AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Dec 20, 2016 at 7:48 PM
    #521
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    Thanks!
  2. Jan 10, 2017 at 10:55 AM
    #522
    knoxtoy
    knoxtoy Member
    2013 Tacoma Sport
    Will Adding a Leaf raise the back? (front will look lower?) I would like my truck to look leveled if I decide to AAL. TIA
  3. Jan 10, 2017 at 12:52 PM
    #523
    dumontrider
    dumontrider Well-Known Member
    Cerritos, CA
    05 PreRunner V6, 5A, AC
    Too many mods for a PreRunner!
    Yes it raises the rear only. I believe stock the front is about 2" lower than the rear, maybe a bit more, so depending on the AAL you go with you can brain the math on what's needed for the front to be level.
  4. Jan 10, 2017 at 12:53 PM
    #524
    T4RFTMFW
    T4RFTMFW 10% OFF
    It's usually 1.25-1.5" of rake, so far as I've seen.
  5. Jan 10, 2017 at 12:54 PM
    #525
    dumontrider
    Cerritos, CA
    Ah yes, I had 885's and it was level but I forgot I had an AAL back there at the time.... 885's w/o AAL would be bro-tastic! I stand corrected.
    Tac11 and MTopp like this.
  6. Jan 12, 2017 at 9:29 AM
    #526
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    Did mine yesterday using this and was pretty ease. One side took me an hour first time and another half couse I put stock shim from bottom between aal and stock leafs. Other side took 40 min. I also did shocks so that added some time.
    Lord Helmet and MTopp like this.
  7. Jan 13, 2017 at 11:59 AM
    #527
    GarageGirl18
    GarageGirl18 Active Member
    05 TRD dbcb
    Awesome write up.. Thanks a ton!
    rmepilot, Lord Helmet and MTopp like this.
  8. Feb 22, 2017 at 9:06 AM
    #528
    BarefootBandit
    BarefootBandit Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    When my frame was replaced they had cut the bolts to recover my non-tsb AAL's, and because of that they had to give me my truck back without the back lifted.
    I still have the AAL sitting in my garage, and my bro-lean is to the max.
    If I buy new bolts and put back in my Toytec Non-TSB AAL into my new TSB springs, will I have any problems? other than more lift that expected? I don't mind if the rear is higher than the front, in fact I prefer it.
  9. Feb 22, 2017 at 9:25 AM
    #529
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    There may be clips in the way. The best you can do before buying/installing anything would be to get under the truck and set your AALs up next to your new leafs and see if there might be any interference with the clips.
  10. Feb 27, 2017 at 10:23 AM
    #530
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Do you need to replace the cantering pin? Is it just basically a bolt?
  11. Feb 28, 2017 at 9:43 AM
    #531
    Whitetrash
    Jimmy
    its basically a bolt that is a "cut to fit" style. but the head of the bolt is in the shape of a circle, you wouldn't be able to get a socket on it even if it was 6 point bolt. when you get the nut tightened to the proper torque of your choice, you can do what I did if you like, i left about 1/2 inch of threads and cut the rest off with a dremel tool. then put the bump stop back on top of it and everything fit together perfectly.
    maxpower29 likes this.
  12. Mar 5, 2017 at 2:54 PM
    #532
    maxpower29
    Jordan
    Nova Scotia, Canada
    Thanks Ill grab something and figure it out
  13. Mar 6, 2017 at 6:17 AM
    #533
    xJuice
    Josh
    North DFW
    07 DCSB Sport 2wd
  14. Mar 19, 2017 at 9:03 AM
    #534
    donny
    donny Well-Known Member
    don
    San Jose Bay Area
    2008 DCLB
    Next on my list of things to after shocks
  15. Mar 19, 2017 at 9:10 AM
    #535
    donny
    don
    San Jose Bay Area
    2008 DCLB
    What brand of AAL. Wheelers , toytec ,tough country???
  16. Mar 19, 2017 at 12:05 PM
    #536
    maxpower29
    Jordan
    Nova Scotia, Canada
    I had the deaver but its currently snapped in half on my garage floor.....so I may be the wrong guy to ask
  17. Mar 31, 2017 at 5:36 AM
    #537
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va
    2016 Blazing Blue DCSB TRD Sport 4X4
    Bedrug, LED headlight/fog light conversion
    I will be doing an add a leaf at the end of June and I will be referring back to this so thank you for doing the write up for us.
  18. May 15, 2017 at 9:02 PM
    #538
    koloheboy
    koloheboy Well-Known Member
    Paul
    PDX
    2017 Toyota Tacoma TRD OR DCLB
    Overland wannabe build on OME, SCS Ray 10, KBRO2's 285/75/16
    3rd Gen owners - these instructions will work for your AAL install. I just did my Deaver single AAL and followed the steps, except that you don't need to remove the bolt for the brake lines on the axel.
    Grand dude likes this.
  19. Jun 3, 2017 at 3:07 PM
    #539
    Robosko
    Robosko Well-Known Member
    Houston
    14 DCSB TRD OR
    I have the same question. Did you guys cut if off? I'm just hesitant to use the dremel right by the brake line.
  20. Jun 3, 2017 at 6:00 PM
    #540
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    I ended up not cutting anything off, just zip tied it up and haven't had any problems
    Robosko likes this.
