AaronArf's 2012 DCSB Build
Discussion in '2nd Gen. Builds (2005-2015)' started by AaronArf, Apr 6, 2012.
  1. Jan 1, 2016 at 11:06 AM
    #1401
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Ok cool. I thought I saw another company but I'm probably mistaken it for something else. Thanks buddy!
  2. Jan 1, 2016 at 11:19 AM
    #1402
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Good deal, I think your comment elsewhere was the one that made me just buy the complete kit. I was just about to buy the ones for the radiator only
  3. Jan 2, 2016 at 9:47 PM
    #1403
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I thought I heard some people didn't like the kit. Made it squeeky and stiff :notsure:
  4. Jan 3, 2016 at 7:25 AM
    #1404
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That was me, if your cab mounts are in good shape I would not change them. Every soft rubber bushing you eliminate you replace it with a harder urethane bushing and with that comes more road vibes. I have had a problem with noise from the bushings that I have only been able to partially eliminate by adding a bit of grease between the washer and bushing but it is only a temp fix and wears off because I think....
    I am suspicious that some of the creaking that I am hearing is the same as what many folks have found with the front of the cab where the pinch welded seams flex and the you hear the layers of the cab mashing against each other. After some research and reading about that issue it seems probable that by removing the rubber body bushings and adding the harder compound bushings that the cab itself is being tweaked because the bushings don't flex enough. IE : every bit of flex in the frame is being transferred into the cab and as the cab tweaks it creaks. Still trying to figure it out but basically from the day I installed the cab mounts my truck has creaked like a bitch. It is an 06' so possibly because it is an older worn out truck and adding the harder bushings is transferring more flex into the cab ?
  5. Jan 3, 2016 at 9:13 AM
    #1405
    AaronArf
    AaronArf [OP] Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    My truck already squeaks and my uniballs chirp o_O leafs sing songs...but haven't heard any additional squeaking from the bushings. Zero lube besides the thru bolts being coated with lots of anti-seize. Also haven't noticed a more harsh ride - already rides like a ton of bricks :yay:
    dakotasyota[QUOTED] likes this.
  6. Jan 3, 2016 at 9:28 AM
    #1406
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    So what your saying is your truck was already so clapped out that you didn't notice :rimshot: I'm guessing the thousands of miles I have on my truck on washboard dirt roads in Baja have wiggled and vibrated the cab a wee bit loose. I do have aftermarket Corbeau seats that are much firmer than the OE seats so that definitely lets me feel every little vibe too...but seriously the creak I have would not bug me if it was external but it is totally inside the cab :/
  7. Jan 3, 2016 at 9:37 AM
    #1407
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Whats driving me nuts is my drive line vibes...my pass seat goes into full seizures at about 68-70mph. haha The squeaks, clanking and all that is just part of the DDing a truck on 35s with beadlocks and wannabe race truck parts.
    lemons likes this.
  8. Jan 3, 2016 at 9:53 AM
    #1408
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yeah I gave up on that and got a double cardon one piece drive shaft from Tom Woods zero vibes now. Hangs a bit lower than OE so prob not the best idea for the rock smashing stuff you guys do...
  9. Jan 3, 2016 at 9:56 AM
    #1409
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Unfortunately not an option for us. I pretty much have accepted the drive line vibes, the new carrier bearing and u-joints w/ a balance from the DS shop helped a bit. Going to toy with CB spacer height to see if I can improve it a bit.
    ChandlerDOOM likes this.
  10. Jan 3, 2016 at 9:59 AM
    #1410
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    I was gonna try spacing mine out too, I need to stop losing wheel weights first.
  11. Jan 3, 2016 at 10:01 AM
    #1411
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Also a problem I have had. I got the "lifetime" balance package at the local Merchant's Tire for a few bucks more so I can just bring it in and have them do it if I determine the wheels are out of balance.
  12. Jan 3, 2016 at 10:05 AM
    #1412
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    #beadlocklife
    AaronArf[OP] likes this.
  13. Jan 3, 2016 at 10:06 AM
    #1413
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Yeah I want to try out dynabeads or something similar (airsoft pellets) Or find speciality weights that actually stick well, its always the adhesive that comes apart
  14. Jan 3, 2016 at 10:09 AM
    #1414
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I bought Dynabeads but decided against actually using them. Too much risk, didn't want to have unnecessary work unmounting/remounting.
  15. Jan 3, 2016 at 12:01 PM
    #1415
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    My winter tires lost a few weights on the last wheeling trip and the vibes were a little unpleasant on my 5k road trip over the holidays. If you have any luck with the other products you're talking about let me know. Tire shop here costs an arm and a leg
  16. Jan 3, 2016 at 12:08 PM
    #1416
    dakotasyota
    Dakota
    Ellensburg, WA
    Got it... Hmm mine aren't the prettiest at 169,000 miles and 10 years. The amount I can jack up the body is shocking...
    But what you're saying makes sense.
    Haha yep just something I need to come to terms with. My candy caned drives me crazy! But I'm gonna make it last thru Moab this year.
    The other thing that drives me nuts is my lower uniballs coming loose. Ever have that issue?
  17. Jan 3, 2016 at 5:13 PM
    #1417
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No issues on mine but I also have race series lowers so no Uniball adapter
  18. Jan 3, 2016 at 9:00 PM
    #1418
    dakotasyota
    Dakota
    Ellensburg, WA
    Ughhhh so mad I didn't get the race kit
    2ndGenJonny likes this.
  19. Jan 4, 2016 at 7:32 AM
    #1419
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    When I bought mine it was less than 300$ difference to go with the race series. That adapter is what sold me on the race series.
    AaronArf[OP] and Acerwin like this.
  20. Jan 4, 2016 at 1:18 PM
    #1420
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Yup me too, along with the weight savings and ground clearance improvements.
    2ndGenJonny[QUOTED] likes this.
