A click not a clunk not a thud when I apply the brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Jul 12, 2017.
  1. Jul 12, 2017 at 6:04 AM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    On my 2015 TRD off road I get a click that seems to be coming from the left front wheel when I apply the brakes. Any ideas folks? Thank you in advance.
  2. Jul 12, 2017 at 6:09 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Front pads moving around in the Caliper?
    My shitty ford ranger did that.
    12TRDTacoma likes this.
  3. Jul 12, 2017 at 6:21 AM
    Pigpen
    Dan
    Northwest Montana
    Yep. They all do it eventually. Back side of the pads needs a little grease.
    12TRDTacoma and Jerry311SD like this.
  4. Jul 12, 2017 at 6:34 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Also the pins that the pads ride on, coat them in silicone brake grease and it goes away until the grease dries up again.
    Normal.
  5. Jul 12, 2017 at 6:36 AM
    Jake1530
    2015 Tacoma TRD
    Thank You so much guys, I'm not mechanic have an appointment at the dealer on Monday but have a long drive on Saturday, do I have anything to worry about other than the click noise? Thank you again
  6. Jul 12, 2017 at 7:48 AM
    gearcruncher
    Canadain bumper technician
  7. Jul 12, 2017 at 9:03 AM
    Pigpen
    Dan
    Northwest Montana
    Nothing to worry about. Mine have been clicking for about 3 years now. I even added the second "spring". I'm almost due for new pads - I'll address the issue then.
    12TRDTacoma and Jake1530[OP] like this.
  8. Jul 18, 2017 at 10:47 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    mine would click going forward and reverse when you hit the brake pedal. Pulled the pins and the pads out, wire brushed pins and put a little grease on them, no more noise.
  9. Jul 18, 2017 at 10:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Add a second spring is the best you can do about all this. The grease eventually wears off the pins and the clicking reoccurs. It is normal, but I'd rather have fixed pistons rather than floating on a truck like these have so it's all a trade off.
    Pigpen likes this.
  10. Jul 26, 2017 at 3:12 AM
    Jake1530
    2015 Tacoma TRD
    Ok last week I went to the dealer showed the fellow that you check your truck in with, and showed him my thread and gearcrunchers post on the thread that was linked off of my thread. All good information, thank you s much people. Well the guys at the dealer said pretty much “that’s just how it is”. I took my truck to my regular mechanic who I haven’t seen in 2 years as I’ve been getting my free oil changes for free, for my 30,000 mile oil change and spark plug replacement. They did what gearcruncher recommended with the NAPA clips. They mentioned there was NO grease or lubricant on the caliper areas. Well no more click! Before I mention the plugs, does anyone hear think I can get reimbursed from Toyota for the brake fix?
    The plugs, like myself they were puzzled why there were two different brands of plugs in the truck from the factory. I had platinum plugs installed. Thank you again for all your help.
