A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Jan 11, 2009 at 3:08 PM
    #81
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay. Well I am messing with it right now. Just need to find some E-tape though!:eek:
  2. Jan 11, 2009 at 3:08 PM
    #82
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    From stewie on family guy. It cracked me up. :D
  3. Jan 11, 2009 at 3:46 PM
    #83
    hoosiertaco
    hoosiertaco Well-Known Member
    not familiar with automotive A/C, but I think it would be either on or off. Don't really matter with this mod I guess, but to have partial cooling you would need some type of unloader, hot gas bypass or other componant. I would say the compressor is either on or off. Automotive is not my specialty, was just wondering.........
  4. Jan 11, 2009 at 3:56 PM
    #84
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay finally got it! Dang it took longer to put that air strut back then to actually do the friggin mod itself!!!:eek:
  5. Jan 11, 2009 at 4:05 PM
    #85
    piercedtiger
    Jon
    Southern Tier, NY
    Well, if you don't want to cool the air it wouldn't have to cycle on and off as much. If it's not kicking on as much then it's lower output mode, so to speak. Either way, it doesn't seem to lag the engine as much as when the button is pushed.
    Like an air compressor. It doesn't have to run and fill the tank as often if you're using a nailer as it does for a sander. Maybe it's not really a "low power" mode, but it's also not running full out.
    Edit:
    Oh, and wouldn't it be kinda counter productive to have the AC running full bore trying to cool the air when you have the heat on to dry the windshield?
  6. Jan 11, 2009 at 4:08 PM
    #86
    AK27
    AK27 Well-Known Member
    is this really make a big difference for fuel mileage?
  7. Jan 11, 2009 at 4:22 PM
    #87
    CtryBoyInMT
    CtryBoyInMT [OP] Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    You actually put the shock back on? I found it a pain in day to day life, so it's now a prized addition to the "New Owner" box you give the next owner when you sell it.
  8. Jan 11, 2009 at 4:31 PM
    #88
    piercedtiger
    Jon
    Southern Tier, NY
    I'm sure it affects it somehow, but not sure how much. You can feel that there's more load on the engine, but not quite the same amount as when you turn on the AC manually if that makes sense.
  9. Jan 11, 2009 at 4:37 PM
    #89
    DMZX
    DMZX Active Member
    E. Oregon
    2x4 Tacoma
    I had a Honda Civic that drove me crazy because the A/C would come on when the defrost was selected. It would burden the engine for a bit, and when you selected floor or panel, you had to turn the A/C off manually. :mad:
    I read your mod CB and immediately went out and applied it to my '07 Tacoma. Quick and easy.
    I love manual overrides. Thanks for posting that! :thumbsup:
  10. Jan 11, 2009 at 5:37 PM
    #90
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Haha nice! I was about to give up on it but I was like screw it! I'm going to get it no matter what!! It would have bugged the crap out of me if I didn't!:eek:
  11. Jan 11, 2009 at 9:08 PM
    #91
    AK27
    i played with my defrost tonight, even had the wife listen and i could not tell any difference....maybe i am just deaf and blind (not to see a change in RPMs). i switched between settings, played with it in different gears and saw no change in rpms nor heard any changes in the engine.....nor did i notice any lag when i accelerated down the highway while switching it on.
  12. Jan 12, 2009 at 6:09 AM
    #92
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah to tell you the truth, I never really noticed any change either before I did the mod but then again I didn't even think about the A/C kicking on with the defrost. But enough people says it does so I believe them so that's why I went ahead and just did the mod. Easy mod to do anyways so it all worked out!:D
  13. Jan 12, 2009 at 6:48 AM
    #93
    DMZX
    DMZX Active Member
    E. Oregon
    2x4 Tacoma
    Pre mod, I could always hear the compressor when I switched to DF at idle.
    Post mod, I no longer hear it.
  14. Jan 12, 2009 at 7:00 AM
    #94
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmm. I might have to put it back to stock and try it to see if I hear the compressor turn on.
  15. Jan 12, 2009 at 2:07 PM
    #95
    hoosiertaco
    For anyone that wants to know for sure, look at the front of the compressor and see if the clutch kicks in and spins. Turn it off and on and you will see the difference. A helper is good to have, to run the controls for you while you are looking.
  16. Jan 12, 2009 at 2:15 PM
    #96
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    My 06 ijust have to push the ac button and it goes off.. i guess i'm good. i didn't relize that on my other o6 either:confused:
  17. Jan 12, 2009 at 4:13 PM
    #97
    hoosiertaco
    remember the light won't be on when you are in defrost mode, yet the A/C will still be on. Check like in my post above to see if the A/C is on or not.
  18. Jan 12, 2009 at 6:20 PM
    #98
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Out of curiosity, has anyone done this mod on an '09 yet?
  19. Jan 13, 2009 at 7:04 PM
    #99
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    yeah i'll check into that.
  20. Jan 15, 2009 at 8:31 AM
    #100
    confuzzed2
    confuzzed2 Member
    Colorado Springs, CO
    07 PreRunner
    Completed the mod last night...stupid wire was a pain to get out. No doubt about a noticable difference with A/C coming on pre-mod and A/C not coming on post-mod. Checked it in the garage after modding it and on the road during an errand run, well pleased with the results!! I've been avoiding the defrost setting as much as possible after noticing the A/C turning on. Sooo glad to have found this mod.
