Whoever it was that told you you needed to change pretty much everything was correct and that does include the condenser. The condenser will not flush well. I used to work at an auto AC repair shop. To do it right, it's going to cost you. I haven't looked at my '15 but I think the Tacoma has a Nippondenso compressor. Stay OEM and do not go aftermarket on the compressor. You'll thank me later.
  16. Oct 24, 2016 at 1:44 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Tacoma has a thermal expansion valve (TXV), not an orifice tube. There is no accumulator. There is a 'sort of' receiver drier built into the condenser. If I'm not mistaken.
    OP, if you are sure the compressor is toast, it needs removed and the oil drained to check for metal junk. There is also a strainer just before the TXV that should be checked for metal junk. If there is any junk, the system needs flushed, the condenser needs replaced, and the installer needs to fill up with the proper oil amount in the proper components.
    This job, done properly, isn't really for the shadetree mechanic.
  17. Oct 24, 2016 at 2:52 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    So did your AC completely stop working?
  18. Nov 2, 2016 at 12:06 PM
    ecliff5
    ecliff5 Well-Known Member
    Brooklyn, NY
    06 Tacoma Access cab
    King Coilovers with Total Chaos stock length upper & lower control arms, Bilstein and Archive Garage shackle flip in the rear Bruteforce Fab Front & rear SOS Offroad Concepts sliders RCI skids 285/75/16 Falken Wildpeak AT3W on Pro Comps Hard Shell RTT and ARB awning on a Pinsu rack Home made storage drawer unit in the bed.
    I am having a similar problem, but haven't read an article with someone having this issue...
    My AC died while on my cross country road trip as soon as I hit the desert on full blast, I heard a terrible squeal from the engine and then the AC light started blinking and the system blew hot air. I shut off the AC and fan system. I tried to turn just the fan on without the AC system on and it still made the squealing noise.
    From what I have read about people hearing the squeal, they only hear it when they turn the AC system on. I hear it whenever I try to turn the fan on period, means no heat or defroster either.
    I drove cross country this way and put another 4k + miles on it, brought it to a dealer in Seattle and they quoted me $2500 and said I need a new compressor and condenser. They said the compressor seized.
    I am wondering if my compressor seized but the pully still spun, so no damage was being done to the belt on the road trip home if it could just be the clutch?
    Any inputs feel free to chim in.
