AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Feb 15, 2010 at 7:40 PM
    #101
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
  2. Feb 15, 2010 at 7:42 PM
    #102
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I'm a tard, you have a 1st gen. The flip kit is only required for 2nd gen trucks.
  3. Feb 15, 2010 at 7:44 PM
    #103
    YellowDog01
    04 4x4
    haha no I'm a tard..I posted this on a 2nd Gen thread.
    Thanks for the help
  4. Feb 15, 2010 at 8:11 PM
    #104
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I see there is some confusion about the torque specs of the U bolts. Chris says the torque is 73 ft-lbs. The FSM (What is FSM an acronym for?) states 37 ft-lbs. I have a subscription to alldatadiy.com and it also states 37 ft-lbs. Does alldatadiy.com get their information from this FSM?
    I'm installing an AAL and 2* shims on top of my TSB springs this week. I'm sitting here looking at the new U bolts. They are big and beefy which makes me think 73. The thread is kind of fine which makes me think 37. However, the nuts are like an inch tall which makes me think it has plenty of purchase for 73. I also plan to pay attention to the force required to remove the U bolts on my recently done TSB's.
    I'm trusting you on this one man and going with 73...
  5. Feb 15, 2010 at 8:14 PM
    #105
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeah. I have talked with a bunch of people that think the 73# is correct. I personally, have never seen a U bolt torque spec as low as 37 ft- lbs.
  6. Feb 15, 2010 at 8:16 PM
    #106
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Listen to Chris! He does all the work on my truck and my truck hasn't blown apart and hurt anyone yet...well there was that one time...:eek:
  7. Feb 15, 2010 at 8:34 PM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!....:eek:
  8. Feb 15, 2010 at 8:59 PM
    #108
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I used to have a first gen, I swapped the factory springs with AAL for new leafs. Thus i still have the 1st gen leafs and AAL in my garage. I now have a 2nd gen with 3 leaf packs and no warranty which means no TSB. The truck was lifted when I bought it with spacers up front and blocks in the rear. It sits perfectly level right now but i want some extra strength in the rear for this summer when I hook up the boat. This said, I am still trying to figure out, Is there a difference in 1st and 2nd gen AAL? How much lift do you get from them? I have 265/70/17 and i measured from floor to fender 38" if that helps.
  9. Feb 15, 2010 at 9:10 PM
    #109
    mbaltonv
    mbaltonv Active Member
    Moscow, ID
    02 extra cab manual 4x4 TRD
    Front Bilstein 1500's 2.5", 1.24" rear schakel, 2" rear AAL, Swaybar disconnect, 265X75R16 BFG T/A ko
    Shackles are great if you want a short lift. I have both on my Taco, and they are better than a block lift. The AAL adds to a stiffer suspension but also more load capacity. If you are in an area where you rock crawl, then don't go with a AAL as it reduces your flex slightly. I moved to Idaho and there are no rocks in the north to crawl over so the AAL works great for me. I do plan on replacing my springs with Alcan springs sooner or later.
  10. Feb 26, 2010 at 3:22 AM
    #110
    bigEEEEE
    bigEEEEE been rampin dem tacos since dey were introed
    big E
    bay area
    07 dub cab long bed 4x4
    ome shox arb bumper access tonneau
    i put an arb bumper on my taco after a lil incindent w a tree and added ome shocks up front. i believe that w the weight of the bumper the lift comes in at 1.75 in. im going one step at a time and want to work on the rear susp. because the truck aint level no more. weighing options like a block or add a leaf. i do tow occaisionally what is my best option? what is the right height to add? thx in advance ive been trollin these boards for a year and done lotsa the cheap mods suggested yall are awesome.
  11. Feb 26, 2010 at 7:53 AM
    #111
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do an AAL over a block.
  12. Mar 3, 2010 at 6:29 PM
    #112
    Hugebergen
    Hugebergen Crash and burn live and learn
    Saskatoon Sask
    3"Toytec ULK, box mat, angle brackets in box corners for tie downs, anytime fog lights, bhlm, black grill and lip, trimed front flaps, 7089 procomp rims with 285/75/16 Toyo M/T tires, black badges with trd badges added,anytime foglights, lamin-x yellow fogs, illuminated 4x4 switch, colour match satoshi, Camburg ball joint UCAS.
    how tight do you tighten the top of your rear shock with the rubber bushings?
  13. Mar 3, 2010 at 6:35 PM
    #113
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    15 ft - lbs.
  14. Mar 4, 2010 at 6:29 AM
    #114
    Hugebergen
    Saskatoon Sask
  15. Mar 4, 2010 at 10:15 AM
    #115
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    Is this virtually the same for installing an AAL on a 1st gen?
  16. Mar 4, 2010 at 11:33 AM
    #116
    4x4Tacoma
    4x4Tacoma Well-Known Member
    Ben
    Fresno, ca.
    08' Tacoma, RR lock 295/75/16 MT 3" level kit
    3" leveling kit by Hell Bent Steel, 295/75/16R mud tires
    Great Diy. Thanks. Do they have a breather mod for the front and rear diff?
  17. Mar 4, 2010 at 6:35 PM
    #117
    somebody1010
    somebody1010 New Member
    I just did the AAL with TSB springs. Took about an hr the first side and half hr on the second. Also put on the 5100's. Tomorrow im going to drop it off for the front and alignment. Will post pics when its finished.
  18. Mar 4, 2010 at 6:52 PM
    #118
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there is a mod for the rear diff breather, but none really needed for the front diff or transfer case, as they are already extended into the engine compartment fenderwell.
  19. Mar 4, 2010 at 7:36 PM
    #119
    4x4Tacoma
    Ben
    Fresno, ca.
  20. Mar 5, 2010 at 4:03 AM
    #120
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just curious, why are you getting an alignment? Did you change the front end as well, or is an alignment needed with just an AAL install?
