AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Jun 20, 2017 at 10:47 AM
    #541
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I can't remember... Are the deaver aals directional? Front and back or it doesn't matter which way?
  2. Jun 20, 2017 at 11:05 AM
    #542
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Yes - short side goes toward the front. I think. Or maybe the back. There's definitely a right and a wrong way though.
  3. Jun 20, 2017 at 11:41 AM
    #543
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Ok thanks. Gonna check tonight. Might have installed backwards
  4. Jun 20, 2017 at 1:42 PM
    #544
    RyanL
    Indiana
    From an Icon AAL thread
    There's a discussion in that thread about installing it backwards, maybe intentionally ... not really sure what's going on with those guys.
    dirtnsmores likes this.
  5. Jun 20, 2017 at 2:24 PM
    #545
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Thanks for helping. I just got off the phone with deaver. They said some or their single AALs are made with the hole in the center. Sure as shit I went outside and measured and it's in the middle. Was hoping they were installed wrong because I lost some height in the past year. Dakars coming soon
    RyanL[QUOTED] likes this.
  6. Jun 22, 2017 at 6:32 AM
    #546
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    I just did this on my 3rd gen and it was a lot easier than i thought it was going to be. I only had to remove the clip for the parking brake cable and didn't have to remove the other brake line clips on mine. I rented a bay at the hobby shop on base and was able to do the install by myself.
    ready6delta and RyanL like this.
  7. Jul 4, 2017 at 9:52 AM
    #547
    rcchris
    rcchris Well-Known Member
    Halifax
    '12 v6 4wd access cab auto black
    Pics no longer show up on original post?
  8. Jul 15, 2017 at 12:04 AM
    #548
    Tacoma_Wa253
    Tacoma_Wa253 Well-Known Member
    Sav
    Tacoma Washington
    07 Taco
    Can anybody verify. Bought a used deaver aal and gonna install it this weekend
  9. Jul 15, 2017 at 5:59 AM
    #549
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    My deaver leaf was 14" both sides. no way to put it backwards
  10. Jul 22, 2017 at 6:06 PM
    #550
    AdventurousTurtle
    AdventurousTurtle Well-Known Member
    2005 Tacoma TRD Off Road
    2 inch leveling kit
    Hello! So I've got two questions on this one.... I bought my truck with a procomp lift on it. The truck just turned over 105K and I have no idea when the lift was put on - I'm assuming very early in the trucks life given the bushing wear and slowly fading shocks. I'm looking at putting an icon stage IV complete kit on and was wondering if I would be able to add their AAL pack to the AAL that's already on the truck. For whatever reason, Toyota replaced my leafs under the TSB like 4 months ago so my leaf kit is basically brand new besides the old AAL. Second question is does anyone have experience with the icon AALs (install and/or quality)? Thanks!
    EatSleepTacos likes this.
  11. Jul 28, 2017 at 5:44 AM
    #551
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    2017-07-28-08-38-33.jpg 20170727_172506.jpg There's been some questions about the torque spec the ubolt nuts so I thought I'd share this....OP mentions a torque of around 75 ft/lbs which seemed reasonable to me; however, another member mentioned a torque over 100 ft/lbs.
    Here are the Icon AAL instructions for the kit I just installed last night. It reads 120 ft/lbs.
    I'm guessing this higher torque is due to adding more height to the spring stack.
  12. Jul 28, 2017 at 5:47 AM
    #552
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was in a similar boat. I just bought an 05, but the leafs were recently replaced. Since they're brand new, I opted for an AAL in the interim until I get a new leafpack in a year or two. As far as install, it's pretty much the same procedure as this, except the overload leaf gets removed.
  13. Jul 28, 2017 at 5:49 AM
    #553
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I just installed an Icon progressive AAL last night and the install was straightforward and not too difficult. I kept the overload in as I will be pulling a 3000lb travel trailer. I gained about 2 inches from ground to fender over my rear wheels but i expect it will settle some. I'll post before and after pictures later.
    Grand dude likes this.
  14. Oct 7, 2017 at 6:46 PM
    #554
    Baxter_2010
    Baxter_2010 Member
    Baxter
    2010 dark gray Sr5 4x4 dcsb
    Not sure if this has been covefed already or not, bit were extended length shocks used for this aal?
    Also, were the brake lines and bump stops modified?
    Thanks!
  15. Oct 7, 2017 at 6:57 PM
    #555
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You'll want longer shocks than OEM, but don't need anything crazy. Some regular 5100s will do. And as far as brake lines and bump stops, no. You won't need to modify them.
  16. Oct 9, 2017 at 6:56 AM
    #556
    Baxter_2010
    Baxter_2010 Member
    Baxter
    So the 0-1" 5100's or the extended length ones? I already bought the aal and was planning on installing it next weekend but saw a bunch of threads of guys saying to use extended length ones.. seems like it's 50/50.
  17. Oct 9, 2017 at 9:23 AM
    #557
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The regular ones are fine. Different vendors give different measurements on it, but they're good for 2.5-3" lift
    RyanL likes this.
  18. Oct 9, 2017 at 10:57 AM
    #558
    Baxter_2010
    Baxter_2010 Member
    Baxter
    Alright thanks, I appreciate the info.
    EatSleepTacos[QUOTED] likes this.
  19. Jan 16, 2018 at 7:01 PM
    #559
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I know this is an old thread Chris,but how much lift if any did you get by putting the add a leafs on ? I have a prerunner and need just a little extra help in the back due too a tool box and tools
  20. Jan 17, 2018 at 5:32 AM
    #560
    rcchris
    Halifax
    This may not be any help to you, but when I put them on, I forgot to measure the rear stock height. I measured the front, and got just about 3", and the truck was sitting pretty much level. I guessed that the rear was raised about 1.5 inch or so.
