AAL help...
Discussion in 'Suspension' started by All Beef Taco, Apr 11, 2010.
  1. Apr 11, 2010 at 4:11 PM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    I tried to install my new Toytec AAL set but ran into some trouble. I'm not sure I'm doing it right- I wasn't able to get the leaves to pull away from the axle when I lowered it. I supported the frame, unbolted everything, etc... But with my jack under the rear diff and lowered all the way to its lowest setting I still didn't have room to separate the leaves from the axle and get my AAL in. Does this mean I didn't Jack the frame up high enough? Is there a different way to do this?
  2. Apr 11, 2010 at 4:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like you didnt jack the frame high enough. Use longer jack stands, or put some large wooden blocks under them to get the extra height.
