AAL Install. (second gen)
Discussion in 'Suspension' started by chris4x4, Sep 28, 2009.
  1. May 6, 2010 at 6:18 PM
    #161
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nothing in the FSM points to it needing to go in any specific direction.
  2. May 6, 2010 at 6:30 PM
    #162
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    OK cool thanks Chris! I pointed the star forward on both so hopefully there is no right or wrong way?
  3. May 7, 2010 at 6:14 AM
    #163
    taco157
    taco157 Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    Which way does the add a leaf go.... From the center hole it's longer one way than the other.... Long end to the front or rear?? Please help I am putting the lift in as I write this....
  4. May 7, 2010 at 6:16 AM
    #164
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Longer end twards the rear.
  5. May 7, 2010 at 6:18 AM
    #165
    taco157
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    Ok just wondering in your pics it looks like the longer end is towards the front....
  6. May 9, 2010 at 10:03 PM
    #166
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    so if i were to go with billies at 2.5 what size aal should i grab the 1.5 or 2?
    i see some people with a 1.5 and it looks good/level, but i also see some with a 2 and it also looks good
  7. May 9, 2010 at 10:17 PM
    #167
    mbaltonv
    mbaltonv Active Member
    Moscow, ID
    02 extra cab manual 4x4 TRD
    Front Bilstein 1500's 2.5", 1.24" rear schakel, 2" rear AAL, Swaybar disconnect, 265X75R16 BFG T/A ko
    I run mine with a 2" AAL and a 1.25" shackel lift. I personally like to have the bed of my truck higher so when I load it I still maintain a high amount of clearance for off roading. I know that some people like the level look so I would suggest a 1" lift. If you want the stock angel look, then go with the 2".
    Also the springs won't settle evenly so don't freak out in your first couple of weeks with them when your truck lists to one side of another.
  8. May 9, 2010 at 10:26 PM
    #168
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    depends on how much difference you have right now. I have a shell on mine, no tsb, and have a 1.5 on mine. Billies set right now at 1.75. If they don't settle too much, I can set at 2.5 and still be level.
    if you like rake, go with the higher aal. If you want level, go 1.5
  9. May 10, 2010 at 12:54 AM
    #169
    671taco
    Guam
    twenty-ten rc
    yeah im not planning on slamming heavy things on my truck like a shell or a beefy bumper.
    i also dont have the tsb leafs. i want a level ride so i guess ill grab the 1.5
  10. May 10, 2010 at 3:25 AM
    #170
    taco157
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    I put in a 2" AAL and i'm glad that i did, the rear would have been too low if i ever put anything in the back
  11. May 10, 2010 at 3:43 AM
    #171
    671taco
    Guam
    twenty-ten rc
    is there anywhere else i can grab a good 2" aal? i would get the one from toytec but they dont ship to guam
  12. May 10, 2010 at 6:36 AM
    #172
    mbaltonv
    Moscow, ID
    Try "FatBob's Garage", they sell a AAL from Stanley Springs.
  13. May 10, 2010 at 2:52 PM
    #173
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    Awesome Sticky. I managed to get my 1.5" AAL from ToyTec installed in a couple of hours with my laptop on top of my work bench. I've learned more about trucks in the last few months of hanging out on this forum then in the last several years. This place is costing me a fortune.
    Malinosan likes this.
  14. May 13, 2010 at 4:24 PM
    #174
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Did you put 5100s on at the same time as the AAL? Since I'm doing both toytec AAL and 5100s, is it best to go ahead and put the 5100s on when I do the AAL?
  15. May 13, 2010 at 4:29 PM
    #175
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    hehehe...
  16. May 13, 2010 at 4:44 PM
    #176
    Reaper10
    Brandon
    If you're putting the 5100's on the rear then you might as well do it when you do the AAL because you have to remove the shocks anyway. If you're talking about the front end then the worst that will happen is a wicked rake back to front if you don't do the 5100's at the same time. I did the front end on Saturday and the rear end on Sunday. Took about 3 hours each day and I spent a lot of time reading these threads on my laptop while I did the work.
  17. Jun 7, 2010 at 2:46 PM
    #177
    raycie
    Oahu, HI
    In need of $$$
    How long was install for "most" of you?
    As my rear lift drama continues, I am picking up a toytec 2" aal today, which is to replace a 1.5" block, which replaced a 1.5 fabtech aal.
    Would like to do it tomorrow after work.. have at least 4-5 hours of light before I gotta bust out the work lights.. do-able?
  18. Jun 7, 2010 at 3:42 PM
    #178
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    What was wrong with the Fabtec? The reason I ask is that's what I have right now and I'm pretty happy with it. It probably took me, alone and unassisted, about 4 hours total?
  19. Jun 7, 2010 at 3:50 PM
    #179
    raycie
    Oahu, HI
    In need of $$$
    For me.. the fabtech started squeaking BAD..every little stop and go getting out of the truck, closing a door.. I hear that this doesn't happen ALL the time, but is a common problem esp. for AALs that don't have the anti-friction pads. toytec comes with the pads, so I will try my luck with those..
    ALL - Am doing this, and want to do it right.. Did you remove both wheels, and remove the center pin on both sides at the same time? or did you work one side completely, the the other side completely. The pics look like the passenger wheel is still on, until the "dropping of the axel" that pic shows that the pass wheel is no longer on. Could you do steps leading up to dropping the axel on both sides, then lower the axel and add the leaf on both sides, then raise the whole axel up to complete both sides?
  20. Jun 7, 2010 at 3:58 PM
    #180
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don't know if there's a better way to do it, but I took both wheels off and had the truck up on jack stands under the frame. After that, I did 1 side at a time. I don't think I'd want to take both sides off at the same time, too many bolts and pieces laying around, plus you don't have the "together" side to refer to if you forget something. I can't really see any advantage to taking off both sides at the same time, but maybe others can say differently?
    TacoEspecial likes this.
