A/C Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Dec 24, 2009.
  1. Dec 24, 2009 at 6:44 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Hey everyone,
    So my 07 tacoma is starting to develop a sound in the A/C unit (36K miles). If I had to describe it, like a card stuck in a bike wheel:confused:. It is only noticeable in the low and low medium setting. Any ideas? Am I still under warranty and can just have Toyota fix it?
  2. Dec 24, 2009 at 7:21 AM
    NumNutz
    Virginia Beach, VA
    Lots.
  3. Dec 24, 2009 at 7:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pull the filter, and see if a leaf or something is in the blower wheel.
  4. Dec 24, 2009 at 7:24 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    The cabin air filter? Where is it located?
  5. Dec 24, 2009 at 7:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    behind the glove box
  6. Dec 24, 2009 at 7:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check out my "Cabin Filter cleaning" thread.
  7. Dec 24, 2009 at 7:30 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Wow thats easy. I'll go do that right now and report back.
  8. Dec 24, 2009 at 7:31 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Wasn't there just a thread where a member pulled the motor, cleaned it and re-greased the bearings?
  9. Dec 24, 2009 at 7:38 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You say "AC Unit" but do you really mean the blower unit?
    As stated above it is likely debris in your blower housing.
  10. Dec 24, 2009 at 7:45 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Yea I just mean air conditioning/blower.
  11. Dec 24, 2009 at 8:16 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    sounds like crickets
  12. Dec 24, 2009 at 8:25 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I have this too, driving me nucking futs
  13. Dec 24, 2009 at 9:31 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    I just went and cleaned my cabin filter, boy was it dirty, but after cleaning it out and reinstalling it. I turn on the fan only to hear this annoying little cricket chirp. Headed to the dealer next week.
  14. Dec 24, 2009 at 10:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    That would be the bushing in the motor.
  15. Dec 24, 2009 at 11:13 AM
    NorthXNorthwest
    NorthXNorthwest Well-Known Member
    Myrtle Creek, Oregon
    07 Sport DC 4X4 Not Debaged
    BHLM, Ultra Mammoths, Husky mats, K&N non true CAI, window tint, Avid Steps and light bar.
    Better get at it before it starts sounding like the cricket on crack, my 07 with abount the same mileage is doing it too!
  16. Dec 24, 2009 at 11:15 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I've found the reason for the ticking sound. My dealer kept saying "normal" and "there are leaves in the fan". I kept telling them otherwise until I got pissed enough to just take apart the blower fan and see where EXACTLY the sound was coming from. The sound is coming from the metal faceplace which covers the wire spool around the spindle of the fan. the faceplace must be balanced properly because it holds in place the spindle which is rotating for the fan to blow. when the faceplace is off balance by one of two screws that holds it in place, the fan ticks like a MF'er....as you balance the plate, the tick goes away and is as quiet as a mouse.
    #1 I took my glove box completely off making sure to release the springy thing first on the right side towards the passenger door and then just popped her out.
    #2 I then got out my trusty ratchet with a 5.5mm socket and removed 3 screws on the underside of the blower....the fan will slide out easily. leave the wires attached (be careful as the fan is still runnin' lectric)
    #3 let down the door that holds the cabin filter in and remove filter. now you can reach up in there and see if any of those mysterious leaves are present. blow it out with your air compressor or just root your hand around in there to get anything out.
    #4 hold the black plastic fan housing in your hand carefully and reach over and turn your a/c on the low setting (BE CAREFUL as that thing is quick to get away from you and can take a nub off pretty quickly) make sure you can hear the sound coming from the assembly in your hand. If so, move to step #5.
    #5 remove the covering with a phillips screwdriver (4 screws - i think) and remove that cover to reveal a silver metal cover with TWO (2) lubed screws. THESE ARE THE SCREWS THAT MUST BE BALANCED. Take a pair of vice grips and grab the black housing with them so you can get your hands away from the moving fan and so you can hold it steady. then use your phillips screwdriver on one of the two screws and notice how you can make the sound/tick worse as you tighten one of the screws.....too tight and the fan slows down and/or TICKS, too loose and the fan slows down....(spindle getting in a bind).
    There is a point where the fan will turn fastest and the sound will disappear magically. You'll see what I'm talking about once you're in there adjusting the screws to find that perfect point.
    #6 re-assemble and enjoy!
    I hope this helps a few people that have this ANNOYING sound!
    sometimes it just takes getting pissed off.....damn delphi.
    Why didn't they have metal stoppers under those screws or not have the spindle held still by a moveable plate......argh....
    I think that over time, those screws are backing out at different rates, which makes the spindle bind up and/or ticking sound occur......
    __________________
  17. Dec 28, 2009 at 5:30 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Alright just went outside and did this. Takes a little playing around with the screws to get it just right. Now I cant hear my fan!!! Just be careful if you try this not to strip your screws. I took a few pictures if I get around to it tonight Ill try to get em up. Thanks TacoNut!!!!
  18. Jan 7, 2010 at 2:56 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Well I took it to the dealer, they said it had debris in it, and they cleaned it out. but soon after I left it started again, so I am going back tomorrow and complain some more, hopefully I will get some good answers tomorrow, I will be working with the service mgr, and he has always treated me well.
    Also can you believe the astronomical price that Toyota charge for the cabin air filter? 37 bucks, give me a break. I got mine on ebay for under 10 bucks shipped to the door.
  19. Jan 13, 2010 at 6:12 AM
    Gringo
    Gringo Active Member
    MA
    '10 2wd AC SR5
    HID's, extra D-rings
    Will this adjustment eliminate the crickets? Last night my fan started chirping on the medium setting that I use the most, and it's getting worse fast (at 1,900 miles I guess the truck's getting old!). Don't know if it's because of the really cold temps or if it's starting to wear in, but it's annoying. Anyone killed their crickets successfully?
  20. Jan 13, 2010 at 6:45 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Please yeah post the pictures, I need to this too.
