A/C won't blow at all
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueWaffleTaco, Sep 3, 2015.
  1. Sep 3, 2015 at 9:14 PM
    BlueWaffleTaco
    BlueWaffleTaco [OP] Well-Known Member
    Brendan
    Stl (wentzville) MO
    2007 Blue Double Cab sr5 trd sport
    SOS CONCEPT ROCK SLIDERS, CALI RAISED LED w/ STEALTH MOUNTS, THULE ROOF RACK, 3" ROUGH COUNTRY BODY LIFT w/ 5100 BILLYS, VISION WHEELS W/ 285 70 R17s, AFTERMARKET HEAD UNIT, SOON TO BE OWNER OF NEW FRAME
    The ac in my 07 taco is blown, and has been for awhile. I took it to the shop awhile back and they called me immediately saying it was fine and still charged me 60 bucks, so when it stopped working the next day i called them inappropriate names and just lived with it. but now i feel i found a clue. the light behind the fan switch on my panel doesn't light up like it should, should i buy a new temperature control panel or just mess with the resistor or could it be something else. Help plz k thx.
  2. Sep 3, 2015 at 9:15 PM
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    I have the same exact problem, but it's with my girlfriend
    WhiteNight likes this.
  3. Sep 3, 2015 at 9:16 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    thanks for the help
  4. Sep 4, 2015 at 4:14 AM
    freespool
    freespool Well-Known Member
    Friendswood, TX
    2012 DCSB Prerunner TSS
    There is an AC relay switch I replaced in my 4Runner that fixed it. A cheap try and see. Will have to google it as I am about to go into surgery and can't look it up for a while.
  5. Sep 4, 2015 at 7:32 AM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    Thank you i will look that up.
  6. Dec 8, 2015 at 9:04 PM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    07 Double Cab LB 4x4
    3 inch lift, AM nerf bars, Plasti-dip badges, Areis bull bar, KC 6in spotlights, AM stereo + sub, AM high performance Halogen headlight bulbs
    Did this work? How did you fix it? Having the same problem
  7. Dec 8, 2015 at 9:07 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Turn it to fan speed 4. If it blows, the problem is the fan resistor and harness. Takes about 10 min to fix. The light issue is just a bulb. 1 min fix.
  8. Dec 8, 2015 at 9:09 PM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    I think OPs AC does not work on any setting. Mine doesn't either - about to go check the resistor, if its not burned ill try taking the motor out and cleaning it.
  9. Dec 8, 2015 at 9:27 PM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    OP my AC was not working at all, but when I went out to check the resistor I first tried hitting the bottom of the glovebox a couple times. Fans started right up no problem. I pulled the resistor for fun and its a little burned, might be a problem in future. For now, I would say I just need to clean the fan motor
  10. Dec 9, 2015 at 5:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07's AC blower stopped working a few months ago. I needed a new blower, under $200 and a couple of hours at an independent shop. It had 150,000+ at the time so I'm not complaining. The only part that has been replaced except tires, brakes, and battery.
  11. Dec 9, 2015 at 7:18 AM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    Give it a nice whack
  12. Dec 9, 2015 at 7:36 AM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    Just hit it with a wrench lol I do it daily now
  13. Dec 9, 2015 at 7:47 AM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Every once in awhile my 07 will do the same thing man I can turn it to full heat or air and I get nothing. Someone told to reach up under the glove box area and just hit around with my palm (while the heat/air is turned to high) so I did it the next time it wasn't coming on for me and BAM it kicked on. I don't know shit about A/C stuff but whatever is under my glove box I have a feeling is on it's last leg. I've just been to lazy to take it to the shop and get it replaced. Oh and also just giving it a small kick with your foot works if you don't feel like hitting it with your hand lol.
  14. Dec 9, 2015 at 2:23 PM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Here at Amazon. $ 43 for the fan and $ 28 for the resistor pack. (for a 2007)
    http://www.amazon.com/gp/product/B0041TEKI4?keywords=tacoma blower fan&qid=1449699708&ref_=sr_1_1&sr=8-1
    Fritz
