A noob's game plan for a lift.
Discussion in 'Suspension' started by SmoothFox, Jan 17, 2011.
  1. Jan 17, 2011 at 7:32 AM
    SmoothFox
    SmoothFox [OP] Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    Well, I guess this is the route I am going to take. It is cheap and will add 2.5 inches of lift for 3 Franklin's with me doing the install.
    Just three questions.
    1. I know some of you guys are gonna have a good laugh @ my expense but.... Will doing this mod physically add 2.5 inches to my over all height? Want to make sure it fits in the garage set @ max height.
    2. Can the height be adjusted after install go from stock to whatever I choose?
    3. Do I need to pick a height and NOT change it because it will be messing with the alignment?
    Step 1. Install the shocks.
    Step 2. Take to dealer for rear TSB and alignment.
    Step 3. Enjoy!
    Thanks! Fox
  2. Jan 17, 2011 at 7:47 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    You will have no problem fitting in your garage. It will be level at 1.75 mine was with the TSB AAl. You adjust it before you put the shock on it is a shock not a coil over, and if you want to change it you have to take it out and adjust it and put it back in all over again. This is not that bad of a way to go for a start I added new springs and an AAL for the full 3inches and a better ride. I would take it somewhere else for the alignment I did mine at a Big O tires.
