AaronArf's 2012 DCSB Build
Discussion in '2nd Gen. Builds (2005-2015)' started by AaronArf, Apr 6, 2012.
  1. Apr 6, 2012 at 7:53 AM
    AaronArf
    AaronArf [OP] Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Truck was sold to a fellow enthusiast...will update pictures of before I sold it. Also don't hesitate to post or PM me with any questions on the build... Will link to the new owners build thread as soon as he creates one.
    7ce70f5676feb473636d443997134d86_eaa27e8326ca907db90d2422dcd0a353bed3caa5.jpgf7efcf8ef13813c310a6ac746c6feb8b_14156e14078fed7d62eac3b9fbd5fb39a590564f.jpg
    ed65f40f5482fbda4ab41dfb9490fb9e_b13a89f11d2b91b5afeac949ff4653efc39b27f6.jpg27121dc7f604f6abc85d4af16496c554_0412d3142ad8f13c9a39232f571e93e47b20b265.jpg4c74de126ad8a138aae0337c159e62d0_132851ddf4d42f83097aaa52f6155d87e0abb44e.jpg
    2012 4x4 Double Cab Short bed TRD Sport upgrade package w/ ENTUNE
    Modifications
    Armor/Recovery
    Pelfreybilt Front Bumper (Full hoops, Light bar cut out, Fog cut out)
    Pelfreybilt Skids (IFS/MID/REAR/GAS TANK)
    Warn VR10000-S Winch
    Warn Wireless winch controller
    Factor 55 Flat link winch thimble
    Factor 55 Aluminum Hawse fairlead
    Custom Winch Solenoid mounting bracket
    Brute Force Fabrications High Clearance rear bumper w/ swing out & bed side protection
    BEEFED Bolt on sliders with Kick outs (Medium Width)
    Trail Gear Rear Weld-on Diff guard for 8.4" rear (PN: 300655-KIT)
    Pelfreybilt Hi-lift Jack mount
    Pelfreybilt Axe/Shovel mount
    Hi-lift Xtreme 60" Jack
    Suspension
    Total Chaos +2" Race Series Long travel Kit
    ICON Long travel remote reservoir coil overs with #700 Eibach springs, CDC and IVD coating
    Total Chaos Alignment cam tab gussets
    Total Chaos Coil bucket gussets
    Total Chaos Spindle gussets [Sway bar version for extra strength]
    Total Chaos +2 Extended CV axles
    SDHQ High angle CV Boots
    All Pro U Bolt Flip Kit
    ATO Shackle Flip kit
    Rubicon Express XJ shackles
    OME Dakar Leaf Packs
    ICON Hydo Bump kit
    ADS 2.5" Piggyback Reservoir 10" travel rear shocks
    Wheels/Tires
    Method 105 Matte Black Beadlock Wheels 17x8.5 (4.75BS, 0mm Offset)
    Goodyear MTR 35x12.50R17
    Spidertrax 1.25" wheel spacers [REAR]
    Lighting:
    FXR HID Retrofit by Ambiguous (Osram SVS 4300k bulbs, Morimoto 35w ballast, Apollo shrouds, XBAL LED Halo's)
    Famous Fabrication Hood hinge light brackets
    Rigid Industries LED D2 Dually Driving pattern lights
    Rigid SR2 20" Combo Driving/Hyperspot LED Bar
    Rigid D2 Amber Driving LED's for Fog lights
    LED Lights (Dome, License plate, Map lights)
    FLYZEYE V2W LED Dash light
    FLYZEYE 3VP Console light
    Fog light mod (On Anytime)
    886 Bulb Reverse Light mod
    Rock Lights (Oznium LED Modules)
    Interior:
    Weathertech floor mats
    Wet Okole Seat Covers Front & Rear (Charcoal/Black)
    ImMrYo Rear View Mirror relocation bracket
    OTRATTW Switches in custom housing
    Ultra Gauge EM V1.2
    Misc:
    ECGS Assembled Differentials (Nitro 4.88 gears, ECGS solid spacers, ARB Air lockers)
    Stock Fenders & Flares Cut ~4" Front/Rear
    Airflow Snorkel
    Red line Quick lift Plus hood struts
    Stainless Steel Goodridge Extended Brake lines by OCTaco
    K&N Air filter
    Fumoto Oil drain valve
    Blue Sea 5026 Auxiliary fuse panel w/ Blue Sea 7144 100A Breaker
    Blue Sea USB Charging ports (One in bed / One interior)
    Rear Diff breather mod (Toyota PN Union: 90404-51319, Plug: 90930-03136 & Fuel line)
    Diehard Group 31M Deep Cycle Battery
    Pelfreybilt 31M Battery Cage
    Pelfreybilt Bed side supports
    On Board Air (Air Zenith OB2 Compressor, 5 Gallon AVS Aluminium tank, 165 PSI on /200 PSI off Sealed Viair Pressure switch)
    Powertank ARB Solenoid manifold
    Cab Mount Chop
    Exhaust Re-Route
    Trasharoo
    Iggy Switch panel
    Prinsu CABRAC Roof Rack
    Energy Susp. Poly Bushings
    COMMS
    Cobra 75WX CB Radio
    Wilson 5000 Antenna (Mounted on Prinsu Roof Rack)
    Wheeling Trips/Pics:
    Rausch Creek April 2016
    Potts Mountain October 2015
    Rausch Creek July 2015
    Moab Rock Therapy 2015
    Potts Mountain April 2015
    Potts Mountain July 2014
    Shoe Creek Jan 2014
    AR15xAR10, ChadsPride, Crom and 3 others like this.
  2. Apr 6, 2012 at 7:53 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Picked up 11/21/11
    Stock!
    A week later....Fabtech 6" lift and 35's
    Retrofitted headlights by TW member Ambiguous (FXR Projectors, Apollo Shrouds, LED Halo's, BHLM)
    Light output: FXR Retrofit (low beams on), D2 Duallys (driving pattern) and Fogs on
    OBX, NC / Ocracoke Ferry 2013
    Pelfreybilt Front Bumper and Bruteforce High Clearance Bumper
    OTRATTW Switches w/ custom bracket mounted in Radioshack Project enclosure
    Pelfreybilt Battery Tray & Aux Fuse Panel Revision 2
    Link to Long travel install pics: http://www.tacomaworld.com/forum/2nd-gen-builds/213614-aaronarfs-2012-dcsb-build-23.html#post8926871
    4845e56edd67221bbecb6d4ae39bb2bd_a5c900cb67d28bec585b2b079d7c4b51c8f0ca01.jpgf08f8eee245ef60eec99c75bfe5bb7d6_03453da291264a2f0356c25ef5dafe8a4d63950e.jpg
    LT Install before the new wheels
    78fd6089b14f5a894d7ee50135578f0c_4e628f0368fc6c8bddba8256aff3c454335fc267.jpga4c20dfe99581457883a6be9051ad36c_e8634597a9abb1bc3485b39998676ff794959031.jpg2f66ba254edef9aa2137f8edb612a0e0_4a62ac006ab43e21470270504f1f6a4c8c0346d2.jpg62510ffb0b63b3db3d7005234c9ddbc6_cdf1cd0eb464be925c919df4c472538bfc15e911.jpg569bc7705342a3ffc0355b9cd35932e0_a8dc7df5e671af5e7566b94732fcdb1c59d8148f.jpg
    Wheeling Pics - Pre Long Travel
    Potts Mountain Jeep Trail July 2014
    Shoe Creek 2014
    Side two, Crom and ChadsPride like this.
  3. Apr 6, 2012 at 7:56 AM
    mondexyota
    mondexyota Well-Known Member
    Beau
    Titusville, FL
    2010 Barcelona Red DC SR5 4x4
    3" Toytec spacer lift, 285x70x17 Nitto Terra Grapplers on 17x9 XD Misfits
    Love your truck bro, I am wanting a 6" lift really bad right now!
  4. Apr 6, 2012 at 8:08 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    sweet!
  5. Apr 6, 2012 at 9:15 AM
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Jealous of the truck man. Sexy red an black look. Im SUB'D!! :D
  6. Apr 6, 2012 at 9:19 AM
    ShadesOfGrey
    ShadesOfGrey Well-Known Member
    Jamie
    Salem, OR
    '10 DCLB, TRD Sport 4x4, MGM
    TRD Cat-Back Exhaust, Airaid CAI, Pro Comp 3" Suspension Lift, 17" Moto Metal rims w/ 33" Pro Comp tires, Powder Coated Pro-Tech Headache Rack & Toolbox
    Lookin' awesome man.
  7. Apr 6, 2012 at 9:28 AM
    swervin22
    swervin22 "Obviously, You're not a Golfer..."
    Jonas
    Chesapeake
    2004 Radiant Red Access Cab Off Road
    Thought you installed your sliders already? Or just prepped and ready to go? Either way, looking good bro! Barcelonas Unite!!
  8. Apr 6, 2012 at 9:39 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    VARY NICE!!! im going with the same setup soon only with different wheels tho
  9. Apr 6, 2012 at 9:42 AM
    Eagledynasty
    AJ
    Worcester, MassHole
    Barcelonas are steppin it up these days :D
  10. Apr 6, 2012 at 9:47 AM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    Nice man! I've got pretty much the same set up and love it!! Are you going to do gears?
  11. Apr 6, 2012 at 9:47 AM
    Eagledynasty
    AJ
    Worcester, MassHole
    Hope he does :D
  12. Apr 6, 2012 at 9:59 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Very nice man :thumbsup:
    How do you like the drain valve? I was looking at those and didn't know how much help they'd be. I've got the ATO front skid so its kind of a reach to get to the drain plug now.
  13. Apr 6, 2012 at 1:50 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    OLD PHOTO DUMPING GROUNDS OF PREVIOUS MODIFICATIONS OR SMALL MODS ETC.
    Old Set-up
    Alcan Springs Custom built 6" Leafs, All Pro Flip and OCtaco Stainless lines
    No more saggy rear end! [OLD LIFT]
    [​IMG][/URL]
    OBX Sunset
    [​IMG][​IMG]
    Bye bye stock tube steps
    BEEFED Medium width bolt on sliders w/ kick outs coated with LINE-X Premiuim
    Sliders installed!
    Armor Tech Offroad Hi-lift bed rail mount & Hi-Lift 48" Xtreme Jack
    Switched to a 60" Hi-Lift Xtreme Jack since the 48" maxed out on the street
    Pelfreybilt hilift mount. MUCH nicer/sturdier than the ATO rail mounts.
    Spare mounted with Beard Racing Y-Strap & Additional OEM Toyota D-Rings
    886 Fog Light mod (left) vs. CSJumper LED Reverse Light (Right)
    FLYZEYE "2012 Black V2W" Interior Dash light installed (Blue/White & Red Halos)
    Flyzeye 3VP Console light
    a6esa3ab_89a762bcadf0740c8bdad33dc85706965aa530ce.jpgqamuvupe_32b94ba57225c964afccef301006ff1d302e7071.jpg
    Crom likes this.
  14. Apr 6, 2012 at 1:52 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    Sick truck Aaron!!!! Finally got that build page!!! Now we can follow your mods. Keep up the good work buddy.
  15. Apr 6, 2012 at 6:32 PM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Nice ride!!!:D
  16. Apr 6, 2012 at 6:59 PM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Beautiful
  17. Apr 6, 2012 at 7:02 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  18. Apr 6, 2012 at 9:33 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Coming along really nice bro. I wish it would've been feasible for me to go with a 6" lift. You & COMA got some sick looking 12's....Keep up the good work.
  19. Apr 6, 2012 at 9:35 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You need the BHLM in a bad way Aaron... DO IT!!!
  20. Apr 6, 2012 at 9:38 PM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    I agree it would really look good. Black or graphite colored. SWEET!
