A/C not cold anymore.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by daivs, Jun 2, 2015.
  1. Jun 2, 2015 at 2:04 PM
    daivs
    daivs [OP] Active Member
    3" front lift, 2" rear lift, SPidertrax wheel spacers
    So just recently my a/c (on max a/c) has become quite weak. It's still cool, but no where as cold as it was a few weeks ago. Normally i have to turn it down because of it being too cold.
    Should i try to do the a/c recharge stuff ive seen?
    Also, normally i get a puddle under my car after parking using the A/c.. now there isn't one, could this be a blocked drainage tube?
    2012 dclb prerunner - 27,000 miles. Shouldnt have issues with the a/c already...
  2. Jun 2, 2015 at 2:32 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    2012 take it to dealer for free if they cover it. If not hook up gauges and check the gas. If it's not removing heat due to lost freon it wouldn't cause the condensation under the truck but it won't hurt to check. Is the compressor running consistent or kicking on and off or not running at all?
  3. Jun 2, 2015 at 2:59 PM
    daivs
    Is the condenser that hissing noise?
  4. Jun 2, 2015 at 4:13 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    If you're getting a constant hissing noise in the cab, after the ac comes on, it's almost certainly a low charge (possible leak) if the compressor is not cycling on/off (running constantly or nearly constantly). It should cycle after it's been on awhile to keep from over-cooling the system an you'll notice slight engine speed changes when the compressor engages and disengages.
    Get it in to dealer b/f the 3/36 is over. In my '12 prerunner i get a temporary hissing noise as the refrigerant charge builds (about 3 seconds) and then it's cold.
    If you're getting no drip from the drainage tube on the pavement, the evaporator is definitely not producing the cooling needed. It's unlikely the drainage tube is blocked.
    Dealer should check for leaks and properly charge it. There is a possibility of a blocked/defective expansion valve too.
    Additional information: if the 3/36 is over and you don't want to pay the dealer, you may want to try the recharge kits at Walmart. I've used them and they work well, but you'll have to be familiar with the procedures of charging a system.
  5. Jun 2, 2015 at 4:31 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Try a recharge it's cheap and 80% of the time it solves the problem. At least for me.
  6. Jun 2, 2015 at 5:10 PM
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    had the same issue brought it into the dealer they found a leak in one of my hard lines replaced the line recharged it and charged me a pretty penny..
  7. Jun 2, 2015 at 5:19 PM
    daivs
    dang.. around how much? ill try a recharge since i have it laying around... but if it goes down again, then im sure there's a leak...
  8. Jun 2, 2015 at 5:56 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Shouldnt have to worry about cost since you are within the 3 year 36K warranty.
  9. Jun 2, 2015 at 6:14 PM
    daivs
    thank you for that.. what documentation do i need to take to the toyota service center?
  10. Jun 2, 2015 at 6:55 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Don't know since I bought mine new and in 35 years behind the wheel its the only one new enough to have a warranty. I assume just go to any Toyota dealer and ask them to take a look under warranty. Then they check your odometer and say "okay." Before ya go make sure that's all you want them to loom at including any TSBs. There is a TSB thread here in the second gen forum.
  11. Jun 2, 2015 at 6:57 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    As long as you aren't past the 3/36 they will have that info so nothing other than explaining the issue
  12. Jun 2, 2015 at 7:09 PM
    R1D2
    R1D2 The FEDS are coming, the FEDS are coming!!
    "KarVer"
    Atlantis
    01' Tacoma
    Heard 21oz from the can. Mine is recommended. If you have some laying around imo try it. If it doesnt work an its in warranty take it to a dealer. They are likely to get the vin, ask a question or two. An have ya wait.
    An I had a drain plug clogged, it left "water" in the passenger floor board.
  13. Jun 2, 2015 at 7:21 PM
    daivs
    ya that's the first thing i checked was water on passenger side, but it was dry... so freon first, then warranty option. thanks guys
  14. Jun 2, 2015 at 7:48 PM
    R1D2
    "KarVer"
    Atlantis
    01' Tacoma
    Your welcome, come back here will ya, an let us know the gist of it, if the can worked or if something needed fixed at the dealership.
    Could be it was undercharged, or a factory issue that needs known.
  15. Jun 3, 2015 at 12:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is under warranty take it to them and let them do it right esp if you want it to work properly.
    If it is low where did the coolant go? It doesn't just disappear. Low coolant in the AC means that you have a leak that needs to be addressed.
    These " DIY " kits are crap and you may do more harm than good. I know they make it look so simple on the advertising, but an over charge is just as bad as an undercharge.
  16. Jun 3, 2015 at 2:08 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Check fuses
