A/C light still blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by k9srgn, Aug 9, 2019.
  1. Aug 13, 2019 at 4:02 PM
    CurtB
    CurtB Well-Known Member
    Curt
    Kansas
    2010 Tacoma SR5
    Told ya. Find another shop, or 5! 2800 is robbery for a 200 compressor, add a condenser for 100, and labor for 100. JFC
  2. Aug 13, 2019 at 4:38 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Ha! 100 for labor!? It's at least 10hrs for all of that
  3. Aug 13, 2019 at 5:30 PM
    b_r_o
    b_r_o get em loaded, get em high, get em off
    Alex
    WA
    2015 DCLB
    OP said evaporator, not condenser
  4. Aug 13, 2019 at 5:55 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    10 hours to change out a comp and condenser, leak test , vac and recharge? lol ok
  5. Aug 13, 2019 at 6:05 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    So I guess I missed that part. Only reason to change the evaporator is if it is leaking. Is it? I don't know either.
    Other than a blinking light, not much to go on.
    b_r_o likes this.
  6. Aug 13, 2019 at 6:06 PM
    S.B.
    Sean
    San Diego
    15 Taco
    If compressor goes bad, the evaporator is one of items that need to be replaced along with the compressor
  7. Aug 13, 2019 at 6:09 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Where is the evaporator located, and why does it need replaced?
    b_r_o likes this.
  8. Aug 13, 2019 at 6:15 PM
    S.B.
    Sean
    San Diego
    15 Taco
    In the dash, gets clogged with debris from the compressor letting go, can't flush em (passages too small). So typical parts to replace when a compressor goes is: compressor, evaporator, expansion valve, dryer (which is part of the condenser). Older cars you can flush the evaporator and dryer is separate from the condenser
  9. Aug 13, 2019 at 6:45 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Let's see if I follow. The compressor fails and grinds its self up. That does happen. Comp still pumps some and sends debris to the dryer in the condenser. Fine debris manages to get thru that and makes it to the fine mesh filter right before the TXV. Then it plugs up the passages in the evaporator and cannot be flushed. Is that what you are saying?
  10. Aug 13, 2019 at 7:08 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Yup, normal procedure. Been there with a cust's vehicle when their aftermarket warranty would only pay for a condenser and compressor and flush, new compressor shit the bed right away.
  11. Aug 13, 2019 at 7:17 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Right away? And a plugged up evaporator caused it? Manifold gauge pressures would show that immediately.
    Anyways, done arguing on the internet for tonight.
  12. Aug 13, 2019 at 7:20 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Debris in the evaporator got into the new compressor once fired up and ate up the new compressor
  13. Aug 13, 2019 at 7:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Filter before the TXV Valve Should prevent the Evaporator / TXV from getting contaminated with fine particles.
    CurtB, 06Tacooo and b_r_o like this.
  14. Aug 13, 2019 at 7:48 PM
    b_r_o
    Alex
    WA
    2015 DCLB
    You are describing a rare scenario. There is a reason most corporate insurance policies such as the one you referenced stop at the compressor and condenser. Seeing metal contamination beyond that is just not common enough
    I replace compressors all the time with just a basic flushing of the lines. I'll disconnect the inlet line to the condenser, take a look at how much metal is in there, explain the risks and benefits to the customer, and go from there. If the manufacturer that I'm buying the compressor from wants the condenser replaced I'll bring that up too.
    It's not about how thorough the mechanic wants to be, it's about how thorough the customer wants to be, what kind of risk they want to take on, and how much they want to spend.
    But who knows, maybe the evaporator was leaking like a motherfuker and the drain tube was puking refrigerant oil.. those are the AC leaks I like, easy to find and they pay good lol
    CurtB and Jimmyh like this.
  15. Aug 13, 2019 at 8:26 PM
    #35
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Thanks for all the information. Time for bed. My heads gonna explode with Tacoma A/C info
    b_r_o likes this.
  16. Aug 13, 2019 at 8:36 PM
    #36
    b_r_o
    Alex
    WA
    2015 DCLB
    Ask them why they want to replace the evaporator. Is it due to metal contamination? Evidence of refrigerant leakage?
  17. Aug 13, 2019 at 8:41 PM
    #37
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    I will! Thanks
    b_r_o likes this.
