A different blower motor/resistor issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rmeyer7, Dec 26, 2017.
  1. Dec 26, 2017 at 10:06 AM
    rmeyer7
    rmeyer7 [OP] Active Member
    Roy
    2012 Tacoma 4-cyl, 5-speed
    I've been having the common intermittent issue where my A/C blower fails to run at any speed. I read as many threads as I could find here, took the blower motor and resistor out, and ran into a couple of surprises.
    First, the connectors in the pigtail assembly were perfectly fine -- they looked brand new. Then, when I pulled the resistor out, I found it was NOT the factory ceramic one, so it was probably changed by the original owner (my Tacoma is a 2012 and I bought it in 2015). And finally, I pulled the blower motor out and noticed it's an aftermarket model. I'm guessing the pigtail part was also replaced when the other two parts were.
    The motor is noisy so I'll be replacing it, and the resistor looks like it might have burned out. Hopefully that's all that's needed to fix it. I'm not surprised that it's failing again...but I am pretty shocked to find the pigtail connector in perfect shape. Anyone else had the same experience?
  2. Jan 31, 2018 at 7:41 PM
    TacoTaco06
    TacoTaco06 Member
    2010 Tacoma TRD Sport Access Cab 4.0L 6Spd
    Made an account specifically for this issue. I am having very similar problems. Started with the dreaded squeak from the blower motor. Now it only works on the high setting. I have read every single post and no one has a perfectly fine connector and (relatively) fine resistor (all have the common burn mark). Removed the motor and cleaned it. Got a fair amount of dust and metal filings out which did stop the noise (for all of about 4 minutes of use). Now I'm back to square one. On the verge of replacing everything- motor, resistor and pigtail connector. Have you been able to resolve your issue?
  3. Jan 31, 2018 at 8:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That should take care of your problem.
    TacoTaco06[QUOTED] likes this.
  4. Jan 31, 2018 at 9:14 PM
    TacoTaco06
    TacoTaco06 Member
    ^^ something I would like to avoid if possible lol. Sounds like the issue persists, in time, for others even after replacement of all of the above. A permanent fix would be greatly appreciated *cough*cough* toyota..
    dborrer likes this.
  5. Jan 31, 2018 at 9:15 PM
    rmeyer7
    Roy
    I replaced the resistor and blower motor right after my original post, and haven't had a problem since. I went with aftermarket parts in hopes that they won't fail like the OEM ones. I didn't replace the pigtail, since mine wasn't bad.
  6. Jan 31, 2018 at 9:19 PM
    TacoTaco06
    TacoTaco06 Member
    Good to hear. Looks like I will be trying the same
  7. Jan 31, 2018 at 11:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You know there are two pigtails that get burned right?
    That connector and the resistor connector are both known for getting burned terminals.
    That connector on the top right is here:
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    You may also have a burned resistor connector and may need these:
    Plug Number 82141-04M40
    Resistor Number 87138-04052
  8. Feb 1, 2018 at 9:18 AM
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    I just went thru this a few weeks back on my 2012. Fan switch work on higher settings for a time, then stop working. Change the resistor (connector was fine)and work fine for two days then stopped working again. Did some research on heater problems and blower motor problems. Did a test by banging/tapping the bottom of the blower motor and checking the connector ( connector was fine) . Started the truck, turn the heat on and worked. Would run for a while then stop again. Installed a new blower and every thing has been running perfect.
    I also checked the 2 relays and fuse under hood before changing the resistor. They where fine.
  9. Feb 1, 2018 at 11:50 AM
    TacoTaco06
    TacoTaco06 Member
    Both connectors and all wires show no signs of burns from shorting. I will definitely try the updated resistor as mine is the old green style. I took the blower motor out, removing the cap on the back to access internals. Removed a fair amount of fine metal/carbon dust (just with simple canned air duster). I just don't know what to look for to determine if the motor is junk.
    As I mentioned I had the squeak that often plagues the blower motors in the tacoma. I put up with this for several days before it moved on to a grinding, then quitting on all but high fan settings.
    I have wiggled all connectors with no results, checked fuses. I'm guessing both new Blower and resistor, as I have noise issues as well as the fan speed . Would I be correct to assume the old resistor connector will plug into the updated resistor?
    Hunter, did you get an oem or aftermarket blower?
  10. Feb 1, 2018 at 12:14 PM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    Amazon oem rated , T1A-87103-04040
  11. Feb 2, 2018 at 6:28 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes the plugs are the same.
  12. Feb 2, 2018 at 2:58 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd...........:popcorn:
  13. Feb 3, 2018 at 9:55 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Looks like I’ve just joined the club, motor is a little noisy and doesn’t work on the lowest setting.
    Rockauto has a TYC that is cheaper than T1A-87103-04040 on Amazon. Anybody have any issues with quality on these motors?
  14. Feb 3, 2018 at 11:11 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    have not had any problems after installing the T1A, I went with this one after checking reviews in a few places.
    YOTA LOVER[QUOTED] likes this.
  15. Feb 4, 2018 at 10:35 AM
    YOTA LOVER
    NH
    Nice, do you guys recommend just replacing all of the components, or go piece by piece?
  16. Feb 4, 2018 at 11:17 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    I first just replaced the resistor then the blower motor. On a later model I think its better to just change both at the same time. Resistor problem can carry over to the blower motor and vise versa from some of my researching.
  17. Feb 4, 2018 at 2:25 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I replaced the resistor before i noticed the bad wire at the resistor plug. Found a kit at Auto zone that included both the replacement plug and resistor with heat shrink crimp butt splices
    Haven't had a problem since.
    YOTA LOVER likes this.
