A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Jul 29, 2008 at 5:09 PM
    #41
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    You can try using the "feet only" zone setting. It does the front side vents near the windows, floor, and windshield. So it basically circulates air throughout the entire cab in addition to covering the windshield to kill fog. I leave mine set to that almost all the time since I don't like getting hit in the face with hot/cold air all the time either.
  2. Jul 29, 2008 at 8:17 PM
    #42
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    I made this mod a couple of days ago after doing the illuminated 4wd switch mod.
    I'm now fairly sure my '03 Corolla also has the same "feature". I always have it on windshield / floor mix. I'm sure some gas was wasted because of it as most of the 140K were put on in the desert.
    Bet my '04 Sienna does the same thing.
  3. Jul 30, 2008 at 4:57 AM
    #43
    piercedtiger
    Jon
    Southern Tier, NY
    :laugh: My 98 corolla still has the windshield/floor without AC. :D Only kicks the ac on in Windshield only mode unless I push the button. Kinda wish the truck was like that, but I'm too lazy to fix it. :D
    too much other crap to fix around here.... :frusty:
  4. Oct 12, 2008 at 6:20 PM
    #44
    capecodtim
    capecodtim New Member
    cape cod
    Thanks for the MOD a simple solution to a stupid design. I have heard that upper end Fords have an option to turn off the AC on the defroster, so I don't buy the "have to run the AC to exicise the the berings."
    Once again thanks
  5. Oct 12, 2008 at 6:25 PM
    #45
    hoosiertaco
    hoosiertaco Well-Known Member
    Welcome to TW! I did this mod the other day myself. Sure was easy.
    From what I've read, another purpose of this is to blow dehumidified air onto the winshield.
  6. Oct 12, 2008 at 6:34 PM
    #46
    lakewoodbilly
    Bill
    Lakewood, CO
    I did the mod last summer; I see a good need for dehumidified air as I live in a humid environment and am needing to turn on the a/c even with the heat on to defrost the windshield. I guess now that I understand the feature I like having it in a manual mode.
    I lived in Colorado (for 41 years)and I would have never needed this feature as it is dry there.
  7. Nov 16, 2008 at 5:36 PM
    #47
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    OK...this is my first post so be gentle. Recently bought a 2009 Tacoma DC Sport LB, V6/Auto. Great truck!! It replaced a 2004 Ford F350 6.0 Diesel CC that I hated to part with, but the way Ford treats its customers, I didnt dare own it out of warranty. So when the 5yr/75K warranty was almost xpired I knew it was time. It was a toss up between the Toyota and Nissan Frontier. Liked the Nissan but knew the Toyota would be the better of the two in terms of longevity and durability.
    Anyway got busy doing some cheap free mods as found here in the forum and am having a problem with the Defrost/AC Mod as outlined in the post. I had no problem locating and removing the D3 connector to the defroster servo but try as I might I could not remove the green wire from the connector. I have removed plenty of wires from connectors in the past but this one just wouldnt give in. I tryed all kinds of thin wires and clips and screwdrivers but it would not come out. Was about to give up...when the wire suddenly broke from the terminal. I guess from all the tuggging and pulling I must have weakened the copper wire to the point of breaking.
    Figured it was diconnected anyway which is what was needed...so I reconnected the connector and started the truck and guess what? The A/C still operates when in the Defrost mode. So I guess for the 09 models it may not be the solid green wire. Only thing is now the compressor seems to be working even in the other modes as well. ARGG!!!
    So now what do I do? I still cant get the terminal out of the connector to resplice it back to the green wire. And if and when I do correct it, does any one know which wire is the correct one for an 09 model? Sorry for the long post! Hope to keep posting in the future as I learn more about the truck!! Happy Trucking!!:)
  8. Dec 24, 2008 at 6:07 PM
    #48
    CtryBoyInMT
    CtryBoyInMT [OP] Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I needed a new host so I'm using this post to add the remaining pictures.
  9. Dec 27, 2008 at 1:28 PM
    #49
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Maybe this is simple, but I'm not seeing it. How do you remove the white retainer?
    Thanks,
    GA
    OK - got it. Not an easy little contraption, but I got it done. Very cool. Thanks CountryBoy.
  10. Dec 27, 2008 at 2:22 PM
    #50
    CtryBoyInMT
    I just used my pocket knife to pry it up slowly on each of the long sides of the retainer. You have to remove it straight up to get it out.
  11. Dec 27, 2008 at 5:34 PM
    #51
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Thanks CtryBoyInMT
    I did something similar to my 05 Dakota since they had the AC on in the defrost modes. I always drive around with defrost running...force of habit really! I wondered if my Tacoma was doing the same thing...now that I know I'll be doing this little mod ASAP.
  12. Dec 27, 2008 at 7:25 PM
    #52
    CtryBoyInMT
    Zuter,
    Proceed with caution as I have heard that 09's may be different. I cannot confirm nor deny is.
  13. Dec 30, 2008 at 8:56 AM
    #53
    stevedidj
    stevedidj Well-Known Member
    Another satisfied TW customer - thanks for the mod, dudes! In my 2008 4-cylinder SR5, I now have better performance (and presumably mileage) while blowing air on the windshield without the dang compressor on all the time . . . I can control the compressor the way I like. BTW FWIW, my 2000 Toyota Sienna does not automatically turn the compressor on with defrost. Nor has any other vehicle I've ever owned . . . "A/C linked defrost" or whatever it's called was probably designed to alleviate a large number of service complaints from people who don't know how to defrost a windshield . . . my guess at least!
  14. Jan 5, 2009 at 12:20 PM
    #54
    Krp2nite
    Krp2nite Well-Known Member
    Thanks, this worked great. I prefer to choose if the A/C is on or not and have been wondering how to fix this--makes freeing up a little extra power for highway ramps easy without having to turn off the defroster. Thanks a ton
  15. Jan 6, 2009 at 6:52 PM
    #55
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    you should be on are you smarter than a 5th grader
  16. Jan 9, 2009 at 8:02 PM
    #56
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Thanks for figuring this out.
    This A/C running all the time has been driving me crazy since day one. (almost a year now)
    I noticed from the very first day while sitting at a light the tach would climb every now and then an I knew it was because some sort of load was taking place but I didn't have a clue as to what was causing it.
    About a month went by and I discovered by accident that it was tied into the defrost switch.
    Talked to my dealer and was told it was required by law which I figured was just the typical BS excuse.
    I started doing a search tonight and got linked here from another forum and registered so I could view the pics and also say Thanks.
    I'm going to do a mileage check and then give that A/C a vasectomy :D
    Thanks again :)
  17. Jan 11, 2009 at 11:57 AM
    #57
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    WTF!!! Is every ones Tacoma the same? My A/C does not turn on automatically with the defrost. :confused:
    Or at least the light does not come on the A/C button.
  18. Jan 11, 2009 at 11:59 AM
    #58
    gavonder
    Ct
    The light does not come on, but the compressor does.
    GA
  19. Jan 11, 2009 at 12:00 PM
    #59
    piercedtiger
    Jon
    Southern Tier, NY
    Light doesn't come on, but the system is on in a reduced power mode, so to speak.
  20. Jan 11, 2009 at 12:03 PM
    #60
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ohhh!! So pretty much the A/C is "on" when I am in defrost mode and the light stays off? Hey pierced, did you do the map light mod yet?!?!:confused:
