AAL OR DAKARS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011GTACO, Oct 4, 2016.
  1. Oct 5, 2016 at 8:13 AM
    Pigpen
    Dan
    Northwest Montana
    If you're doing a 3", don't bother with the TSB. You'll end up getting Dakars eventually anyway and someone is paying for all those "free" leaf packs (current/ future Toyota buyers). Do it right the first time. Get extended length shocks. Stock length doesn't allow the Dakars to fully flex (even the OME socks). Make sure you get brake lines too.
    mbmack1 likes this.
  2. Oct 5, 2016 at 8:22 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What is the military wrap feature?
    What is spring wrap? Is it the same as axle wrap?
  3. Oct 5, 2016 at 8:23 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Dakars.
    I load up my truck, but it's nice not having a saggy rear end. Ask @SMKYTXN what it was like when I drive behind him at night.
  4. Oct 5, 2016 at 9:56 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    dakars.....i went both routes on my last taco ('05)...broke an AAL and eventually the main leaf of the oem spring pack before going with the dakars... on newer truck I went right for the dakars... even if you get new set of leafs warrantied from toyota they are still junk
  5. Oct 5, 2016 at 10:01 AM
    O906
    O906 Well-Known Member
    I got my Dakars off Amazon with free shipping because I already had a prime account. Even if you don't have a prime account get them off Amazon and pay for a prime account it'd still be cheaper than shipping. Boom, leafs and a Prime account for a year.
  6. Oct 5, 2016 at 10:04 AM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    Yep, spring wrap is the same as axle wrap. A military wrap spring has a full-length spring just under the main spring that wraps around the spring eye to prevent it from twisting. This works kind of like a traction bar but without sacrificing ride quality or suspension travel. Someone explained to me that it was originally used in military applications, hence the name.
  7. Oct 5, 2016 at 10:36 AM
    2011GTACO
    2011GTACO [OP] Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    If I buy the dakars from @HeadStrong Off-Road do they come with new bushings or will I have to buy new one
  8. Oct 5, 2016 at 11:49 AM
    Ffej
    Ffej Well-Known Member
    Evergreen, Colorado
    '22 TRD OR DCSB
    Bed mat
    I added an AAL to my leaf springs when my truck was new. 30k miles later the rear end is sagging and time for Dakars! Wish I would have spent the extra $300 at the start.
    Get the new leaf pack since you're replacing the front suspension. Might as well have everything new at the same time. I had dakars on my last taco and they rode great with or without weight in the bed.
  9. Oct 5, 2016 at 12:12 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    My rear end has softened with my TSB 3+1 pack, which is only 3 years old now. I put a 2x 45 pound boat batteries in the bed of my truck, and it lowers about 3/4" inch. I stand in the bed, and I can bounce it rather easily.
    Do we need alignment again after installing Dakar packs in the rear?
  10. Oct 5, 2016 at 4:19 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    It's not necessary. I've changed rear ride height by a couple inches at a time and never noticed any adverse effects. It might change the caster and camber slightly, but I would be very surprised if it had any noticeable effect. The toe should be fine regardless, which is what really matters. You could always check the camber yourself with an angle finder, and if it drives fine then the caster is fine too.
    If the alignment is fine now, then it will probably still be good enough that most shops wouldn't even adjust anything if you brought it in.
  11. Oct 5, 2016 at 6:07 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
  12. Oct 5, 2016 at 6:16 PM
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    What's everyone's opinion on a 3-pack AAL? The one(s) that replace the overload spring. TIA
  13. Oct 5, 2016 at 8:57 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I recently installed OME885/5100s in the front and 5100s + single 1.5" AAL in the rear. This is with brand new leafs from Toyota recall. First thousand miles the rear sat a bit higher than front (like stock), which is crazy cuz the front is pretty high on my truck since it's a Prerunner with no armor. But now about 1,500 miles later the rear AAL has settled a bit too much and the truck no longer has rear rake with no weight. Add camping gear and it's barely sagging. It will only get worse. Luckily I got my AALs half price only spent about $50. I think soon i'll be upgrading to Dakars.
  14. Oct 5, 2016 at 9:31 PM
    Pigpen
    Dan
    Northwest Montana
    @ChadsPride has an extra set of bushings he'd send you if you get Dakars.
    HeadStrong Off-Road likes this.
  15. Oct 6, 2016 at 11:05 AM
    #35
    2011GTACO
    Dallas, TX
  16. Oct 6, 2016 at 12:54 PM
    #36
    Pigpen
    Dan
    Northwest Montana
    I sent them to him for free (I covered shipping too) and he didn't use them. If he still has them, I imagine he would be happy to send them to you. @ChadsPride , you can't hide...
  17. Oct 6, 2016 at 12:55 PM
    #37
    T4RFTMFW
    T4RFTMFW Well-Known Member
    HeadStrong has free shipping, so..
    Boom.
  18. Oct 6, 2016 at 12:57 PM
    #38
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Your in Dallas, go check out Toyota of Dallas they do all the TRDPARTS4U website
  19. Oct 6, 2016 at 12:58 PM
    #39
    T4RFTMFW
    It's a nice pack if you're looking for 1.5-2" and want a better unloaded ride than a single leaf AAL offers. The only downside to the 3 leaf AAL is that they're not as strong as a single leaf AAL, so if you're towing, carry a constant load (like a shell), or carry heavy loads regularly I'd go with a single leaf AAL or (even better) a new leaf pack.
    If all you normally carry is a passenger and some camp gear then a 3 leaf is a great choice.
  20. Oct 6, 2016 at 1:02 PM
    #40
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Dakars, no question.
    Get a shock relocate and go to a 12" travel shock if you can.
