A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. May 17, 2017 at 7:26 PM
    #301
    jaystacks88
    jaystacks88 Member
    jay
    2006 dcsb super white
    So this mod did not work for me.. 06 tacoma solid green wire pulled out of harness and connected to pink wire. ac won't turn on. went back to stock config and still not working. 10amp fuse checked out good. Any insight on what else i could take a look at. (side note, the ac worked fine before attempting the mod).
  2. May 17, 2017 at 8:03 PM
    #302
    x250f23x
    x250f23x Going in dry
    Lake Elsinore
    Alright! At least one person understands the useful property of the AC to dehumidify!
    maineah likes this.
  3. May 24, 2017 at 2:31 AM
    #303
    Jeddo
    Jeddo Member
    2016 Tacoma off road access cab
    Bed mat, step, and lights, huskie mud flaps, Polk components, Alpine amp, 3 layer sound proofing, B&I blackwood dash kit, fluid film, led cabin and footwell lights, tail letters, window tint, IGGEE seat covers. More to come.
    Been thinking of trying this mod on my "16" ac, mostly because I did the AC drain hose mod and I am glad I did. When I stop the truck there is what I would call a "large puddle" that otherwise would be soaking the frame and the water can wind up freezing on the garage floor. Seeing large amounts of fluid under my vehicle always gets my attention. My preferred setting is defrost and floor. Wondering if anyone has done this on gen 3. Thanks.
  4. May 25, 2017 at 5:55 AM
    #304
    jaystacks88
    jaystacks88 Member
    jay
    troubleshooting today fuses look good but i have no power to any of the wires on that harness.. I've checked the "a/c" fuse in the engine bay is there any other combo fuse that i should check?
  5. Sep 24, 2017 at 6:04 AM
    #305
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    Just tried the green wire only on 2014 6cyl. Did not work. Ac on all time. Do i need to do the green to pink wire as on page 8 of this forum?
  6. Nov 12, 2017 at 12:26 PM
    #306
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    So I “did” this today and ended up breaking the wire off instead of pulling it out . Now what ? How do I repair the connector ? What kinda connector is in the plastic piece that goes on the end of the wire ?
    If I get it out can I repair the wire using the same connector ?
    I mean it’s disconnected for sure now lol
  7. Oct 8, 2019 at 12:40 PM
    #307
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
  8. Oct 8, 2019 at 2:24 PM
    #308
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A solution in search of a problem.
    Icarus II likes this.
  9. Oct 16, 2019 at 3:41 PM
    #309
    Gunerbey
    Gunerbey Well-Known Member
    2015 Tacoma
    Great mod, worked for me. Save some power and a mountain of fuel in the winter.
    DocD likes this.
  10. Oct 16, 2019 at 4:37 PM
    #310
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    This mod will make my 09 work like my 88 Toy 4x4 did.
  11. Nov 6, 2021 at 4:11 PM
    #311
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    Ok so reviving an old thread, hopefully. So either I missed it in 16 pages or it wasn’t discussed either way does this mod also stop the recirculating button from automatically shutting off when the the ambient outside temperature drops to 50% or below ? If not has anyone figured out a way to do that thanks for any help.
  12. Nov 6, 2021 at 4:20 PM
    #312
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It will allow you to use recirc with defrost in aditition to not forcing the A/C to run in defrost mode if that's what your asking.
  13. Nov 6, 2021 at 4:29 PM
    #313
    Turbo-Taco
    Randy
    Portland, Oregon
    Thanks but no thats not what I was asking. On my truck, 2013 Tacoma, when the outside air drops below 50% the recirculating air button automatically shuts itself off. To keep it on you then need to press and hold it longer than 2 seconds to have it stay on. I am wanting to know if this mod eliminates the recirculating air button from doing that.
  14. Nov 6, 2021 at 4:59 PM
    #314
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's interesting, my 14 has never done that even before I did the mods to the A/C.:notsure:
    I did the mods because I didn't like that it forced the A/C on in defrost and when the temp knob was turned all the way to the left.
  15. Nov 6, 2021 at 5:12 PM
    #315
    Turbo-Taco
    Randy
    Portland, Oregon
    Not sure about your manual but on page 247 of my owners manual it explained this. Not a huge deal but just curious if this mod disabled this feature.857D1040-A02C-41C2-9011-4884FE246A0F.jpg
    Biscuits likes this.
  16. Nov 6, 2021 at 5:22 PM
    #316
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nope I just looked and mine has no such paragraph, they must have changed it in the 14 MY.
  17. Nov 6, 2021 at 5:27 PM
    #317
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hum, AC on or fog over widows? I like to see where I'm going. Wonder how many GM, Ford, Dodge, Nissan, Tacoma, Tundra, ETC truck owners are dealing with this? They all run the AC on defrost for good reason. AC units are excellent dehumidifiers that's why they drip water on the ground.
    Greenbean and Icarus II like this.
  18. Nov 6, 2021 at 5:31 PM
    #318
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's what I have an A/C button for, if I want it on I'll turn it on I don't need the truck to tell me when I can and can't have it on. Besides the heater heat's up alot faster when it's not fighting with the A/C.
    raskal likes this.
  19. Nov 6, 2021 at 5:33 PM
    #319
    Turbo-Taco
    Randy
    Portland, Oregon
    Thats not what I’m asking or getting at here it was supposed to be a simple question regarding the function of what the recirculating air button will or won’t do after this specific mod, maybe for someone who has done the mod.
  20. Nov 6, 2021 at 6:08 PM
    #320
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    I have a 2013 and have done this mod, but I don't understand your question yet. If the outside air drops below 50% of what? Why does the cabin temp drop if it's on recirc?
