A/C Valve Leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GorgeRunner, Apr 30, 2020.
  1. Apr 30, 2020 at 11:26 AM
    GorgeRunner
    GorgeRunner [OP] Out There
    2005 PreRunner
    After charging the A/C, I noticed the low pressure schrader valve bubbling fairly vigorously. I will try to tighten the valve, if that doesn't work, are the low pressure valves replaceable and available at a reasonable price?
  2. Apr 30, 2020 at 2:25 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    The Schrader valve is replaceable, but you’ll dump the charge pulling it and it’s under a reasonable amount of pressure. I’d take it to a shop, let the. Recover the refrigerant and replace it after the valve is changed out.
  3. Apr 30, 2020 at 2:29 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    FYI, our specific shrader valves are available at Autozone for the high/low for a couple of bucks. But as Phil said, you need to recover the freon before changing it out. Replacing the schrader valves takes all of 45 seconds, by the way.
    Philrab likes this.
  4. Apr 30, 2020 at 2:30 PM
    Philrab
    Phil
    Btw, I’d suggest replacing both while it’s evacuated. When one leaks, figure the other will eventually.
    Clearwater Bill and Fullboogie like this.
  5. Apr 30, 2020 at 2:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You do not have to evacuate the R134a to replace the schrader valve. There is a tool that is used to replace the valve without losing the pressure at all.
    https://www.amazon.com/MASTERCOOL-81490-R134a-Remover-Installer/dp/B000KITSMI
    See this video: https://www.youtube.com/watch?v=ES0NFPH4eJg
    I learned this from a good friend here. Thanks: @CurtB
  6. Apr 30, 2020 at 3:40 PM
    GorgeRunner
    2005 PreRunner
    I'm ashamed to admit I don't know where it is, or if I even still own, a Schrader valve tool. Walmart has the tool and four standard Shrader valves for a couple bucks. I'll see how long the A/C lasts. It's been 100°+ every day so it will be a proper test.
    If it turns out to be just a Schrader valve, I would consider that fortunate indeed. I charged the system with STP ACPro. Even if it all leaks out, the hose and gauge are reusable; ~$30. Replace the valve, recharge with a couple cans of refrigerant from Walmart, hope for the best.
  7. Apr 30, 2020 at 4:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is not the way to go to have a properly charged and functional AC System. That canned AC charge shit isn't worth the hazard of damage to the AC System. You can't properly charge the system with only one gauge, it doesn't work that way.
    Didn't you see above you don't have to dump the R134a to replace the Schrader Valve.
    Philrab likes this.
  8. May 1, 2020 at 7:10 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    :thumbsup:
    Jimmyh[QUOTED] likes this.
  9. May 1, 2020 at 7:11 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    :annoyed:
    Jimmyh likes this.
  10. May 1, 2020 at 7:18 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Shit, that thing is clever!
  11. May 1, 2020 at 7:37 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    The inventor is a smart fella!
  12. May 1, 2020 at 10:20 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    LOL at "STP AC Pro"
    o_O
  13. May 1, 2020 at 11:46 AM
    GorgeRunner
    2005 PreRunner
    It's a big can of refrigerant and reusable hose and gauge. It got the non working air conditioning blowing cold. Not sure what you expect for $30.
  14. May 1, 2020 at 12:30 PM
    Philrab
    Phil
    To properly charge a system you really should pull vacuum to remove all humidity from the lines though. A can with a gauge doesn’t do that. Doesn’t let you look at high and low pressure levels while system is operating to gauge correct charge.
    It’s your truck, I’m just telling you from personal experience it ain’t right.
    king collard and Jimmyh like this.
  15. May 1, 2020 at 12:42 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Before you do anything about the ac valve cores, take a blunt poker of some kind and depress the center of the leaking valve core a couple times real quick. Sometimes that’s all it takes to reseat the valve. You may not even need to replace it. Protect your hand from the r134a with a glove
  16. May 1, 2020 at 12:52 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    AC pro has "leak stop" in it. It will perhaps buy you some time, then it will completely F up your AC. Maybe not today or tomorrow, but in a year.... Good luck, because it's too late now, it's in there.
    Jimmyh likes this.
  17. May 1, 2020 at 1:24 PM
    GorgeRunner
    2005 PreRunner
    Hard to believe that every can of AC Pro sold has destroyed the air conditioning system it was used on. Think you would hear about that somewhere other than your post.
    It may not be the best solution, but it's the best available option.
    RustyNut1996 and SR-71A like this.
  18. May 1, 2020 at 3:05 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Best available option would be to find and fix the leak, pull a vacuum, and charge with pure R134A. That's how us guys that make a living doing HVACR do it. Best of luck to you, not gonna argue any more.
  19. May 1, 2020 at 4:39 PM
    GorgeRunner
    2005 PreRunner
    I'm done making a living, trying to save money. Don't respond if it bothers you that much. There's always a better way to do something.
  20. May 2, 2020 at 5:06 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    It's not like it's destroying every AC system that it's used on, it's more of a band-aid fix. You could compare it to putting Slime in a leaking tire, sure, the slime stops the leak and plugs the hole and it'll get you home so that you can do a proper fix. However, the slime effectively fubars the tire and wheel. The AC Pro is a "hot" shot of refrigerant to top up the high side IIRC. You can do the proper AC fix with simple tools. Ultimately, before you do this, I would run a can of UV leak detect through the system first to find out where you're leaking from so that once you start working, you can fix the underlying problem. Run this leak detect stuff through your AC for about 3 days to a week and black light the shit out of your engine bay like you're cleaning up after an all day 70s Italian gang-bang porno shoot. Don't forget to wand your heater core behind your glove box. https://www.amazon.com/dp/B077PY6NHR This vacuum comes with the manifold gauge
    You'd need a little less than 2 full cans of R134a refrigerant, and I'd replace both of the schrader valves while you're at it. After you capture all of the old refrigerant, I would do some preventative maintenance and replace the seals going into and out of the heater core while the system is evacuated. I'd also pull a vacuum for at least 4 hours prior to putting in your new refrigerant. When transitioning to the second can, insert the can with the nipple facing down so that the liquid refrigerant is in the neck of the can, that way no unnecessary air gets introduced into the system. Place the second can on the digital scale to make sure you put the proper amount of r134a. I cant remember exactly how much you'd need, but it'll be under the hood on the fan shroud I believe. All in all, doing your own AC work isn't too difficult to do it properly. You'd need the specialty tools I linked, the manifold gauge (this is idiot proof, the schrader valves are different sized for the high/low so you'll know you have the gauge installed correctly), a scale (any scale would work, but the ol' lady might not want you using her fancy kitchen scale for vehicle maintenance), and a constant vacuum pump. You might be able to rent the gauge and pump from an auto parts store. I haven't verified this yet. Just make sure you take it to a reputable AC shop to evacuate your old refrigerant for a nominal fee.
    Last minute add: We're not trying to insult your intelligence and ultimately, it is your vehicle - your decision. However, we are just trying to convey that it's not difficult to do most of the work on this truck given adequate space and tools. Tacomaworld is a collective of individuals each with individual experiences that are just trying to share their knowledge with you so take it as you will, with a grain of salt. Have you messed up your AC system because you ran leak stop through it? Not necessarily. More than likely, you've limited the efficiency of your AC by sealing up passage-ways through your heater core and gumming up the vanes in your AC condenser. It'll still work but not to what the capacity you've been accustom to.
    Youtube is blocked here at work, but ChrisFix has a series of videos that are using our Tacoma for diagnosing AC leaks and charging the AC using the method I described above. Search 'ChrisFix AC charge' and you should be able to see the video series I'm talking about.
    -J
