AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Mar 30, 2013 at 9:22 AM
    #321
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeah. Either the AAL is oriented in the wrong direction, or its the wrong AAL for that leaf pack. You need an AAL designed for the "TSB" leaf springs.
  2. Mar 31, 2013 at 8:30 AM
    #322
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I've just read through the 17 pages of this thread. The question I didn't see answered is:
    Will factory length U-bolts work with tsb springs and a 1.5 inch AAL?
    The reason I ask is I've heard some sites you can buy U-bolts from are cheap quality steel. If that's the case I'd rather order new ones from the dealership.
    Could you recommend any sites to order quality bolts from?
  3. Mar 31, 2013 at 8:35 AM
    #323
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should, however, U bolts are a "Stretch to yield" bolt, and shoulndt be re used.
  4. Apr 1, 2013 at 6:32 AM
    #324
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Ok thanks. I won't be reusing the old ones, I will buy new from the dealership. Unless I can source out good quality ones. Which ones are you guys using?
    Chris just looking for your thoughts on this... Based on the design of the AAL having more of a curve it seems that it will eventually wear through the rubber pads and then start cutting into the stock leaf pack. Seems that it would need to be replaced after some time.
    EDIT: Just doing some reading on ubolt grades and found this about re-using them. I didn't know the nuts had slightly different threads to reduce the chance of them backing off. Taken from www.truckcomponentsonline.com
    Do Not Reuse U-bolts
    • Used U-bolts will have rusted and damaged threads from the previous installation
    • A previously torqued U-bolt will suffer from distored threads from the engagement of the deep nut. Deep nuts should be tighened once and retorqued, never loosened and retightened.
    • A used U-bolt may have suffered from fatigue as well excessive stress since achieving accurate torque with commonly used impact wrenches is very difficult.
    Removed U-Bolts should NEVER be placed back onto the vehicle, they should be thrown away. Suspension U-Bolts are manufactured with a smooth rolled thread, while the mating Hi-Nuts are manufactured with sharp cut threads. When a U-Bolt is tightened to it's recommended torque level, the U-Bolt threads stretch as they mate with the Hi-Nuts. Although, not always visible to the naked eye, this damages the threads. Removing the Hi-Nuts from the U-Bolt will cause a cross-threading that will not allow the U-Bolt to be adequately re-torqued. A common practice in most maintenance facilities is to use a impact wrench to tighten U-Bolts. Consistent, accurate torque is next to impossible to obtain with a impact wrench, and in most cases an over-torqued fastener is the result. We recommend using a torque wrench when installing U-Bolts. New U-Bolts should be torqued after 2 weeks of usage.
    As previously explained the primary function of the U-bolt is to maintain the clamping force on the spring assembly and related parts. Since clamping force is a function of the condition of the U-bolt, the damaged threads of the used U-bolt will make reaching this force very difficult. Considering that reusing U-bolts can lead to premature spring failure and other suspension damage it is clear that U-bolts should never be reused.
  5. Apr 9, 2013 at 8:46 AM
    #325
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Am I the only person that never got the TSB springs put in mine? I bought it in 2006 (it's an 06), and although I worked at a dealership at the time, and although my springs creaked when I had about 2k miles... I never got it done :mad:
    By the time I realized that I could get a new set of springs, I had already moved on to another job, and I was out of warranty.
    Is this going to make it harder to find AAL for my truck? Should I just get some replacement springs from general spring?
  6. Apr 9, 2013 at 10:31 AM
    #326
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    You don't need the TSB to run an AAL
  7. Jun 9, 2013 at 6:57 PM
    #327
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I need some help here.
    I am installing a 4 leaf tsb spring set, with a aal.
    I would like to install a set of energy suspension poly bushings on the leaf ends before installation. Energy only makes gen 1 products until years end. The company will not answer my question. Does anyone know if gen 1 & gen 2 leafs spring ends are the same?
    Thx.
  8. Aug 3, 2013 at 9:52 PM
    #328
    Rincontaco
    Rincontaco Member
    Rincon, Ga
    2013 MGM DC OR
    debadged, mostly.
    quick question as i really need this truck monday for work :)
    Im attempting the aal from wheelers. I have the new leaf in and all the leafs bolted up and when i went to raise the axle to get the pin in its off about 3/4 of an inch. I was thinking that since the other side has not been done that this could be the cause of my misalignment? I figured you guys have seen this movie so ... hoping you guys had the answer.
    I did however manage to get the bilsteins in by myself in the front :D and was super stoked ...kinda thought the rear leaf would have been easier ...:confused:
  9. Aug 3, 2013 at 10:18 PM
    #329
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Youre gonna have to jerk the axel into place. It can shift when lowered, and its not a big deal.
    Malinosan likes this.
  10. Aug 3, 2013 at 10:34 PM
    #330
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I didn't do an AAL but I did install new leaf packs on my truck. So that being said, I would recommend raising both wheels off the ground, put jack stands under the frame, then let the axel drop to full droop. Keep the axle supported with a jack or more jack stands. Add the new Leaf into each side before tightening things up. Now everythng is in its place and just needs to be tightend up, so if the center pins are off by a little, the axle is just hanging there so you can shift it a little to get the center pins ligned up on boths sides.
    I had some of the same issues your having when adding the new leaf packs so I did it as stated above. You'll get it;)
  11. Aug 4, 2013 at 7:17 AM
    #331
    Rincontaco
    Rincontaco Member
    Rincon, Ga
    2013 MGM DC OR
    debadged, mostly.
    Thanks! I did that jerked it over and had a neighbor raise the axle! worked! Thanks a lot!
    Thanks Mainemoe02 also!
  12. Aug 26, 2013 at 8:43 AM
    #332
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thinking about ordering an 1.5' / 2.0' AAL to compliment the OEM Baja that was just installed on my 2013 TRD Sport. (Baja lifts front 2' but no lift in rear)
    My truck currently has 3,600KM's (2,200miles) and came stock with the 4 leaf pack.
    Quesiton, given that it's basically brand new, can I re-use the stock U bolts?
    And, will they be long enough with a 1.5 or 2.0' AAL?
    I really should have just put this in when I had the suspension installed on Friday but oh well...
    Thanks for the help!
    Cheers,
    Jay
  13. Aug 30, 2013 at 11:25 AM
    #333
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  14. Aug 30, 2013 at 12:00 PM
    #334
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not recommended to re use the bolts, but at that age, you shouldn't have any issues.
  15. Oct 7, 2013 at 8:56 PM
    #335
    tim2010
    tim2010 if you ain't first, you're last!
    TimO
    Medina, OH
    '11 MGM access cab 4x4
    OEM Fog Lights (wiring not OEM), Westin brush guard
    Thank you chris and everyone who comment on this post. I had the laptop right next to me with pandora playing and this thread to keep me sane. Not that it was that hard. Much easier than changing the coil overs and adding 2.5 blocks to the front. All said and done, I think it took me 5 hours. I worked slow making sure I took everyone's advice. The 3in aal looks awesome.
    Thanks again all!
  16. Oct 7, 2013 at 9:12 PM
    #336
    tim2010
    TimO
    Medina, OH
  17. Nov 12, 2013 at 5:24 PM
    #337
    Triple D
    Triple D Well-Known Member
    Florida
    07 4x4 Double Cab Sport Pack.
    Over the past few years I have been using this site to take advantage of the DIY info and save $ from the dealers. I've wanted a bit more aggressive look so naturally I chose to do the AAL for the rear.
    Today I installed the 1.5" AAL from Wheelers on my 2007 Tacoma which has the Toyota TSB leaf package. The job was fairly straight forward but had a few hardships since I was working alone. I believe everything is good to go but had 2 questions...
    1. With the tools I had I was unable to get the nut completely tight on the top of the centering pin. There is about an 1/8" space. As long as the centering pin is through all the leafs and the Ubolts are cranked down, could this be an issue?
    2. I noticed that the nuts which screw onto the bottom of the Ubolts don't have thread all the way through them due to me using the original Ubolts and less thread left due to the AAL taking up some room. They're on there at the 73# torque and all appears fine...but should I go get new longer Ubolts so that they have more thread to lock on to?
    Thanks!
  18. Nov 12, 2013 at 5:54 PM
    #338
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    its always a good idea to get the top nut tight against the springs, so as to leave no gap. That being said, you should be OK with it how it is.
    As long as there is about 1/8" threads, or more, exposed after the nut, you will be fine.
  19. Nov 12, 2013 at 6:04 PM
    #339
    Triple D
    Florida
    Thanks Chief!
  20. Nov 13, 2013 at 3:34 PM
    #340
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Now thats' phunny...:D
