A44D swap to A340E Tranny Install- 03' Tacoma 2.7l-Critical Job
Discussion in 'Technical Chat' started by Austin_Mike, Aug 22, 2017.
  1. Aug 23, 2017 at 3:51 PM
    #61
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Drop the pan and make sure there's no metal shavings or anything. Change out the filter and the output seal since it's right there. Once you get it installed I'd recommend you have a transmission flush done.
  2. Aug 23, 2017 at 3:52 PM
    #62
    BartMaster1234
    Tyler
    Flux Capacitor
    How much did you pay for the trans? I bought the A340F for my 4x4 swap for $250 from a yard up in Reno. Think I paid a total of $475 w/ the transfer case and core charges for both.
  3. Aug 23, 2017 at 4:17 PM
    #63
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Flush cooler and lines before installing transmission. Considering the age of the vehical I would replace the cooler.
  4. Aug 24, 2017 at 7:40 AM
    #64
    Austin_Mike
    Austin_Mike [OP] Member
    MIKE
    2003 2WD 2.7L PRE RUNNER TACOMA
    Spent $600 w/ freight shipping from Cali. 148K on the donor vehicle. So change the tranny cooler and flush the lines, also change the output seal. I'll research the seal and it's location...and prepare for a flush across the board and check for shavings. What if there are shavings? I'd hate to do a full rebuild on this...
  5. Aug 24, 2017 at 7:55 AM
    #65
    Austin_Mike
    MIKE
    Hmmm I can't ascertain just the output seal that should be changed inside the tranny. Does it have a different name or a combo type deal?
  6. Aug 24, 2017 at 9:49 AM
    #66
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Change the input seal. The one the converter spins on. Trans cooler is in radiator. Just flush it out. No need to change it.
    98tacoma27 likes this.
  7. Aug 24, 2017 at 10:13 AM
    #67
    mechanicjon
    Jon
    Scottsdale Arizona
    Oh and I've never seen or heard of a 4cyl having drive by wire. Not saying there isn't but ive only seen 3.4v6s with it.
    MrCrowntown and pray4surf like this.
  8. Aug 25, 2017 at 8:59 AM
    #68
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    EDIT: SORRY I'M an idiot
  9. Aug 25, 2017 at 9:02 AM
    #69
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    :bananadead:
  10. Aug 25, 2017 at 9:06 AM
    #70
    BartMaster1234
    Tyler
    Flux Capacitor
    Now that you mention it, it does definitely look different. Isn't the trans. on OP's truck A44D and his donor trans an A340E?
  11. Aug 25, 2017 at 9:06 AM
    #71
    nzbrock
    Noah
    San Marcos, TX
    Sorry I'm an idiot, haha. I just realized that is the point, to swap in a A340E in place of the A44D.
    MrCrowntown[QUOTED] likes this.
  12. Aug 25, 2017 at 9:07 AM
    #72
    nzbrock
    Noah
    San Marcos, TX
    Hence the title of the thread, haha. I really should read more carefully.
  13. Aug 25, 2017 at 9:08 AM
    #73
    MrCrowntown
    Alyn
    Ky
    Don't sweat it :)
  14. Aug 25, 2017 at 9:08 AM
    #74
    BartMaster1234
    Tyler
    Flux Capacitor
    Haha don't worry it all happens to us at some point.
  15. Aug 25, 2017 at 9:48 AM
    #75
    nzbrock
    Noah
    San Marcos, TX
    Just to add some useful info, here are the wiring diagrams for the 2RZ transmission (A44D) and 3RZ transmission (A340E or F)
    As you can see the wiring is very different. If you don't know how to read wiring diagrams this will be confusing.
    The part you should be concerned about is how it connects to the ECU. On the 3RZ diagram you can see that there are many more wires going into the ECU related to the transmission. On the diagram where the wire runs into the ECU, there is a letter and number. This letter corresponds to the physical connector A, B, C, D and number corresponds to the pin in that connector. It appears that the 3RZ (A340E) has an extra connector "D". I suggest you make a list using these diagrams using the connector letter and pin number and letter labels on the ecu in the diagrams. IE: Connector A, pin 1, BATT for the 2RZ. Do this for both diagrams and compare to see what is missing.
    If everything matches up and you are just missing that extra D connector, you may actually be prewired for it. You would just have to figure out where that connector is.
    That D connector is actually the connector that would plug into the ECU. I do not know if the 2RZ ecu is wired for this.
  16. Aug 25, 2017 at 10:05 AM
    #76
    nzbrock
    Noah
    San Marcos, TX
    OK @Austin_Mike I just reread everything in this thread. ARE YOU SURE YOU HAVE A 3RZ PRERUNNER? Because you definitely have a A44D transmission in your truck currently. That transmission only comes on the 2RZ 2.4L 2WD 5 lug trucks.
    3RZ = 2.7L
    2RZ = 2.4L
    A prerunner is a 6 lug truck that is the same as the 4wd trucks, just without 4wd.
  17. Aug 25, 2017 at 11:15 AM
    #77
    MrCrowntown
    Alyn
    Ky
    @nzbrock ^^^^^^
  18. Aug 25, 2017 at 4:00 PM
    #78
    nzbrock
    Noah
    San Marcos, TX
    Yea I know the donor is a 3RZ (the transmission pictured on the pallet), but the OP posted pictures of his current transmission and it is not an A340E. It is definitely an A44D, which did not come on a 3RZ. OP has not posted the VIN of his truck, unless I missed it.
