AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. Mar 15, 2010 at 9:21 AM
    #141
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Yes agreed. I've thought about this. It is a bit more dangerous. I'm just weary about bending those hard lines at all.
    Even if you dont ratchet them up. Clamping the top two together with c-clamps helps a lot in keeping the holes aligned and giving you just a little more clearance.
  2. Mar 20, 2010 at 11:15 AM
    #142
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I just did my AAL today, took 3 hours doing it by myself but wasn't too bad. The 2nd side definitely took less time than the 1st, and I'm kinda surprised but the ride is actually better than it was before. I don't know if it's because the OEM springs where overloaded with my cap on the back or what, but it feels smoother now. Only thing I'm wondering is how long does it take the springs to settle?
    Malinosan likes this.
  3. Mar 20, 2010 at 4:13 PM
    #143
    weidjd
    weidjd Well-Known Member
    '10 DC TRD OR 4x
    Saw COs/RR,TSB + 1.5AAl, LR UCAs
    So i can reuse mt TSB ubolts for 1.5" aal?
  4. Mar 20, 2010 at 4:54 PM
    #144
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I think ideally its best to use new, but I reused mine as they were new in november. There's plenty of thread left for a single AAL, don't think a 3 pack type would have worked with the OEM one's though.
  5. Mar 20, 2010 at 5:06 PM
    #145
    weidjd
    '10 DC TRD OR 4x
    Mine are not even two months old and it is just a single leaf. Will I need a new center screw?
  6. Mar 20, 2010 at 5:08 PM
    #146
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Mine came with a new center bolt. My old bolt was cut to even with the nut, so there was no way I could have re-used it even if I'd wanted to. Your AAL's didn't come with new ones?
  7. Mar 20, 2010 at 5:11 PM
    #147
    weidjd
    '10 DC TRD OR 4x
    I will check. Have not got them yet.
  8. Mar 21, 2010 at 7:07 PM
    #148
    waldo
    waldo Active Member
    Cody
    06 Tacoma SR5
    Rough Country 3" lift, 285/75 BFG all-terrains, Moto Metal 951 chrome rims, fog lights, wet okole seat covers
    Great write up! I have a question for anyone carry weight all the time with a canopy. I'm always bottoming out with my stock leafs. How much extra weight do you think I could handle with this added aal?
  9. Mar 21, 2010 at 7:14 PM
    #149
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They dont increase the weight you can carry, but you wont bottom out anymore. :)
  10. Mar 21, 2010 at 10:36 PM
    #150
    waldo
    waldo Active Member
    Cody
    06 Tacoma SR5
    Which company makes the best aal? And are some stiffer then others?
  11. Mar 22, 2010 at 4:10 AM
    #151
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I put Fabtec 1.5's on mine and it lifted the rear about an inch with my cap. It's a heavy sucker, must be about 200lbs or so. I think most people on here would recommend Toytec's, but mine seems to work well. The ride is good, but I can't say how the reliability is since I've only had it 3 days.
  12. Mar 22, 2010 at 4:15 AM
    #152
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I went with wheelers 1.5AAL, same result as kingston73
  13. Mar 22, 2010 at 7:16 AM
    #153
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Best = Dakar
  14. Mar 25, 2010 at 9:54 PM
    #154
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    just bought the 5 lug lift from fat bobs and it came with shocks, aal, and spacers for the front. A few questions...
    Is it completely necessary to remove the rear shocks completely from the axel? I got antsy looking at the box sitting in my room so i cracked and put on the shocks...they were a PITA to get o n and i just might cry if i have ot do it again :p
    And for torqueing the nuts do you use an air compressor of some sort? how do you check it? i usually put it on as tight as i can and a little more.
    im not going to do the install until next week but just wandering.
  15. Mar 25, 2010 at 9:55 PM
    #155
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It makes it easier with the shocks out of the way. Also, use a torque wrench.
  16. Mar 26, 2010 at 11:17 AM
    #156
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    NIce write up!
  17. May 5, 2010 at 12:17 AM
    #157
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    How long would you say until the leaf "settles". The guy @ 4wheelparts told me about 500 miles. Anyone have any other guesstimates?
  18. May 6, 2010 at 9:05 AM
    #158
    4x4Tacoma
    4x4Tacoma Well-Known Member
    Ben
    Fresno, ca.
    08' Tacoma, RR lock 295/75/16 MT 3" level kit
    3" leveling kit by Hell Bent Steel, 295/75/16R mud tires
    It's been bout 500 for me and I still have the height of the 2" but I think I need to retorque them cause I feel the rap back is back It was worse before the aal. But I think it may be due to me having a manual tranny. Alotta tourqe in first gears
  19. May 6, 2010 at 6:06 PM
    #159
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Ok Chris i gotta question for you. On the piece that goes under the axle that the u-bolts go threw. Is there a right or wrong way to put these back on? I noticed mine has a star(*) stamped into them and i didnt know if this was a mark indicating wich direction they were to be installed? I hope i have them installed correctly? Thanks
  20. May 6, 2010 at 6:11 PM
    #160
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You know.....I never paid attention :eek:
