A/C shut down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BamanMS, Jul 6, 2020.
  1. Jul 6, 2020 at 4:32 AM
    BamanMS
    BamanMS [OP] Member
    Alabama
    PreRunner
    Running bars, vent visors, rolling lock bed cover, aftermarket wheels
    I have a 2007 Tacoma. My A/C stopped working. There is no air coming out of the vents when I turn it on, regardless of the fan speed. Any ideas where I need to start looking? Thanks.
  2. Jul 6, 2020 at 5:53 AM
    DG92071
    DG92071 Well-Known Member
    Check the fuse first. Second make sure the fuse is receiving power.
    My 06 just started doing the same thing. I hit the dash just below the AC/heater control and it starts working. In my trucks case it needs a new control with 133K miles. I have read threads on TW where the plugs going into the heater control had burnt terminals, mine does not have burnt terminals. Good luck.
  3. Jul 6, 2020 at 5:56 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    2X check fuses. Does your truck have an cabin air filter? Is it blocked?
  4. Jul 6, 2020 at 5:59 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    X3 fuses.
    Does the blower motor turn on?
  5. Jul 6, 2020 at 6:00 AM
    DG92071
    Can you hear the blower motor spinning/turning? If yes then ignore my previous reply. If no, then go to my first reply.
    Lol.
    Good point.
  6. Jul 6, 2020 at 8:58 AM
    BamanMS
    BamanMS [OP] Member
    Alabama
    PreRunner
    Before it stopped working, there was a clicking sound. Is it possible that one or more blades in the blower motor broke, and that was the sound I was hearing? I plan on pulling the blower motor out this evening and see how it looks.
  7. Jul 6, 2020 at 4:35 PM
    DG92071
    Mine turned out to be a bad connection at the blower motor plug.
    Verify that the blower motor plug is receiving 12 volts when the fan switch is on high and that should lead you to the culprit.
    Larzzzz likes this.
  8. Jul 6, 2020 at 4:44 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    My resistor connector shit the bed. Replaced it and the resistor as a kit from AutoZone. No issues since. This is a common failure. Unplug the connector and you'll probably see a bad contact or two in it.
    Also, pull the HVAC controls and inspect those plugs as well. There are several reports of toasty connectors there as well.
  9. Jul 6, 2020 at 8:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This may help:
    TnShooter likes this.
