A-TRAC: WHY is it difficult for some people to accept it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Oct 13, 2010.
Thread Status:
Not open for further replies.
  1. Oct 13, 2010 at 6:12 PM
    #41
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    If I didn't know any better I'd say this was a "new chick" thread :rofl:
  2. Oct 13, 2010 at 6:12 PM
    #42
    ink junky
    TACO LOVER
    TEXAS
    I'm number 8! yea! :D
  3. Oct 13, 2010 at 6:12 PM
    #43
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sorry but not true, 0:44-0:46 watch again and again and you will see front right coming down on the ground. You dont see to much of transition but thats because there is no jerking and tire rotates with the same speed as others (lockers :D)
  4. Oct 13, 2010 at 6:14 PM
    #44
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    A-TRAC comes with our truck... a front locker does not. Can't we celebrate what Toyota has added to the Tacoma? I mean it has been available on their other models for 10 years... Of course they have improved it... When it is shown how well A-TRAC shines and somebody posts right below, that he recommends the O/R Taco TRD because it has a rear locker... I just wanted to ask why is A-TRAC so hard to understand or why is it so resisted by those who DON'T KNOW IT?
    Thank you ... Stay Off Road, My Friends!
  5. Oct 13, 2010 at 6:17 PM
    #45
    n315on
    n315on Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    Locker just sounds better I guess??
  6. Oct 13, 2010 at 6:17 PM
    #46
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I don't question front and rear lockers are best, but our trucks came with a rear locker and A-Trac, it's there and it helps ;). How far would the 4 Runner had gone up that hill on just open front?
  7. Oct 13, 2010 at 6:20 PM
    #47
    jandrews
    '09 FourDubDee TRD OR
    And that is the plan here in the next 6 months or so. :D
  8. Oct 13, 2010 at 6:21 PM
    #48
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    FWIW Lockers in snow isnt that bad if you know how to drive in the snow.....
    ATrac is definitely awesome and works great from what i see. But, for the price difference from the base to a trd OR imo its not worth it...
    Also, FWIW the base model tacomas with the auto lsd front and rear works pretty damn good. Ive gone places with my truck a trd or with locker and open front cant do...
    Also, to the comment that a lunchbox locker is a poor mans locker, how so????
  9. Oct 13, 2010 at 6:23 PM
    #49
    BlueT
    NorthEast
    Not quite, imagine your vehicle on iced hill where each wheel has only usable traction to handle 150 ft -lb torque. Combined thats traction to handle 600 ft-lb of torque. Now your truck will need to apply torque of 500 ft-lb to climb up.
    if you brake two wheels you only get 150 + 150 usable traction so thats less then 500 needed. 3 wheels will get you 450 still not enough
    only when all 4 wheels work as one they will collect 150 x 4 = 600 and 100 more then was required.
    this whole A-trac vs lockers is like 2wd vs 4wd. Does it work?, Yes Is it one substitute for another? Nope.
  10. Oct 13, 2010 at 6:25 PM
    #50
    jandrews
    KM2s, which may throw a variable into the game, but hell...someone can always say you greased your driveshaft more recently, or I just cleaned my air filter...can never get a 100% match. Real world, this is as close as it's going to get.
  11. Oct 13, 2010 at 6:25 PM
    #51
    Yoytoda
    Roland
    completely stock
    oh.... the definition of "poor man's locker" is using the e-brake to aid in traction...so i was confused...
  12. Oct 13, 2010 at 6:26 PM
    #52
    senna
    San Jose CA.
    Basic point being, added front traction is a plus ;).
    Does auto lsd work in 4lo?
  13. Oct 13, 2010 at 6:26 PM
    #53
    jandrews
    Still not accurate, because the locked wheels that are slipping aren't applying full torque, so your math doesn't add up there either.
    Again, I'm not comparing lockers vs. A-TRAC as better than one another...just different. I do, however, take issue with your incorrect logic.
  14. Oct 13, 2010 at 6:29 PM
    #54
    David K
    That is a fair answer... thank you!
  15. Oct 13, 2010 at 6:29 PM
    #55
    BlueT
    NorthEast
    Ok here are 3 LC's with different systems (LSD, Traction, Front rear lockers)
    Part 1
    http://www.youtube.com/watch?v=C2wkW05Pc6c
    Part 2
    http://www.youtube.com/watch?v=YNFacsKnswM
    Atrac is better then nothing but compare to F/R lockers and simply not even close.:)
  16. Oct 13, 2010 at 6:29 PM
    #56
    Yoytoda
    Roland
    completely stock
    not stock, but check my sig for the yellow wire mod :D
  17. Oct 13, 2010 at 6:30 PM
    #57
    jandrews
    Did you notice the difference in the momentum used on the first two runs compared with the third?
  18. Oct 13, 2010 at 6:33 PM
    #58
    jandrews
    This.
  19. Oct 13, 2010 at 6:34 PM
    #59
    BlueT
    NorthEast
    How much more proof you need then 3 exactly same LCs setup with different traction system :notsure:
  20. Oct 13, 2010 at 6:38 PM
    #60
    David K
    No, not without the mod. 'AUTO LSD' is just the name Toyota uses for 'TRAC' (limited slip) without any engine regulation... in 2WD.
    The limited slip in High Range 4WD is also called 'TRAC' by Toyota, but it is really the same as AUTO LSD and not like TRAC in H2, because in H4 there is no engine regulation.
    In L4 there is NO limited slip other than A-TRAC (available on the Off Road TRD only).
    Those with Sport or SR5 4WD Tacos who want limited slip in low range can do the mod to get TRAC (AUTO LSD) to work in L4... and they report amazing improvement in traction!
Thread Status:
