A little help: I have no heat.
Discussion in 'Technical Chat' started by ZMan2k2, Oct 22, 2013.
  1. Oct 22, 2013 at 8:59 AM
    ZMan2k2
    ZMan2k2 [OP] “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Yesterday, I had heat. Today, nothing. It's the original coolant with 92k km's on it. Do I need a flush, or is there a fuse or something that could have blown, a relay I need to check? Little help here, please.
  2. Oct 22, 2013 at 9:04 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    More info man, like the fan stopped blowing, or the fan only blows cold air, or none of my heater controls are working.
  3. Oct 22, 2013 at 9:53 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Fan works at all speeds, but blows cold air only. Turning the knob to heat does nothing, it's like it's set to blow cold air all the time. A/C works and re-circ works, but there's no heat from the vents.
  4. Oct 22, 2013 at 9:59 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I dont know for sure cause I haven't had to get into mine but it is probably a blend system. Meaning the coolant is always in the heater core and your controls open and close a door in the heater box to allow the air to be heated. I would check the control head.
  5. Oct 22, 2013 at 10:08 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    HVAC isn't my forte'. Where's the control head?
  6. Oct 22, 2013 at 10:10 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Check the fuses. I know some of the controls are controlled small electric motors. Just a thought.
  7. Oct 22, 2013 at 10:12 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    Could be:
    Blend door control
    Blend door fuse
    Blend door motor
    Clogged heater core
  8. Oct 22, 2013 at 10:18 AM
    Nickel
    Diego
    2013 T/X TRD
    Does your temp gauge show your truck is warming up to temp? If not it's probably the thermostat. If your truck is getting up to operating temp, then it's probably something electrical, either the heater controls, or whatever Toyota uses to open the hot water to allow it into the heater, a solenoid of some kind. Possibly a fuse for heater control.
  9. Oct 22, 2013 at 10:20 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Yeah, the temp goes up to operating temp. quickly, and stays steady at 87*C. So, maybe a solenoid in the under hood fuse box. Any way to check those out before I drop cash on new ones?
  10. Oct 22, 2013 at 10:21 AM
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    Im guessing it may be a thermostat. Mine went out in my old ranger and the heat went away. It usually a cheap part. I might check that. but as said above, normally when the thermostat goes the heat guage stays low. Its actually better for the engine some say, because its cooler? I dunno.
  11. Oct 22, 2013 at 10:25 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    I would assume that you may have a clogged heater core. From what I recall, they are placed way up under the center of the dashboard. To get to it, you will most likely have to take it ALL apart to get to the plastic housing. The coolant lines from the engine bay punch through the firewall and head right into the heater core housing.
  12. Oct 22, 2013 at 10:26 AM
    Nickel
    Diego
    2013 T/X TRD
    Try fuses first, they are inexpensive and easy to tell if they are bad with visual check. Sorry I can't point you to exactly what fuse to look for, I've never even worked on my Tacoma, it's never needed anything (yet). But I have worked on tons of other vehicles and I'd start at the fuses, then check the things paleus listed "Could be:
    Blend door control
    Blend door fuse
    Blend door motor
    Clogged heater core"
    Good luck, I'm sure it's something minor. I don't think its a clogged heater core, because I would think that would be something that would go out slowly, not one day work perfect, next day nothing.
  13. Oct 22, 2013 at 10:45 AM
    BostonBilly
    Easton
    I agree with the fuses. I wasn't thinking about that cause it all used to be vac when I worked on cars.
  14. Oct 22, 2013 at 11:42 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    I've narrowed it down to the blend door. When you switch it from hot to cold on the controls, the door makes a couple funny noises. I actually got heat now, but I'm afraid to switch it to cool now, because it may not come back. How hard are blend doors to work on? Can I do it easily, or is it something that should be sent to a mechanic to do? I have a little mechanical knowledge, but don't know vehicles inside out.
  15. Oct 22, 2013 at 12:18 PM
    BostonBilly
    Easton
    It can be a pain in the ass
  16. Oct 22, 2013 at 10:22 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, I've got my money on the heater blend door inside the HVAC unit. You may want to read this. http://www.toyotanation.com/forum/6...880-08-c-air-door-actuator-servo-problem.html
    That link highlights the recirculation servo but will give you a general idea of what goes wrong. The link addresses one of the more popular servos that go bad.
    There are three servos that control 5 or 6 blend doors. The heater blend door part of one of my servos broke and I had to dig it out of the dash.
    Most of the servos and blend door attachments can be accessed without tearing into the dash -- that is except the temperature control door. It has a POS little plastic pin that shears off and the only fix is to remove the entire HVAC unit from the dash and replace the entire door. Ask me how I know.
    One other thing. The blend doors have foam glued to them and some trucks up to the '09s used a crummy glue that would come unglued from the foam of the blend doors, especially the heater door, and jam open the door, and defrost duct. There are TSBs on both.
    Good luck.
  17. Oct 23, 2013 at 6:35 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Thank you. Yeah, it sounds like my problem. Mine is just beginning, but I better get on it. I'll look into getting the heater blend door part from Rockauto. Initially, I thought it was the relay that had gone bad, and the part from Toyota was 160 bucks. And there's two relays! That's 320 for relays that wouldn't have fixed my problem. I'll have to look into the servo motor, it does make strange noises sometimes while switching from hot to cold now, so I'll check it out and see which one it is. Thanks for pointing me in that direction, I can save myself some coin this way.
  18. Oct 23, 2013 at 9:25 AM
    Taco'09
    The heater blend door servo is the lowest of the three servos. It is right next to your left foot when sitting in the passenger's seat. You can wiggle the heater nozzle off and out of the way to get more space. I believe there are three screws that hold the servo motor and underneath the servo there is the cam that rotates to position the heater door arm.
    The cam operates a lever (the heater door arm) with a tiny, crummy plastic pin I mentioned above. If the pin is broken off you are screwed. If not, open and shut the door by hand to see that it has free travel. The pin is usually broken off when you put it to the max, cold position as the servo really strains to close the door against the foam and seal it.
    Standard Motor Products or Dorman produces the servos for these. There are enough numbers on the servo's label to decode it, IMHO, and chase the Standard Motors or Dorman version. When I bought mine the thieves at the stealership wanted $175 for that horrible crappy little servo.
