aal for my 05 AC....
Discussion in 'Suspension' started by prjctTACO, Oct 13, 2013.
  1. Oct 13, 2013 at 11:12 PM
    prjctTACO
    prjctTACO [OP] Well-Known Member
    bay area, ca
    05 pre-runner AC trd
    Ladder Rack
    I have an 05 AC with flat rear leafs. Probably happened since i have a lumber rack and couple hundred lbs of tools i haul around everyday. I found a low mileage pair of OEM toyota 3 leafs for cheap. Can i pick these up and install a AAL?? Can you guys recommend me a AAL for heavier loads?? Would I need to run longer rear shocks?? Would I keep my oem overload leaf??
  2. Oct 13, 2013 at 11:14 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I have a 2013 taco and mine are basically flat dealer said it was normal. But I don't see how. Dakar, deaver have your search this forum there has to be lots of answers about all
  3. Oct 13, 2013 at 11:25 PM
    prjctTACO
    bay area, ca
    Ladder Rack
    I was planning to keep the fronts stock height. I dont want to lift my work truck. I'm hoping the AAL will keep me close to OEM height, with a better load capacity...The truck squats really easily with just a small load of heavy material. Ride sucks when loaded. I can feel it riding on the bumpstops the last time i hauled about 15 pieces of 2x4's.
  4. Oct 13, 2013 at 11:40 PM
    tacodane
    Dane
    Id see what your dealer says, mine says they have a company ( don't remember at the moment ) but they aal to most of there truck that begin to sag in the rear. Id add a Dakar or deaver. check the vender section I know some vendors sell aal on there sites
  5. Oct 13, 2013 at 11:42 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    you could do a add a leaf, new leaf pack, or you could refurb your springs, i'd PM 4WD and see what load capacity you could gain while staying close to stock height.
