AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Jan 3, 2010 at 6:11 PM
    #81
    JAG
    JAG Well-Known Member
    subbed
  2. Jan 3, 2010 at 6:13 PM
    #82
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good write-up 4x4.
  3. Jan 3, 2010 at 6:56 PM
    #83
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Jan 14, 2010 at 7:17 PM
    #84
    vicstacoma
    vicstacoma Guest
    Install the new centering pin, and tighten down snug. No torque value to this, just get it tight.
    Then, Cut the excess threads off the centering pin, leaving about 1/4" of thread exposed, then raise axel back into position:
    can someone tell me why everyone cuts the excess threads off the centering pin???
    I did the AAL and did not cut the excess threads from the centering pin and does not affect anything at all.. is it just for looks?? so it looks better??.. i know the instructions also said to cut the excess..
  5. Jan 14, 2010 at 7:31 PM
    #85
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The excess threads get cut off to allow the bump stop to fit correctly.
  6. Jan 14, 2010 at 7:54 PM
    #86
    vicstacoma
    vicstacoma Guest
    it fits perfectly fine without cutting the excess threads... the only reason i can see people cutting it off is just for looks... it does not affect anything in anyway... if it does can someone tell me how it affects something?? if it does i'll get back in there and cut the excess...
  7. Jan 14, 2010 at 8:29 PM
    #87
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Perhaps in your truck it does. I have not seen a truck that doesnt need the center pin cut down. Unless, an OEM center pin is used. In which case, it may come the correct size. I use a universal centering pin most of the time. They are 8" long, and most assuredly need to be cut.
  8. Jan 14, 2010 at 10:15 PM
    #88
    vicstacoma
    vicstacoma Guest
    well the centering pin does stick out quite a bit, it's way longer than the stock centering pin that's for sure. But it doesn't get on the way of anything else so i just left it like that. I was gonna cut it, but then thought to myself there was no reason to do so and my brother took a look at it too and agreed so i guess i'll leave it like that!!
  9. Jan 14, 2010 at 10:20 PM
    #89
    vicstacoma
    vicstacoma Guest
    ur right,,,, i think the set up for you guys with second gen tacomas is a little different and the excess thread needs to be cut off to fit the bump stop that goes over it right??? i was just looking at the pics and noticed that.. and well i have a first gen so it does not have the bump stop on top of the centering pin!!! That is probably the reason im guessing... right???..
  10. Jan 15, 2010 at 6:59 AM
    #90
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The First gen 4x4's and Prerunners DO have a bump stop that goes over the center pin. If yours doesnt, looks like your missing it, or it fell off.
  11. Jan 15, 2010 at 7:16 AM
    #91
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    X2 - definitely have the bump stop on my 2001, and my centering pin DID need to be cut so the bump stop fit over it correctly.
  12. Jan 15, 2010 at 11:11 PM
    #92
    vicstacoma
    vicstacoma Guest
    yeah mine doesn't have a bump stop.. don't know if he previous owner might have taken it out or if it feel off, but it's missing on both sides. Do you guys know if it's really necessary?? what's the purpose for it???
  13. Jan 16, 2010 at 3:35 AM
    #93
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It stops the suspension from hitting the frame. I think its necessary.
    Malinosan likes this.
  14. Jan 16, 2010 at 7:26 AM
    #94
    vicstacoma
    vicstacoma Guest
    oh i see thaNKS. i'm gonna have to buy them then!! anyone have an extra they would want to sell me???
  15. Jan 28, 2010 at 8:47 AM
    #95
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Used this write-up to help another member install AAL last night. Had a complication when the axle dropped a little further than I intended and then moved back so the pin didn't line up anymore. Nothing a little creative winching couldn't fix.
    ancient11 likes this.
  16. Jan 29, 2010 at 11:29 PM
    #96
    scrapedface
    scrapedface Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    damn i used the stock u bolts on my 2nd gen. the ones in the aal kit seemed way too long. i got 1/8th and inch thread sticking out on the stock ubolts. so i figured it was fine. should i switch it to the longer ubolts that came with the aal?
  17. Jan 30, 2010 at 6:33 AM
    #97
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    If you think you have enough threads I guess you'd be fine but Chris4x4 told me not to use the stock ones. He'd be better to ask.
  18. Jan 30, 2010 at 7:33 AM
    #98
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not recomended to re use U bolts. That being said, I have done so in the past, but be sure to not over torque them.
  19. Feb 15, 2010 at 7:20 PM
    #99
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Are Shackles worse than AAL? Any comments on shackles would be helpful
  20. Feb 15, 2010 at 7:37 PM
    #100
    drew02a
    San Antonio, TX
    You can't get a shackle lift unless you do a shackle flip kit first. It's a little difficult, but you can get it from Armor Tech here on the forum.
    With a shackle flip, you get more articulation and lift without stiffer springs.
    AAL is way easier though.
