A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Mar 20, 2014 at 10:36 AM
    #281
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    For some reason when I went and checked if the mod was working today it worked perfectly... maybe I accidentally had it on max AC last time or something.
  2. May 3, 2014 at 9:41 AM
    #282
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Does anybody know if this works or if there is a way todo this on a first gen? I apologize if this has already been asked here
  3. May 3, 2014 at 3:06 PM
    #283
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Really liked my old Mazda B2600 better. One knob to direct output, 1 to switch outside air vs recirculate, temp dial only controlled heat, and an a/c on off switch.
    Full Control.
  4. Oct 8, 2014 at 2:31 PM
    #284
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    It had worked on my old '12 a while back. Just did it for the '14. Works great!
  5. Nov 7, 2014 at 7:06 PM
    #285
    seafur
    seafur Well-Known Member
    Pacific Northwest
    2014 DCSB MT TRD OR
    Sprinter bed tiedowns, Aux fuse box, AIO key, 3-way canopy light switch, 12V bed outlet, Dual Battery AGM G35, Viair OBA, Uni-filter mod
    Did this mod tonight. Hardest part on a pre 09 would be getting the pin out of the connector. You could use a "greenie" or Xcelite R3322 to push the pin out from the crimped part that was behind the white plastic clip.
    Hardest part for a 09+ owner would be to read the big red bold text about 2009+ owners... I used a red 3M Scotchlok IDC splice to tie the green wire to the pink.
    I live in an area where the AC is sometimes needed with defrost and other times it's not. Toyota should take a lesson from Honda and turn the AC button light on when defrost turns on the AC and allow the driver to turn off AC by pressing the button even when in defrost.
  6. Nov 9, 2014 at 8:55 AM
    #286
    Pigpen
    Dan
    Northwest Montana
    I wish I had found this thread a week ago. We're about to go into single digits here...
  7. Nov 10, 2014 at 8:18 PM
    #287
    seafur
    Pacific Northwest
    2014 DCSB MT TRD OR
    I have a 2014 DC and tied the green wire to the pink wire, verified 12v on the green wire by piercing the insulation and measuring voltage. However, now AC won't come on with the AC button pressed. The indicator on the button doesn't come on but the engine RPM doesn't increase, I don't hear the compressor clutch and it took forever to defog tonight on a cold wet night. Any ideas?
  8. Nov 11, 2014 at 5:48 AM
    #288
    hogges
    hogges Active Member
    My A/C did not work when I first needed it, many weeks after doing this mod. It turned out that the A/C fuse in the engine compartment needed a little push as it was not seated all the way. I know, this seems unlikely to co-inside with what you were doing, but it's easy to check.
  9. Nov 11, 2014 at 2:37 PM
    #289
    seafur
    Pacific Northwest
    2014 DCSB MT TRD OR
    I checked the fuse and it was good, figured somehow I could've blown it during the change but nope. Reseated it and still no AC. Verified 12v DC on the tab of the scotchlock and verified 12v DC again on the green wire. I'm sort of stumped now.
  10. Nov 11, 2014 at 3:40 PM
    #290
    seafur
    Pacific Northwest
    2014 DCSB MT TRD OR
    I verified 12v on the pink wire, removed my scotchlock and solder spliced the green wire to the pink wire. I can see the AC clutch engaging when the AC button is enabled but sitting at idle it turns on/off/on with the AC button on. I guess it modulates based on something, outside temp? Seems to be working now I'll see how the defog is in the morning.
  11. Nov 11, 2014 at 4:43 PM
    #291
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The AC clutch will cycle on and off as needed automatically as it controls the system pressure. When you first press the button, the clutch should engage and then it'll cycle on and off as needed.
  12. Aug 25, 2015 at 6:02 AM
    #292
    JD Hog
    JD Hog 2014 TRD
    JD
    Eastern KY
    2014 Tacoma TRD
    3 inch lift Smoked LED cab lights Compass / temp. Mirror Dark tinted windows 285-75-16s 1.25 spiderTrax spacers Debadged
    Just did mod on 2014 Tacoma seems like it will work fine. Great mod. Only thing I noticed is the recirculate cab air button didn't work now. Don't know that I need it Thanks
  13. Sep 12, 2015 at 5:55 PM
    #293
    BlueDot
    BlueDot Member
    Dave
    Virginia
    '14 Access Cab SR5
    Just did this on a 2014 access cab.
    Thanks for 'fixing' one of the few things I didn't like about my new truck.
    dc
  14. Sep 13, 2015 at 5:06 PM
    #294
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Something interesting is last night I turned on my fan, slow speed first click,
    went to defrost/foot and I can turn my A/C off? at least the light wasn't on.
    I also went to defrost only and it still didn't come on.
    Went back to dashboard vents and then back to defrost and it turned A/C on
    automatically however I could turn the A/C on and off at will.
    Now in defrost modes I COULD NOT engage recirc...:annoyed:
    Did they maybe change something for 2015?
  15. Nov 20, 2015 at 1:45 AM
    #295
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    I'll have to do this.
  16. Dec 17, 2015 at 12:42 AM
    #296
    jung4x4
    jung4x4 New Member
    What a concept, huh? I'm sick of vehicles "thinking" for the driver. Like my dad always said, if you make something idiot proof they'll make a better idiot!
    I wasn't sure if my truck was doing this (since the AC light wasn't on) until I left it idling while I was shoveling snow the other day and I heard the AC turning off and on. This mod gets done tomorrow.
    jim1234 likes this.
  17. Dec 17, 2015 at 12:58 AM
    #297
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    A/C helps witb defrosting , its a simple concept
  18. Dec 17, 2015 at 1:19 AM
    #298
    jung4x4
    jung4x4 New Member
    I understand that. And when the windows start to fog up inside I'll turn on the AC. When it goes away I'll turn it back off and enjoy not wasting fuel and the slight HP increase.
    I know what my vehicle needs. I don't need it doing things for me.
    jim1234 likes this.
  19. Mar 27, 2016 at 12:19 PM
    #299
    jim1234
    jim1234 Active Member
    jim
    pocatello Id.
    2009 tacoma 4 cyl base
    intermitent wiper review mirror Cruise control 4cyl manuel 09
    Thank you, I have been wondering how to do this for a while. Thepics help me find the damn thing.
  20. Aug 26, 2016 at 10:19 PM
    #300
    Gunerbey
    Gunerbey Well-Known Member
    2015 Tacoma
    The ac is on to dry the air. It removes moisture from the air going into your cab to help with drying up your Windows if they're just foggy and not icy. Without the ac on you can cause your Windows to fog up in certain situations. It really shouldn't be on all the time, it's a huge waste. I generally cycle it on manually every 10 mins or so just to keep the condensation off the glass in the winter. Good mod. I will do this very soon.
