A/C not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tifosi27, Oct 22, 2018.
  1. Oct 22, 2018 at 8:05 PM
    tifosi27
    tifosi27 [OP] Member
    AP
    2010 xtra Cab
    Stereo, K&N intake
    Was driving home from the mountains last night and the recirculate wouldn't work. When I had the A/C on and pushed recirculate the A/C stopped blowing. Pushed it again and fresh air worked. Today the A/C doesn't work at all. I heard the fan clutch engage but no air blowing through. Is this the fan relay?
  2. Oct 22, 2018 at 8:11 PM
    MK_Ultra
    MK_Ultra Well-Known Member
    2012 basic DCLB
    not much
    low charge on the ac, had the same issue a few months back clutch would spin ac would say its on but nothing coming out. Recharged it and was blowing at a nice 34 degrees.
  3. Oct 22, 2018 at 8:20 PM
    tifosi27
    AP
    2010 xtra Cab
    Stereo, K&N intake
    Got it. Question though. WOuldn't the fan motor be on blowing hot air? If I don't have a leak in the system how will it lose charge?
    Thanks
  4. Oct 22, 2018 at 8:25 PM
    MK_Ultra
    2012 basic DCLB
    not much
    Mine a 2012 seemed to lose it over time I had the dealer do a test to see if it was leaking and they found no leaks. the air wasn't hot just what ever the temp was coming through the cab.
  5. Oct 23, 2018 at 12:51 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no clutch on the blower ( fan ).
    Is the clutch on the compressor working at all?
    Does the AC LED indicate it is in AC Mode?
    Is air coming out of the vents?
    Is the blower running?
    It seems you have the burned connector on the blower motor problem which can be repaired cheap.
    Blower connectors:
    Look at both connectors on the motor. I'd be willing to bet one or both of them are burned.
    Check the plug that goes to the resistor connection and the white plug that goes to the motor? If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    You may also have a burned resistor connector and may need these:
    Plug Number 82141-04M40
    Resistor Number 87138-04052
    TacomaMike37 and Biscuits like this.
  6. Oct 23, 2018 at 1:14 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Excellent. Saved for future reference.
  7. Oct 23, 2018 at 6:30 AM
    tifosi27
    AP
    2010 xtra Cab
    Stereo, K&N intake
    Jimmy, thanks for this. I can hear the compressor engage when I push the AC button.
    Yes, the LED lights up on AC and recirculate.
    No , air isn't blowing through the vents and I can't her the blower/fan blowing.
    Thanks
  8. Oct 25, 2018 at 6:15 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Check the connectors on the fan blower.
  9. Oct 26, 2018 at 8:03 PM
    cleats50
    cleats50 Well-Known Member
    chris
    Tacoma 2007 TRD
    air intake push bar running boards
    Thankfully it is not the compressor. Usually the resistor.
  10. Nov 17, 2018 at 12:29 PM
    tifosi27
    AP
    2010 xtra Cab
    Stereo, K&N intake
    Okay, so here's a new question for the same problem. The fan sometimes works and sometimes it doesn't. Checked the motor (under the dash, behind glove compartment) and fan spins freely. Turned the fan on after and it spun. Now the fan works intermittently. Doesn't spin as well as it previously did. Is that the motor wearing out? Or a faulty or weak connection?
    Thanks for the replies.
  11. Nov 17, 2018 at 1:17 PM
    cleats50
    chris
    Tacoma 2007 TRD
    I would still say it's the resistor but I'm a retired foot doc. lol.
