A compact, portable, storable compressor for OEM size tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Feb 27, 2014.
  1. Feb 27, 2014 at 4:36 PM
    jw1983
    jw1983 [OP] Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Hey everyone!
    I carry a small compressor in my truck for emergency purposes. Since that I live in the city, I check my air everytime when I fill up for gas. I noticed my tire was low yesterday and I used my compressor and it took 30 minutes to put in 10 PSI of air. I didn't expect much since that I spent $5.00(CDN) on it 2 years ago. I went to two other gas stations(one was free air and the other one was paid). The free one was broken, leak you could feel. The paid one wasn't putting air into the tire. It was losing more air then putting in. I hate paying for air, it drives me crazy. But I don't want to pay $1-2 dollars every week to a week and a half for air to top it up.
    So I am wondering if there is a decent compressor that is compact, portable and can fill a truck tire in a decent amount of time for a decent price? I figured that some of you would know because a lot of you have bigger truck tire size then the OEM size that I run.
    Any advice on brands, pricing, anything would be great.
  2. Feb 27, 2014 at 4:52 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    MV-50
    Great compressor for the money. I have had mine for nearly 7 years but now I use mine as a backup.
  3. Feb 27, 2014 at 4:56 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    slime makes a good one for around 55.00 at walmart. blows up normal car tire in around 4 minutes.
  4. Feb 27, 2014 at 5:10 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    I have a $10ish one from Walmart that works good enough in a pinch. Doesn't replace the one at home but it fits under the back seat. Have actually used it twice this week with people at work getting flat tires.
  5. Feb 27, 2014 at 5:41 PM
    jw1983
    Alberta
    This is probably like the $5.00 one that I bought 2 years ago. It's good in a pinch but that's pretty much it. It wasn't an emergency or anything but if it's -35C outside, I really don't want to be out there with a shitty compressor trying to put air in a tire. In the summer, on my pedal bike it's no issue. I'll pay more for a better compressor if I don't have to pay for air or rely on the one that I already have.
  6. Feb 27, 2014 at 8:36 PM
    Rln21
    Rln21 Active Member
    Central Oregon
    2013 Tacoma TRD Off-Road Magnetic Gray
    Any of these compressors that will work with the plug in the bed on a TRD without drawing too much power? Would like to use it for other stuff than just the vehicle...
  7. Mar 1, 2014 at 7:11 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just ordered this one today on Amazon for $63. Looks like it has a bunch if great reviews.
  8. Mar 1, 2014 at 7:13 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
  9. Mar 1, 2014 at 9:29 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    x2 ! I have had mine for many years and it works great. I even got mine back when they were 24 bucks, and bought one for a buddy for a Christmas present. Here is a good test of the compressor..
    http://www.gearinstalls.com/pepboys.htm
    Whatever you end up going with, make sure you compare cfm's because you want the unit to move plenty of air. Otherwise you're going to have the same issue you have with your current unit.
  10. Mar 1, 2014 at 10:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Better off with a 12v unit and connect it to the battery.
    The 120 comes from the battery, and is limited to 400 watts.
    That's not going to run even a small 120v compressor (which would run you around $100).
  11. Mar 2, 2014 at 8:52 AM
    jw1983
    Alberta
    I wasn't going to expect much from a $5.00 compressor. Since that I have to plug it into the 12V cigarette lighter(no battery connectors), I wasn't expecting a lot of air to be pushed out. Just trying to find something that's better, isn't a crap load of money and has somewhat a decent quality.
  12. Mar 2, 2014 at 1:39 PM
    TxFireman
    San Antonio, Texas
    Yes, that's my point exactly. You can spend a bit more money (on the new one) and end up with the same 5 dollar compressor if you're not looking at the cfm of the compressor you're buying. In the test I linked, the quick air cost the owner 225 bucks more than the unit he tested it against and the 25 dollar unit worked better. In that case, he could have bought several to keep on hand.. and all together they would probably outlast the life of the quick air.. but I'm just assuming that. Just something to think about. Good luck and I hope you find the one you're looking for.
  13. Mar 2, 2014 at 3:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And those $5 compressors don't have the duty cycle for anything larger than a motorcycle. They might do 60psi, but it's going to take all day to get a 285 to 40 because it will overheat.
  14. Mar 2, 2014 at 3:48 PM
    DJSPEC
    DJSPEC TRD Kaena Point Edition - @GuardianTacos
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone MT2 285/70R17 SCS Stealth 6 Wheels Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel 3" Lift Light Racing Ball-Joint Upper Control Arms (LR8-25470) OME Front Nitro Shock(900021) with 885 Springs OME Nitro Rear Shocks (ARB8-60091) Revtek Add-A-Leaf (REVAALT5B)
  15. Mar 2, 2014 at 3:55 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    ive had this guy for like 3 years now. works great! can plug into the lighter or has clips for the battery. one of the best investments ive ever made.
    edit: ive never plugged it into the cigarette lighter because i was unsure of the current draw. it was just as easy to clip it to the battery directly
  16. Mar 3, 2014 at 6:53 PM
    moondeath
    Pa, Carlisle
    Just got my MV50 from Amazon today.
    0B404B3F-BE07-4391-ABA7-88CE3BB08C19_zps_17ec6ceb96b3b51a2a65a08bbd4c26b09fe0ceb9.jpg
    66E05CF2-E942-48EE-B38C-D47EBD940AF1_zps_0a12b565528ce35c4f66585d0385f015e3d47b48.jpg
  17. Mar 3, 2014 at 7:53 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Check out one of these. It will do a lot more than just fill up you tires.
    I have had this exact one for over a year now. It works great.
    Batter jumper, compressor, air mattress filler, light, usb charger, 12 volt power supply and power inverter.
  18. Mar 3, 2014 at 9:05 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  19. Mar 3, 2014 at 9:36 PM
    TxFireman
    San Antonio, Texas
    I've got one of these exact units as well, and I've used the hell out of it. I have to say I have not used the compressor for much, maybe to fill a bike tire, so I don't know how well it does on truck tires. I've taken it on more than one road trip just to have it handy.
  20. Mar 3, 2014 at 9:43 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    sr5 trd 4wd
    I am amazed that you check the air pressure EVERY time that you get gas…I do have a decent compressor from Harbor Freight.
