A/C on with Defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Mar 26, 2008.
  1. Oct 30, 2009 at 8:01 AM
    #141
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Interesting.... So maybe they finally solved the problem of freezing even faster by having the AC on during the winter in defrost mode? :laugh:
  2. Nov 2, 2009 at 7:11 PM
    #142
    Beach Croc
    Beach Croc Member
    Virginia Beach
    Debadged 4x4 TRD On Road
    Truxedo LoPro Tonneau. Home made bedslide. Removed rear seats & added homemade carpeted 60/40 shelf.
    Checked my 09 (built Sep 08). When in defrost mode a/c is ON dispite what the manual says. Confirmed by feeling underhood a/c plumbing while in defrost mode and the a/c lines were cold. With defrost not selected, the a/c lines lost their cold and warmed up.
    FYI my connector is black with white in-layed plastic segment. Wire colors are white, green-striped, green & pink.
    I was unable to get green wire removed from connector to determine postive ("a/c off "in defrost) results or negative (does not turn a/c off or some other issue) result.
    Does anyone know how do this on 09+ models.
  3. Nov 3, 2009 at 3:38 AM
    #143
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    I think another member on here tried to remove a wire in the harness similar to the 05-08 mod and it messed up his HVAC. I would like to know how to disable it in my 09.
  4. Nov 6, 2009 at 8:59 AM
    #144
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Reading through the manual it appears that if you put the vents to your feet some air would also go to your windshield w/o A/C. I will have to test when i get home. My manual also says a/c not on with defrost, so maybe toyota just types what they feel like.
  5. Nov 6, 2009 at 9:05 AM
    #145
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Air to feet does not push enough air to defog your front window. And I confirm, a/c cycles on/off when in defrost mode.
  6. Nov 6, 2009 at 9:12 AM
    #146
    piercedtiger
    Jon
    Southern Tier, NY
    The "feet only" mode is exactly what I use to defrost the windshield. Turn the fan on high and not only does it defrost the windshield, but also the side windows as well. Not to mention it seems to warm the whole cab up a bit faster. I *never* use the windshield modes unless it's so humid out that I need to AC to keep the windows from fogging on the inside. :thumbsup:
  7. Nov 15, 2009 at 8:37 AM
    #147
    MIke20171
    MIke20171 New Member
    Northern Virginia
    07 Tacoma Acess Cab 4X4
    I had no luck intrying to remove the green wire from the plastic connector by using a pin or paperclip. It easily came out when I used small needle nose pliers to reach into the clip and grab on to the metal connector clip and pull it out from behind.
  8. Nov 23, 2009 at 7:05 PM
    #148
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Thanks for the mod.
    I just did it. The hard part is getting the green wire clip to come out of the connector. I tried everything for half an hour and finally gave up and cut the f'n wire.
  9. Nov 23, 2009 at 7:19 PM
    #149
    ElectronMan
    ElectronMan Well-Known Member
    Man this is an awesome mod. Something I hate about my 09 Tacoma. I like when the operator is able to take control of the HVAC system. Anyone have any luck yet with the 2009 wiring?
  10. Nov 24, 2009 at 1:26 PM
    #150
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Bump for 2010 trucks as well.
  11. Nov 24, 2009 at 1:40 PM
    #151
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Interesting post. I wont be doing it on mine though.
    I rarely use the defrost,
    A. because I park in the garage
    B. because I drive with the AC on in the winter with the heat which keeps ALL the windows from fogging without having to use the defrost. I don't really notice much of a difference in the temp of the air because the AC knows when to come on/off to keep the unit from freezing up.
    The reduction is gas mileage is not that noticeable to me personally.
    I have been doing this in all the vehicles I have driven, I learned it from my dad who has been doing it all his life. My girlfriend thought I was crazy when I told her to run the AC in the winter but she quickly changed her mind when she realized she didnt have to use the defroster, and had to have a leaking AC line replaced two summers in a row due to a bad seal from not running the AC all winter.
    You should run your AC often to keep the seals lubed as someone already stated
  12. Dec 16, 2009 at 1:26 PM
    #152
    zee
    zee New Member
    Onder
    NorthEast
    20102wd
    Why does the recirc button kick out shortly after you
    turn it on? Even if the fan isnt on and it is one floor only
    position?
    2010 4cyl AC Base model
  13. Dec 16, 2009 at 1:51 PM
    #153
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The 2009 models introduced logic into the defroster which affects the circulation mode.
    I believe your answer can be found in this post here
  14. Dec 17, 2009 at 6:00 AM
    #154
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    When in defrost the AC is on in my 09. I know this since I've wired my electric fan into the AC compressor signal line. When in defrost the compressor cycles on and off as needed depending on the temp selected.
  15. Mar 22, 2010 at 3:37 PM
    #155
    xpdishun
    xpdishun Active Member
    10 AC SR5 4x4 6MT V6
    I'm really having trouble getting the wires out, can someone that has done this mod take a close up picture of the metal piece on the end of the wire?
    I'm trying to test this out for the 09+ but I don't want to rip out the wires in case it won't work.
  16. Aug 8, 2010 at 5:52 PM
    #156
    proneill
    proneill New Member
    new brunswick canada
    4 cyl 4x4
    I have a 2010 i disconnected the green wire, the ac would come on all the time if the fan was on so i then disconnected the green with stripe and reconnected the green and the selector switch would not work. Has any one found out how to run the defrost and not the ac on a 2010?
  17. Nov 16, 2010 at 9:14 PM
    #157
    fohlkmann
    fohlkmann Member
    2010 Taco AC 4cyl Manual
    Disconnect A/C from Defrost
    I just completed this mod on my 2010 Taco. I too couldn't release the green wire from the connector, and it finally broke after struggling with it for like an hour. The A/C then turned on 100% of the time as the other 2009/2010 owners have commented. And the recirculate light/function was then disabled.
    But I also found the fix. Measuring the voltage on the green wire coming from the servo motor/connector, I noticed it only read 0V when in defrost-only mode. Turning the air-vent-mode dial to any other position caused it to read greater than 0V. Turning to the vent-only position caused it to read +12V. So I simply tied the green wire going to the A/C amplifier to +12v and all works great now! I can now toggle both A/C and recirculate during any functionality (A/C and recirculate are no longer hard-tied during defrost modes).
    Details:
    1) Cut green wire. Tie off the side coming from the servo motor/connector so it doesn't short to anything, it'll never be needed again.
    2) The other end of the green wire goes to the A/C amplifier per the schematics I found on this site. Tie this end to +12V. The pink wire happens to be +12V. So just connect this end of the green wire to the pink wire and you're done!
    Thanks again for posting this fantastic mod. I wouldn't have figured this out any other way.
  18. Nov 16, 2010 at 10:08 PM
    #158
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    First, welcome to TW!
    Second, post pictures! You may just become a TW hero.
  19. Nov 17, 2010 at 4:46 AM
    #159
    grammy
    4x4 v6 X-Cab
    Yes, post pictures please!!
  20. Nov 17, 2010 at 7:05 AM
    #160
    fohlkmann
    fohlkmann Member
    As requested, I've attached pics to my previous reply above.
    Thank you for the great compliment Juggernaut. I felt it's the least I could do for all you subscribers considering how much information you generously lend out!
    winkel likes this.
