A340E Slippage
Discussion in '1st Gen. Tacomas (1995-2004)' started by jgill21, Mar 20, 2018.
  1. Mar 20, 2018 at 5:00 PM
    jgill21
    jgill21 [OP] Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    This one bugs me. Under normal driving, the trans shifts fine. However if I try to drop into passing gear on the interstate, it slips and revs around 4 1/2k until I let off the gas. Then it clunks into a higher gear. I've put a new filter and flushed the entire system. Ideas?
    Edit: Hard acceleration from a dead stop is fine, too. Only when dropping a gear on the interstate
  2. Mar 20, 2018 at 5:07 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    1. solenoid
    2. clutch pack
    3. torque converter
    4. hosed trans
    5. rebuild
    just quick thoughts
  3. Mar 21, 2018 at 10:36 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    I have a good A340E if you need one
  4. Mar 21, 2018 at 10:38 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What year? Do you have the A340E or the older A340?
  5. Mar 21, 2018 at 10:39 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's a '98 so it will have the early A340E. I know 2nd Gen 5-Lug 2WD's used the A340E as well. Tons of cars used that transmission, including the Supra.
  6. Mar 21, 2018 at 11:22 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    Since you are both 2.7 that trans should bolt right up unless you modified it in someway?
  7. Mar 21, 2018 at 11:23 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    The only thing that's different between the 3RZ and 5VZ A340E is the bellhousing. Otherwise they are identical.
  8. Mar 21, 2018 at 12:57 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    They have supra ones on ebay built for 500+ hp for around 2000 bucks! I bought a brand new one hiding in a yota dealership for 2,500 bucks, my trans has 15+quarts o' mobil 1 syn its newish now and it's engaging late too, its indicative of shift solenoids theres about 3 or 4 under the pan it helps to ohm those out, mine were fine yet its still a pig my 33's must have put a hurt on the trans. If you drive in OD all the time it will screw the trans too, I was guilty of that w/my other one.
  9. Mar 21, 2018 at 12:58 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You keep OD off? I was under the impression you should only turn off OD when towing or hauling.
  10. Mar 21, 2018 at 1:13 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I keep it off under 45mph, no unnecessary shifting that way. also going up hills i turn it off to hold the gear instead of relying on the TC to go in and out all the time.
  11. Mar 21, 2018 at 1:34 PM
    Luv my yota
    00 turd lift 33's
    This, I run it up to 60 before I turn it on, saves gears literally.
  12. Mar 21, 2018 at 2:52 PM
    jgill21
    Jake
    Nashville
    I'm gonna try to keep this one going for as long as I can until I can throw a manual one in
