A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Feb 1, 2014 at 9:19 PM
    #261
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Huh , interesting , mine never leaves those 2 haha , but I think I've only used AC once in 5 years
  2. Feb 1, 2014 at 9:23 PM
    #262
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Difference in climates, I guess. I use the floor vent for heat in the winter, and the dash vent for fresh air in the summer, and occasionally a/c on really hot days.
  3. Feb 2, 2014 at 6:33 AM
    #263
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    I have owned many Honda's & still own one, I think it works the same as the Toyota, (Not sure) I will check the next time I drive it. Maybe this mod is good depending on where you live, I can see in a dry climate where turning it off might be a good idea, but I just don't see any big advantage, but again to each their own, When I do something I don't ask permission & neither should anyone else. I do get nervous when messing with the wiring on a vehicle, Toyota has some pretty good engineers & sometimes things that don't make sense to me makes a lot of sense to them. As to cars without air working good, well I am an older guy & remember having a lot of vehicles without air, & no, they didn't work just fine, they worked, not good, but they did work. jmop
  4. Feb 2, 2014 at 8:38 AM
    #264
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    My wife's Honda can be turned on/off while in defrost. She prefers to keep in on defrost 100% of the time because it doesn't bother her dry eyes that way. If she couldn't turn off the a/c it would be running 100% of the time.
    I forgot it did take a sequence to make it work that way. At least Honda allowed owners a way to do it, without cutting any wires.
    From Honda owners manual:
    To deactivate automatic a/c feature:
    1. Turn vehicle[​IMG] off.
    2. Turn fan knob off.
    3. Turn temperature knob all the way to the left (blue area..
    4. Turn vent knob to panel only setting (next to max. a/c..
    5. Hold down both air re-circulation button and a/c button while turning the key to the "run" position (one short of starting..
    6. Continue holding for 7 seconds until air re-circulation button stops flashing.
    7. Anytime you engage defrost or defrost/heat positions, the A/C will automatically turn on. Press the A/C button to turn the A/C compressor OFF, the light will go out.
    Since the wife leaves it on defrost all the time, it stays a/c off and she can turn it one if needed. If she switched to any other setting and then switches back to defrost the a/c light comes on and she can just hit the a/c button to cancel a/c.
    I guess defrost effectiveness is different depending on climate. Humid foggy climate may work well with a/c on, but living in WI, IA, CO, I've never had issue with poor defrosting. I'm an older guy too and can't recall ever thinking the non-a/c equipped vehicle wasn't defrosting well. Heavy rain and the right temperature and the a/c goes on.
  5. Feb 2, 2014 at 9:17 AM
    #265
    DocD
    Mn./SoCal
    09 access cab
    Well said, I will try that on my Honda. Well, not to argue, but growing up in Wisconsin/Minnesota I had many a cold damp morning & I would hit the defroster & the inside windows of the car would instantly be covered with dew/mist (can't come up with a word) that had to be wiped off, & took forever to clear. there were many times when I had to pull over & wipe the windows. jmop
  6. Feb 2, 2014 at 9:21 AM
    #266
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Thanks for the write up. Worked great on my '12!
  7. Feb 2, 2014 at 9:44 AM
    #267
    worthywads
    I've probably needed a/c on driving between Albert Lea and La Crosse, for whatever reason it seems like every time I drive back to La Crosse as soon as I reach Austin/Albert Lea the weather goes to shit either torrential rains or blizzard conditions?
  8. Feb 4, 2014 at 7:03 AM
    #268
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    AND that's the point of this mod. It gives you the choice IF YOU NEED IT.
  9. Feb 4, 2014 at 8:06 AM
    #269
    DocD
    Mn./SoCal
    09 access cab
    Agree, everyone should do as they want, I was just stating an opinion, on some of these mods I am not sure If I want to take the advise of someone on the internet, (NOT saying they do not know what they are doing) but this is the INTERNET, electrical issues being of most important, new vehicles are reliant on electronic analysis, &sometime the cutting of wires can upset this process, & I would worry about possible compressor issues, the benefit of this mod is so small I would not consider it, HOWEVER!!!! should anyone want to I say GO FOR IT, This is just my opinion, everyone should do as they want!!! jmop
  10. Feb 4, 2014 at 9:17 AM
    #270
    merkman
    merkman Well-Known Member
    Etna, NH
    2012 green
    So I need a little clarity. If the AC light is NOT on, is the compressor still engaged with defrost? OR is the light the realtime on/off indicator? Because my light only comes on when the heat dial is all the way to cool, unless I push the button!
  11. Feb 4, 2014 at 9:23 AM
    #271
    YOTA LOVER
    NH
    The A/C indicator will not illuminate when the selector is set to defrost windshield (on my 2011 anyway). However, if you let the truck idle you can feel the A/C engage and disengage as it cycles.
  12. Feb 4, 2014 at 10:05 AM
    #272
    merkman
    Etna, NH
    2012 green
    As I suspected. I do feel that slight shudder when I put it onto defrost, just wasn't sure, thanks... Might consider the mod!
  13. Feb 4, 2014 at 2:02 PM
    #273
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    This. I've never seen anything stating a temp at which it would not engage for my 2006. If it's below freezing, I want all the heat I can get before I leave for work. There's a noticeable difference in the temperature of the air coming out the vents in defrost mode vs feet only so I know the AC is running.
    I've also noticed the slight engine lag while driving up a hill with the defrost or normal AC mode on. So it would be beneficial to turn it off. I just use feet only mode 99% of the time to get around that.
    My nissan is more annoying. If you turn to either windshield mode it turns on the AC like this, but changing modes doesn't turn it back off. We have to turn the fan off then back on to turn the AC off. :rolleyes:
  14. Feb 24, 2014 at 12:01 PM
    #274
    hogges
    hogges Active Member
    To vssman: How did you disable the A/C on when temp dial is in cold position? I see one mechanical solution on the forum (restricting how far the knob can be turned) but am wondering if there is an electrical solution to this. I want to do both mods, as I find both the defrost A/C and the auto-on feature very annoying. '11 SR5
  15. Feb 24, 2014 at 4:04 PM
    #275
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  16. Feb 25, 2014 at 3:45 PM
    #276
    hogges
    Thanks! Did both mods this evening, in about 10 minutes each, not counting the time to buy a small butane powered soldering iron at Radio Shack (works great). Wish I had done these mods years ago. No more unwanted A/C air.
    BTW: I used the wire splicing technique described here: http://www.backinblackgp.com/Tap_And_Splice.htm
  17. Mar 13, 2014 at 12:31 PM
    #277
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I noticed this as well. I did the mod exactly as described a few weeks ago on my 2010 but today I popped the hood and watched the AC compressor cycle on defrost regardless of whether or not the AC button was activated. It seems like all the mod accomplishes is that it allows you to turn the light on the button on and off but the AC remains on all the time with defrost
  18. Mar 13, 2014 at 2:11 PM
    #278
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I can tell you it works on a '13. I purposely watched the ac compressor stop spinning when the button was pressed to turn off the light while in defrost. Pressing the button again to turn the light on turned the compressor back on. I also made sure the compressor stayed off when the light was off with it in defrost just to make sure it wasn't a case of the compressor cycling on/off. Could you either have wired something wrong or does the '10 have a different harnes (I don't recall exactly what years use what diagram)?
  19. Mar 13, 2014 at 4:32 PM
    #279
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    And the 2009+ fix (post 157) works on a 2014 DC also. Funny, wife's VW Beetle requires a manual push of AC button with defrost, but as early as my old '89 Ranger, the AC came on with defrost, without AC light notification. AC defrost is often needed in the damp PacNW, but not always. Easy enough to push the button, if needed. Thanks!
  20. Mar 13, 2014 at 6:24 PM
    #280
    plurpimpin
    PDX
    disconnect green and splice into pink is what I did, looks just like the instructions on page 8
