A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Jan 23, 2014 at 8:12 PM
    #241
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You can't, it's a good part of the design. I like that my window shield and side windows stay clear with the floor setting. Why is it bad?
  2. Feb 1, 2014 at 11:13 AM
    #242
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Another satisfied customer! Works perfectly on my 13 SR5 following the diagram on page 8. Also did the "eliminate auto AC when turning the knob all the way to cold".
  3. Feb 1, 2014 at 11:17 AM
    #243
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Lol. Why would you want to disable AC coming on with defrost?
  4. Feb 1, 2014 at 11:49 AM
    #244
    worthywads
    I guess you didn't read any of the thread, lots of reasons discussed.
  5. Feb 1, 2014 at 12:12 PM
    #245
    Spoonman
    Jamie
    Alberta
    I did not read it at all.
    Unless there is something I'm forgetting, there's no advantage. The AC is on with defrost to dry out the air as it passes through the evaporator. And your AC your won't go on below about -10*c anyway. Your gas milage won't be improved enough to notice. What's the alleged advantage :|
  6. Feb 1, 2014 at 12:44 PM
    #246
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Reducing engine draw can only improve mileage - maybe not enough to notice but it does. Maybe it doesn't do anything but at least I can choose if I want it on. Back in the day most cars didn't come with AC and everyone did just fine using defrost without the AC. If the windshield starts to fog a bit, I'll hit the button to kick on the AC. I've been driving longer than many commentators have been alive and after owning over 10 vehicles find having manual control to be better for me versus the vehicle choosing what comes on when for me. Anyway, the mod works on a '13 model. I just don't understand why a very good percentage of the threads on here turn into discussion as to why "you don't know what you're talking about". If you don't like the mod, skip over the thread - easy enough...
  7. Feb 1, 2014 at 12:48 PM
    #247
    Spoonman
    Jamie
    Alberta
    I just love to hear the logic behind pointless mods.
    If you've been around that long, shouldn't you know that old saying "if it ain't broke don't fix it". Or that "modding" shit that doesn't need to be modified, is more likely to cause you problems down the road?
  8. Feb 1, 2014 at 12:54 PM
    #248
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I look at it like this: it was broke.. I just fixed it. As with any mod, "I am my own warranty station" and this was an instance that I believe needed to be modded. Here's another old saying "to each his own" and maybe another "If you don't have anything nice to say then don't say anything". Enough.
    Back to the original intent of this post. Thanks to the OP for figuring out the mod.
  9. Feb 1, 2014 at 1:58 PM
    #249
    Spoonman
    Jamie
    Alberta
    Where was I not "nice"? Have I offended you?
  10. Feb 1, 2014 at 2:13 PM
    #250
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    you've been condescending and dismissive.
    you haven't read the thread and you come spouting the worthlessness of the mod. Just because you don't find it useful, doesn't mean others won't
    I did this mod because I like to drive with air blowing through the defrost but only want a/c when I want it. I want to control the truck, not it telling me when to have the a/c on.
  11. Feb 1, 2014 at 2:51 PM
    #251
    Spoonman
    Jamie
    Alberta
  12. Feb 1, 2014 at 6:47 PM
    #252
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Running the compressor to remove moisture from air that has very little moisture is silly, made especially so when one considers that heating the air has the same effect while simultaneously keeping the passengers warm. With this mod I have the choice (imagine that) to engage the compressor the three days of the winter I may actually need it.
    You may also want to read what the mod consists of before shitting on it. If you had, you would have discovered that it is non-destructive and can be reversed in less than 5 minutes.
  13. Feb 1, 2014 at 7:17 PM
    #253
    Spoonman
    Jamie
    Alberta
    Thanks for the neg rep tough guy :thumbsup:
  14. Feb 1, 2014 at 7:27 PM
    #254
    worthywads
    You earned it. :rofl:
  15. Feb 1, 2014 at 7:30 PM
    #255
    Spoonman
    Jamie
    Alberta
    I do what I can.
  16. Feb 1, 2014 at 8:43 PM
    #256
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Exactly, I have read all the posts & from the first, I couldn't understand what was to be accomplished, to each their own, I'm not sure I would call this a mod, I guess it doesn't hurt anything, but I don't see any advantage. jmop
  17. Feb 1, 2014 at 9:02 PM
    #257
    worthywads
    Many manufacturers including Honda let you turn the a/c on or off if you choose, instead of forcing you to like Toyota. That is because there is an advantage to not running the a/c when it isn't needed. Simple as that.
    They still make cars without a/c, and they do just fine defrosting.
  18. Feb 1, 2014 at 9:12 PM
    #258
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I can see the merit of this mod if you used the defroster...I haven't had a defroster on in my vehicles for the last 20 yrs or so (other than to turn it on to see if it still works)...not much need for it around here. There just isn't any moisture usually in the air to fog up the windshield, and no frost on the windshield in the morning under a carport.
    Would use it if needed, and probably would do this mod if I did.
    I wonder what happened to my photo of Orbit...?
  19. Feb 1, 2014 at 9:16 PM
    #259
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You never use either of the top 2 settings ?
  20. Feb 1, 2014 at 9:17 PM
    #260
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    No.
