AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Jul 29, 2014 at 11:06 AM
    #361
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    What about the other clamps at the end that hold the other leafs together? Won't the AAL hit those?
  2. Jul 29, 2014 at 12:07 PM
    #362
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Not if its the right length
  3. Jul 29, 2014 at 12:08 PM
    #363
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I called Wheelers and they said to just grind it off and use the clamp that's on the AAL.
  4. Jul 29, 2014 at 12:09 PM
    #364
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    3 leaf aal?
    sounds bout right.......... same with Icon
  5. Jul 29, 2014 at 12:11 PM
    #365
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Yes, it's the wheelers progressive HD 3Leaf AAL!
  6. Jul 29, 2014 at 12:13 PM
    #366
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Really ??, See, thats bullshit if they're going to mass produce an AAL why not take that into consideration when they design it, should'nt have to cut/grind anything thats still on the truck (oem)
  7. Jul 29, 2014 at 12:15 PM
    #367
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I think he said those clamps position can vary slightly so sometimes they might interfere and sometimes they don't...
    Doesn't really matter to me, but I do agree with you!
  8. Jul 29, 2014 at 2:44 PM
    #368
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The "TSB" spring pack, is on relatively few Tacomas, given the amount produced between '05 to present. To have to re tool to accommodate a small percentage isn't cost effective.
  9. Jul 29, 2014 at 2:52 PM
    #369
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    plus IIRC that aal is used on tundras
  10. Nov 17, 2014 at 8:39 AM
    #370
    softail
    softail Member
    wayne
    bathurst nb
    2013 tacoma trd quad cab 4x4
    2.5 front lift with 1.5 lift in rear
    hi Chris question how is the ride after installing the AAl I have a 2013 Tacoma trd I installed a 2.5 lift in front and a 1.5 block lift on the rear lost my ride as soon as I lifted the rear should I cancel the blocks and go with AAl all im looking for is as near factory ride just curious on the difference on the ride compared to blocks all info much appreciated Wayne
  11. Nov 17, 2014 at 9:39 AM
    #371
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    it depends on which AAL is installed. The icon AAL has the best ride, imho.
  12. Nov 18, 2014 at 8:32 AM
    #372
    Denteen
    Denteen Well-Known Member
    D
    Central valley CA
    2018 TRD Sport 4x4 DCSB
    TRD Pro suspension-2nd Gen Frontrunner bed rack Tacowiede radio knobs! Best mod everrrr!!! DSM mount Wheel swap to OR’s. For now... Gone-2005 DC Icon Stage 2 with Rear Resis;ICON 3 leaf AAL installed! Gone-2001 xcab 4x4 4cyl 5spd. Best truck ever...
    Completely agree with Chris! My 2005 Tacoma was night and day after getting rid of the original 'crap' and going with Icon shocks all around (resi in back, although overkill for my purposes) and Icon AAL. You will NOT be disappointed. Surf around, I got a good deal on the AAL from a smaller outfit, although I don't remember their name anymore. Its been a while.
    I wish I had Icons on my 2007 FJ! Bilsteins are fine, but they are no ICONS!!!
  13. Nov 18, 2014 at 11:45 PM
    #373
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Just to confirm what's been brought up, with the Icon, and possibly also with the Wheeler's 3 leaf AAL, when installing on the OEM four leaf pack one of the factory leaf clamps per side must been cut/ground away.
    Now in the case of Icon...
    What they fail to mention, and I've seen this personally on another 2014 DCSB TRD OR, is that when installing their 3 leaf AAL on a vehicle running the factory four leaf pack, the forward most AAL pack clamp on the drivers side comes in contact with the fuel tank mount. I also heard from a couple members on this site with the same problem, varying in severity.
    Installing the bolt so that the threads/nut face outwards towards the wheel lessen the severity of the issue, but after that and some grinding of the clamp itself minor contact is still made under daily driving conditions.
    I spoke to Icon about it, and their solution was just taking some measurements and if it looks like it'll work, flipping that leaf around and running it backwards. If the clamp isn't hitting anything with the spring reversed, then leave it. I haven't done this because I'm not a huge fan of the idea. Instead I'm trying to find a bolt with a thinner head to replace the Icon supplied one on the clamp. That and/or a little more grinding. They sum the problem up to be Toyota having huge tolerance allowances, up to one inch (their words, not mine). I dunno about all that but whatever.
  14. Nov 19, 2014 at 5:16 AM
    #374
    softail
    softail Member
    wayne
    bathurst nb
    thanks for the info ill give it a try
  15. Dec 3, 2014 at 4:53 PM
    #375
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Can these instructions be used on a 1st Gen (1996)?
  16. Dec 7, 2014 at 6:04 AM
    #376
    Jwbfx4
    Jwbfx4 Active Member
    Bama
    14' dcsb trd
    Well I was on the fence about doing this myself or not but I think I'm going to give it a try. Thanks chris for the write up and detailed instructions.
    But I do have one question. Bolting the shocks back up concerns me a little bit. I have read the whole thread and really haven't seen much mention on it. But are they not under a little pressure or real hard to get lined up? Thanks.
  17. Dec 7, 2014 at 7:49 AM
    #377
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are very easy to re install. Not enough pressure that you cant collapse them by hand.
  18. Dec 7, 2014 at 11:58 AM
    #378
    JAL
    Mississippi
    Can these instruction apply to 1st Gen too?
  19. Dec 7, 2014 at 12:05 PM
    #379
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup. Shock location is slightly different, but same technique is used.
  20. Dec 7, 2014 at 2:32 PM
    #380
    JAL
    Mississippi
    Thanks
