A-trac in 4lo on all 2016 4x4 Models Non Trd Offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mulkey, Jun 21, 2016.
  1. Jan 25, 2018 at 6:16 PM
    #401
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You are the man!
    I will put a good eye on your updates.
    Thanks for the effort!
    DesertTaco4x4 and Topanga Taco like this.
  2. Jan 25, 2018 at 6:26 PM
    #402
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    So after fixing the errors, it appeared everything combined across trim levels pretty well until 4Lo.
    I am still miffed by the 4Lo in the ORs defaulting to TRAC-OFF, where the SR/etc default to TRAC ON.
    It seems that generally the modes across the board default to high level of traction, until you get to the 4Lo OR models. Why make the trims designed for maximum traction, default to min traction in the maximum traction mode?
    OR Manuals have a good work-around by the latching A-TRAC switch, so that when going into 4LO, they don't go to the default TRAC-OFF.
    OR Autos don't have a good work-around to this issue as far as I see.
    tonered and DesertTaco4x4 like this.
  3. Jan 25, 2018 at 6:31 PM
    #403
    BigWhiteTRD
    Ted
    Ahh, I guess @Doggman pulled the trigger on a new thread.
    DesertTaco4x4 likes this.
  4. Jan 25, 2018 at 6:39 PM
    #404
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Yeah decided to throw it out there. I'll copy the latest excel documents into the original post.
  5. Jan 25, 2018 at 6:40 PM
    #405
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Thank you for all of your time dedicated to this. It’s been a blast, from finding this thread on the net, joining, and then feeling the magic. *Applauding*
  6. Jan 25, 2018 at 6:43 PM
    #406
    BigWhiteTRD
    Ted
    Please do, thanks
  7. Jan 26, 2018 at 8:13 AM
    #407
    Cold_Toad
    Cold_Toad Well-Known Member
  8. Jan 27, 2018 at 3:45 AM
    #408
    Thechief86
    Thechief86 Well-Known Member
    Eric
    Middle TN
    Stock 2006 TRD OR, as well as some other junk...
    Sparkly blue shift knob
    https://youtu.be/YYeImIIYpjs
    Figured I'd repost this video from June last year of me climbing some off camber stuff, in case some of you missed it.
    Watch what the truck does when The front wheel comes off the ground. This is in 4lo with no button pushed.
    tacomatime, Topanga Taco and tonered like this.
  9. Jan 27, 2018 at 4:15 AM
    #409
    Thechief86
    Eric
    Middle TN
    https://youtu.be/fcbzyD0iEcM
    A nice, steep hill climb in Colorado Springs, after unloading the bikes I wanted to see what the truck would do.
    This is 4lo, no buttons pushed, steeper than it looks.
    The truck had just finished a 17 hour drive from Nashville, TN, only stopping for fuel. I love this truck!
  10. Jan 27, 2018 at 6:24 PM
    #410
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    Why is you bumper trim black and your flares white? Is that how all SRs come?
  11. Jan 27, 2018 at 6:38 PM
    #411
    Thechief86
    Eric
    Middle TN
    Truck has no fender flares, it's just painted steel.
    This is the "convenience package", includes back fold up seats, painted bumpers, and a sliding back window. I think it's a decent looking truck for $25k and has everything I needed, and a few things I could live without, but have grown to really like. :cool:
    tonered likes this.
  12. Jan 27, 2018 at 6:42 PM
    #412
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Ah just curious, looking to convert my trim and flares to black someday.
    tonered and Thechief86 like this.
  13. Dec 24, 2018 at 12:20 PM
    #413
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    They should just have an "OFF-ROAD" button once you put it in 4hi or 4low. I guess "Crawl Control" is the closest thing on a AT.
  14. Dec 24, 2018 at 1:51 PM
    #414
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Crawl is a low range only cruise control. MTS would be the selection in low range, In H4, Trac Off is maybe the best choice on loose surfaces but I would need to drive a 3rd gen to see if Trac Off is the same as it is for 2nd gens.
  15. Oct 22, 2019 at 10:38 PM
    #415
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    All of this is very informative. It’s got me thinking. If an sr5 owner adds an aftermarket rear locker, is there anything wrong with turning on the locker and not turning “TRAC OFF” in 4lo or in 4hi for that matter. Or any other of these modes that should be thought about and turned off before turning that rear locker on?
  16. Oct 23, 2019 at 9:05 AM
    #416
    David K
    When you lock the rear diff, it would not be affected by traction control which only is activated with wheel spin, so one tire does not spin freely.
    Once locked, both tires are rotating the same so one spinning by itself can't happen.
    You would want traction control on the front end to make both tires work at moving you forward.
    On my 2010 Off Road, in H4, TRAC without engine regulation is the standard mode (renamed TRAC OFF in 2012 and needs a button push) works on all 4 tires. In L4, there is no traction control other than A-TRAC (which is a far higher level of traction, almost like lockers). You can lock the rear with A-TRAC on or off. A-TRAC in that case only works the front and as with any traction control only works if there is tire spin, but with the rear locked it is only active below 3 mph. When the rear diff is not locked, there is no speed limit on A-TRAC function. However, you are in low range, so not driving fast... and wheel spin usually means you are stopped or nearly so.
    I still have not been satisfied learning if TRAC OFF MODE is the same on 3rd Gens as it is on 2nd Gens. ??
  17. Oct 23, 2019 at 9:15 AM
    #417
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    gotcha. That’s what I figured but wanted to check. Also, What I’m trying to figure out and what I’ve gathered from this thread is that on my 3rd Gen Sr5 4x4 in 4lo, if it says TRAC OFF on dash my traction control is disabled and if no light is on than my traction control TRAC is enabled. This is what I’m thinking. Is this correct?
  18. Oct 23, 2019 at 10:10 AM
    #418
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
  19. Oct 23, 2019 at 10:17 AM
    #419
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    This tread may help explain the 3 rd gen traction control. The first post is up to date with all current info.
    If the light is off in 4wd low, traction-brake applied- is functional.
    If dash says TRAC OFF you tires will spin.
    https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/
    tonered likes this.
  20. Oct 23, 2019 at 11:28 AM
    #420
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    PB FAB[QUOTED] likes this.
