AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Oct 23, 2009 at 9:22 PM
    #61
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  2. Oct 23, 2009 at 9:45 PM
    #62
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Haha, I thought that truck looked familiar! How did I miss this?? Great write up Chris! Sorry I forgot my camera...:eek:
  3. Oct 24, 2009 at 7:04 AM
    #63
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worries, We got it. :)
  4. Oct 24, 2009 at 4:19 PM
    #64
    08Taco5-Lug2.7L
    08Taco5-Lug2.7L Member
    David
    Statesboro, GA
    08 Tacoma 5-Lug 2.75" ReadyLift 31" BFG ATs
    2.75" ReadyLift EZLift, 31" BFGoodrich All-Terrain KO, K&N Air Filter
    Would any AAL for a PreRunner or 4x4 Tacoma also work for the 5 Lug version? I have the ReadyLift 5-Lug Lift Kit but one of my AAL's got worn down. Any advice would be awesome.
  5. Oct 24, 2009 at 4:23 PM
    #65
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think so.
  6. Nov 13, 2009 at 10:14 AM
    #66
    DScottT
    DScottT Member
    Nacogdoches, TX
    05 DC PreRunner TRD SR5
    12 v outlet under hood, constant power to cig outlets, console light.
    Chris,
    Are you saying the FSM is wrong. It says the rear u-bolt torque is 50 N-m. 50 N-m converts to 37 ft-lbs. I'm confused, please clarify as I'm adding a leaf next weekend.
    This is where I always check torque values and other unit conversions.
    http://www.onlineconversion.com/torque.htm I've checked their numbers and they have always been right.
  7. Nov 13, 2009 at 10:21 AM
    #67
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. 73 ft-lbs is the correct figure.
  8. Nov 13, 2009 at 11:08 AM
    #68
    DScottT
    DScottT Member
    Nacogdoches, TX
    Chris,
    I'm reluctant to disagree with you because you have been right on so many occasions, but where did you come up with that?
    I just measured the dia. of the u-bolt (14mm) on my truck and checked a metric torque chart. Assuming Toyota uses standard strength steel in these u-bolts, 37 lb-ft(50N-m) is correct. I'm a Mechanical Engineer by education, with that said I know I'm not a expert on Toyota's, but I do know over torquing a bolt is bad. I need to know :confused:
  9. Nov 13, 2009 at 11:36 AM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I checked with about 5 or 6 Toyota mechanics. Also, I tried the 37# on my truck, and found the springs will shift horribly. I also asked a friend of mine who has been working on Toyotas for God only knows, and he said the value was wrong. Over torquing a bolt IS bad, and I understand your relectance. Every U bolt I have torqued has been to about 75#, with no issues. No crooked springs, etc. I HAVE E-mailed Toyota regarding this issue 2 seperate occasions, and have not heard back. I have given up at this point.
    Kbattlefield likes this.
  10. Nov 13, 2009 at 11:51 AM
    #70
    DScottT
    DScottT Member
    Nacogdoches, TX
    That's what I needed to hear. I know manuals are not always right. I suspect they are actually using a higher strength bolt, which needs a higher torque, but the manual writers are using the torque chart I used. It happens in my businesss too often. You da man. Thanks!!:thumbsup::thumbsup:
  11. Nov 13, 2009 at 11:52 AM
    #71
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help :)
  12. Nov 16, 2009 at 5:51 AM
    #72
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    is longer u bolts needed, or the stock ones will still work?
    lookin at the toytec 2" aals
  13. Nov 16, 2009 at 6:46 AM
    #73
    Packman73
    2007 TRD Off Road
    New ones are needed.
  14. Nov 16, 2009 at 6:46 AM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. You need longer U bolts.
  15. Nov 17, 2009 at 5:29 PM
    #75
    671taco
    Guam
    twenty-ten rc
    damn i just contacted toytec and they said they dont ship to guam:mad:
    any where else i can find a good 2" aal with u bolts??
  16. Dec 14, 2009 at 8:47 AM
    #76
    MC1983
    MC1983 Well-Known Member
    Mark
    Indianapolis, IN
    2005 DCLB
    Does anybody know which leaf spring goes on which side? I bought a used pair of TSB leafs with aal since the dealer denied me for the tsb. I want to install them, but not sure which side they go on. I believe the springs were stamped with RH and LH after the part number. Does anyone know which spring goes on driver and passenger?
  17. Dec 14, 2009 at 4:43 PM
    #77
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The one marked RH is the passenger side.
  18. Dec 14, 2009 at 7:53 PM
    #78
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    Try they seem like a respectible outfit.:)
  19. Dec 18, 2009 at 3:16 PM
    #79
    Will Prerunner
    Will Prerunner Well-Known Member
    Tempe Az
    01 TRD Prerunner Doublecab
    Trail-Gear rock sliders, OME Lift, kobalt tool box, herculined fender flares, CrossFab light bar, Deck plate Mod, Differential Breather Extension, 32"goodyear duratracs Pioneer 3 way speakers, alpine head unit, Boss Bass 600 sub, custom az pinstriping
    Great write up, just installed AAL's and shocks in the back and it is really nice to have pictures to go along with it. This is my first time taking anything apart on my truck and everything went smoothly, so far. Thanks Chris.
    Don't know about second generation, but on my first generation the old u-bolts were more than long enough.
    Malinosan likes this.
  20. Jan 3, 2010 at 1:49 AM
    #80
    mbaltonv
    mbaltonv Active Member
    Moscow, ID
    02 extra cab manual 4x4 TRD
    Front Bilstein 1500's 2.5", 1.24" rear schakel, 2" rear AAL, Swaybar disconnect, 265X75R16 BFG T/A ko
    The stock U-bolts will work, at least on the 1st gens.
